Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > Chinese Miracle & PinFinder
Old 09-14-2010, 07:27   #1 (permalink)
Member: 383211
Need this file & eeprom "dsx801_pcb01_gprs_mt6225_s00.dsx801a_eng_v1_3 _car logo.bin"
dsx801 hanged on star up but after flash mobile is dead and also eeprom is corrupted. On bcp write this "DSX801=MB=PCB-V5.0"i search this file in support area but there is no any file. following files come search "flashfiles/ChineseMiracle/_MT6225/8m/GINWAVE25_08A_GEMINI_PCB01_GSM_MT6225_S00.DSX801C_ E_A800_01_929__HTTEL-A800_8m_En_Vn_Hi_Farsi_Ar.B0M.bin
flashfiles/ChineseMiracle/_MT6225/8m/GINWAVE25_08A_GEMINI_PCB01_GSM_MT6225_S00.DSX801C_ E_A900_01_1007_8m_En_Vn_Hi_Farsi_Ar.B0M.bin
flashfiles/ChineseMiracle/_MT6225/8m/GINWAVE25_08A_GEMINI_PCB01_GSM_MT6225_S00.DSX801C_ E_V5_2_A_05_8m_En_Fr_Farsi_Pt_Ar.B0M.bin
flashfiles/ChineseMiracle/_MT6225/8m/GINWAVE25_08A_GEMINI_PCB01_GSM_MT6225_S00.DSX801_C OSTD_EN_01__nktel-a200_8m_En_Ru_Fr_Vn_Hi_Farsi_Ar.B0M.bin
flashfiles/ChineseMiracle/_MT6225/eeprom/DSX801_PCB01_GPRS_MT6225_S00.DSX801_EN_V1_8_01_SAM SUNG_ffs_01.B0E.bin
flashfiles/ChineseMiracle/_MT6225/DSX801_PCB01_GPRS_MT6225_S00.DSX801_EN_V1_8_01_SAM SUNG_16m_En_Ru_Fr_Es_It_De_Ml_Id_Th_Vn_Tr_Farsi_Pt _Ar.B0M.bin
" COM18 [VCP0] selected
module v3.20
Device: Autodetect 6205-6239 NOR
Checking data, wait...
Action: reset settings ("format ffs")
Do you want to make ffs/eeprom backup before format ?
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:8803:000C
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 2088C4FFFFFFFF:2088C400000000
flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
otp offset: 00FE0000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [standard] type
TCL-ID is absent
rom info detection finished
rom info ver: 04
sw version: DSX801_PCB01_GPRS_MT6225_S00.DSX801A_ENG_V1_3_CARL OGO.BIN
project-id: DSX801A_ENG_V1.3_carlogo, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00080000-00FFFFFF...
ffs/eeprom found near: 00540000
Detected ffs/eeprom address is non-standard: 00540000
Posible reasons:
1. ffs/eeprom is Ok but address is non-standard
2. ffs/eeprom is damaged and can't be detected
3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make full flash backup for emergency case
3. repeat required operation
Are you sure that detected ffs/eeprom address is correct ?
autodetected ffs/eeprom address confirmed by user: 00540000
detecting ffs/eeprom size...
ffs/eeprom size: 00AC0000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00540000-00FFFFFF
firmware area: 00000000-0053FFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
Finished, time used: 2 min 36 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 09-14-2010, 21:55   #2 (permalink)
Member: 148515
hello!
so what is this version: "DSX801_PCB01_GPRS_MT6225_S00.DSX801A_ENG_V1_3_CAR L OGO"? original or not? what happends if you flash phone with listed above files?
Old 09-15-2010, 09:01   #3 (permalink)
Member: 383211
hello!
it is orignol software and before formating it is working.i never flash it with above listed files bcoz i thing there is so much defrence between orignol and above listed files.i also need its eeprom.what is ur advice.i m wating for ur responce
Old 09-16-2010, 09:25   #4 (permalink)
Member: 148515
hello!
try followin file, it most matches to your original:
it also has eeprom file
Old 09-24-2010, 08:00   #5 (permalink)
Member: 383211
i flashed it with ur sugestd file but no luck
hello!
i try above file but no luck i sent u flshing log plz give me advice
COM20 [VCP6] selected
module v3.11
Device: Autodetect 6205-6227 NOR
Action: write flash
"smart write" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
write: Eeprom/ffs
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
Boot Done
Initialize Done
====> Set baud ...
921600
Set baud Done
rom info structure: 2nd [standard] generation
TCL-ID is absent
rom info ver: 04
sw version: DSX801_PCB01_GPRS_MT6225_S00.DSX801_EN_V1_8_01_SAM SUNG.BIN
project-id: DSX801_EN_V1.8_01_SAMSUNG, 00000000
TCL-ID is absent
====> Write ...
sec info (fast) detection...
usb bootloader (file) is absent
startup code area #1 check...
startup code area #1 fixed
detecting startup code area #2...
startup code area #2 is absent
Area: Firmware
Write: Firmware
Area: Eeprom/ffs
Write: Eeprom/ffs
Write Done
Finalization Done
Finished, time used: 11 min 21 sec
Old 09-24-2010, 20:33   #6 (permalink)
Member: 148515
hello!
what means "no luck"? phone can not be powered, freeze on logo, constantly restart?
have you tried eeprom file also?
Old 09-25-2010, 06:40   #7 (permalink)
Member: 383211
dx801 phone not power on.
hello!
i check it on power supply .power supply volt needle going 3 to 6 digit.and phone not power on.
Old 09-26-2010, 00:01   #8 (permalink)
Member: 148515
hello!
ok, that means phone do not power On
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
HELP!!! BACKGROUND SCREEN LOGO Michael Go Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-25-2011 23:56
needed pinout for carkit(N61xx) mobileinfo Nokia Hardware & Hardware-Repair Area 1 12-27-2006 10:20
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 1 06-02-1999 16:23
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 05-26-1999 11:35
Page generated in 0.35706 seconds with 11 queries
