Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2006 Location: sn,fdo,lu philippines
Member: 288470 Status: Offline Sonork: 100.1605122 Thanks: 543
| <<< N96i shutting off problem,solved by infinty >>>> just fixed yesterday one N96i shut off when inserting SIM card using COMPLETE FORMAT option,ounce again thanks infinity. Nokia-N96i connector_2x5_mini 1: Tx 2: Rx 6: Gnd 5: connect to phone pin-10 10: connect to phone pin-5 br keaelite Last edited by keaelite; 09-09-2007 at 00:47. |
| | #4 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2005 Location: EVERYWHERE U GO Age: 35
Member: 106026 Status: Offline Sonork: 100.77890 Thanks: 127
| [QUOTE=keaelite;2700516]just fixed yesterday one N96i shut off when inserting SIM card using COMPLETE FORMAT option,ounce again thanks infinity. Nokia-N96i connector_2x5_mini 1: Tx 2: Rx 6: Gnd 5: connect to phone pin-10 10: connect to phone pin-5 CAN U HELP WITH CABLE???PLS I NEED ALL DIS FONE WITH READY MADE CABLE..PLS CAN U HELPS??REGARDS.............. |
| | #5 (permalink) | |
| [quote=damabib;2705207] Quote:
u can use the usb of the phone,use the usb connector only then get RJ45 cable. br keaelite | |
| | #8 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2004 Age: 40
Member: 69269 Status: Offline Thanks: 118
| N96i Not connecting I followed pinouts above. With keypad ontop and counting from left to right up and down, that is pin1(up), pin2(down) since we have 2x5 mini connector. Correct me if i am wrong.with this connection made this is what i got as result after many trials COM1 [Serial0] selected Device: Autodetect 6205-6227,6228 NOR Checking data, wait... advanced flash detection active Action: reset Boot... Press and HOLD Power button now ! baud autodetection active 9600 Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 48 sec Remove/Install battery now ! |
| | #12 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jan 2002 Location: Leon
Member: 8804 Status: Offline Thanks: 0
| 1: Tx 2: Rx 6: Gnd 5: connect to phone pin-10 10: connect to phone pin-5 1 on the phone side connects to TX 2 on the phone side connects to RX 6 on the phone side connects to Gnd 5 on the ??? connects to 10 on ??? <<<< please explain this 10 on the ??? connects to 5 on ??? <<<< and this thank you. |
| | #13 (permalink) |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2005 Location: infinity-box
Member: 130995 Status: Offline Thanks: 9,039
| 5: connect to phone pin-10 10: connect to phone pin-5 means: take wire, solder one side to phone pin-5 and solder other side to phone pin-10 |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| 5130 Call Send recieve then Switches off problem Solved.... | swechacnu | Nokia Base Band 5 ( BB-5 ) | 7 | 01-18-2011 13:48 |
| 1110i 20s 30s turn off problem solved | charletan | Universalbox | 0 | 04-04-2008 15:43 |
| !!!!K600 white screen/pls wait/ shut off problem!!!! | rakishi | Cruiser Suite | 14 | 11-07-2007 22:07 |
| E65 Auto Shut Off Success Flash By -ub | GUDO-GSM | Universalbox | 1 | 04-29-2007 13:28 |
| sx1 shut off problem | emso | Siemens Hardware Repair Area | 0 | 11-24-2006 21:16 |
