05-19-2011, 07:01 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: pakistan Age: 41
Member: 653398 Status: Offline Thanks Meter: 669 | Nasaki m505 call yes no problem module v3.30 Device: Autodetect 6253 NOR Checking data, wait... Action: reset settings ("format ffs") NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[00BB]: 0001:007E00630001 [SPANSION] S29VS128R_T chip size: 16Mb otp status/size: S_DA_NOR_OTP_NOT_SUPPORT/00000000 NAND flash chip: not installed internal RAM size: 00020000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: C100A3.XT.NASAKI01.110308.01 detect NOR info... number of areas/bytes to read: 1:00040000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: TELSDA53_SLIM_09A_PCB01_GPRS_MT6253_S00.C100A3_XT_ NASAKI01_110308_01.BIN project-id: C100A3.XT.NASAKI01.110308.01, 00000000 code offset: 00000000 ffs offset/size [02]: 00E00000/00200000 rom info structure: [standard] type (07) TCL-ID is absent ===> done ==================== New firmware found (v.3.30, database date: 11.05.2011): TELSDA53_SLIM_09A_PCB01_GPRS_MT6253_S00.C100A3_XT_ NASAKI01_110308_01.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== area size: 16Mb number of areas/bytes to read: 1:01000000 reading (HW_STORAGE_NOR)... file saved: C:\InfinityBox\ChineseMiracle\TELSDA53_SLIM_09A_PC B01_GPRS_MT6253_S00.C100A3_XT_NASAKI01_110308_01__ fullflash_20110519-101836.B0M.bin Format... Disconnect... done Finished, time used: 5 min 3 sec Remove/Install battery now ! i try flash and format but problem still |
05-19-2011, 09:00 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Nasaki m505 call yes no problem Could you write your problem in more detail, it's confusing! I guess the phone has calling problem. Repair imei and try to call emergency number without sim card. If it fails to call then phone has hardware problem. Wr. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
11-27-2011, 17:57 | #8 (permalink) |
No Life Poster Join Date: Jan 2009 Location: ---- Age: 35
Member: 959010 Status: Offline Sonork: 100.1602440 Thanks Meter: 445 | I have same problem in nasaki b3,Yes/green and end button not work on incoming call,would you like to mention which area need to be check in hardware? thanks in advance |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
