07-06-2010, 08:15 | #1 (permalink) |
Junior Member Join Date: Feb 2005 Location: PolPhone.com Age: 40
Member: 119485 Status: Offline Sonork: 100.1608366 Thanks Meter: 1 | N97 dualsim flashing error Loading data, wait... [Infinity Box] Chinese Miracle v3.15 smart-card: connected S/N: 1920:0116 Wait... Device: Autodetect 6205-6239 NOR Done Device: Autodetect 6228-6239 NAND Loading file v.02... RATECH35_08B_PCB01_GPRS_MT6235B_S01.M97_JYY_FM_MLA _091118__firmware_20100705-131008.B4M.bin loaded usb bootloader (file) is absent rom info ver: 07 sw version: RATECH35_08B_PCB01_GPRS_MT6235B_S01.M97_JYY_FM_MLA _091118.BIN project-id: M97_JYY_FM_MLA_091118, 00000000 code offset: 00000000 ffs offset/size [01]: 02620000/059E0000 rom info structure: 2nd [standard] generation TCL-ID is absent ==== [2010-07-06 08:36:46] ==== COM3 [VCP0] selected module v3.15 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: write flash NAND write: Firmware RATECH35_08B_PCB01_GPRS_MT6235B_S01.M97_JYY_FM_MLA _091118__firmware_20100705-131008.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... bootloader version: RATECH35_08B_BOOTLOADER_V005_MT6235B_M97_JYY_FM_ML A_091118.bin nfi area detection finished: Ok interface: BROM_DLL_v3.1012.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0053]: 00AD:00A100000015 [HYNIX] H8BCS0PG0MBP chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (460800)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02620000/059E0000 firmware size: 38Mb ffs size: 89Mb detect sec ro... detect custom parameters... detect project-id... project-id: M97_JYY_FM_MLA_091118 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: RATECH35_08B_BOOTLOADER_V005_MT6235B_M97_JYY_FM_ML A_091118.bin warning: id-page1 area is invalid nfi area detection finished: failed TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: RATECH35_08B_PCB01_GPRS_MT6235B_S01.M97_JYY_FM_MLA _091118.BIN project-id: M97_JYY_FM_MLA_091118, 00000000 code offset: 00000000 ffs offset/size [01]: 02620000/059E0000 rom info structure: 2nd [standard] generation TCL-ID is absent ===> done ==================== New firmware detected (v.3.15, database date: 06.06.2010): RATECH35_08B_PCB01_GPRS_MT6235B_S01.M97_JYY_FM_MLA _091118.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== nfi area detection... bootloader version: RATECH35_08B_BOOTLOADER_V005_MT6235B_M97_JYY_FM_ML A_091118.bin nfi area detection finished: Ok startup code area #1 check... startup code area #1 fixed number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . . . write core... error: can not write flash: 0FAF:S_FT_NFB_DOWNLOAD_CODE_FAIL error: last error: 0FAF:S_FT_NFB_DOWNLOAD_CODE_FAIL Disconnect... done Finished, time used: 2 min 34 sec Remove/Install battery now ! Checked at all baudrate, at 115200 flashing 3%, at 230400 6%, at 460800 12% and hang flashing Checked at orginall and edited flash file |
07-06-2010, 20:19 | #2 (permalink) |
Member: 1043909 Status: Online Thanks Meter: 60,964 | Hello, As I can see it's no a cable problem and not a box problem. I am not sure, but if flashing stop at middle of process and flash can not be written - it may be NAND flash chip fault or other kind of HW damage (f.e. bad soldered flash chip). |
07-17-2010, 16:00 | #3 (permalink) |
Junior Member Join Date: May 2004 Location: Hun
Member: 66296 Status: Offline Thanks Meter: 4 | hi same problem nfi area detection... bootloader version: RATECH35_08B_BOOTLOADER_V005_MT6235B_M98_XZY_TV_KE Y2_100107.bin nfi area detection finished: Ok startup code area #1 check... startup code area #1 fixed number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . . . . . . . . . . write core... error: can not write flash: 0FAF:S_FT_NFB_DOWNLOAD_CODE_FAIL error: last error: 0FAF:S_FT_NFB_DOWNLOAD_CODE_FAIL Disconnect... done Finished, time used: 5 min 45 sec Remove/Install battery now ! |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
error (1002) simlock3.dll winopen | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 15:57 |
