03-13-2011, 19:15 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! flashfiles/ChineseMiracle/_MT6253/GOLDDRAGON53_JAVA_12832_09A_PCB01_GPRS_MT6253_S00. A19BV10_GFIVE_DSIM_IT32DE_V02_2010-09-30_w_eeprom_16m_En_Fr_Id_Hi_Urdu_Farsi_Ar.B0M.bin |
03-14-2011, 14:54 | #8 (permalink) |
Banned Join Date: Feb 2008 Age: 34
Member: 696872 Status: Offline Thanks Meter: 18 | plz help my problm not solved i have gfive m73 i have try to repair no license to produce but not done by infinity i have use your flashfile but not work here is my log plz help infinity team COM35 selected module v3.27 Device: Autodetect 6253 NOR Checking data, wait... Action: write flash write: Firmware GOLDDRAGON53_JAVA_12832_09A_PCB01_GPRS_MT6253_S00. A19BV10_GFIVE_DSIM_IT32DE_V02__G-Five-M73_2010-09-30_16m_En_Fr_Id_Hi_Urdu_Farsi_Ar.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nor area detection... interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[0093]: 0089:890300000000 [INTEL] PF38F30xxM0x1xx chip size: 16Mb otp status/size: S_DA_NOR_OTP_EXIST/00000108 NAND flash chip: not installed internal RAM size: 00020000 external RAM: S_DA_RAM_ERROR done Set baudrate (460800)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: A19BV10_GFIVE_DSIM_IT32DE_V02 detect NOR info... number of areas/bytes to read: 1:00040000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: GOLDDRAGON53_JAVA_12832_09A_PCB01_GPRS_MT6253_S00. A19BV10_GFIVE_DSIM_IT32DE_V02.BIN project-id: A19BV10_GFIVE_DSIM_IT32DE_V02, 00000000 code offset: 00000000 ffs offset/size [02]: 00E00000/00200000 rom info structure: [standard] type (07) TCL-ID is absent ===> done startup code area #1 check... done number of cores: 1 loading files... number of areas: 1 done write... write core... Disconnect... done Finished, time used: 8 min 39 sec Remove/Install battery now ! |
03-14-2011, 21:32 | #9 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! after flashing this firmware- does your phone is working, with message "no license to produce"? please post log operation "repair "no licensed to produse"" |
03-17-2011, 17:41 | #12 (permalink) |
Member: 696872 Status: Offline Thanks Meter: 18 | yes sir hi after flash with no licence to produce tik my phone with your file plone is working but no licence is not gone problm not solved plz help me here is lod COM35 selected module v3.27 Device: Autodetect 6253 NOR Checking data, wait... Action: write flash write: Firmware GOLDDRAGON53_JAVA_12832_09A_PCB01_GPRS_MT6253_S00. A19BV10_GFIVE_DSIM_IT32DE_V02__G-Five-M73_2010-09-30_16m_En_Fr_Id_Hi_Urdu_Farsi_Ar.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nor area detection... interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[0093]: 0089:890300000000 [INTEL] PF38F30xxM0x1xx chip size: 16Mb otp status/size: S_DA_NOR_OTP_EXIST/00000108 NAND flash chip: not installed internal RAM size: 00020000 external RAM: S_DA_RAM_ERROR done Set baudrate (460800)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: A19BV10_GFIVE_DSIM_IT32DE_V02 detect NOR info... number of areas/bytes to read: 1:00040000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: GOLDDRAGON53_JAVA_12832_09A_PCB01_GPRS_MT6253_S00. A19BV10_GFIVE_DSIM_IT32DE_V02.BIN project-id: A19BV10_GFIVE_DSIM_IT32DE_V02, 00000000 code offset: 00000000 ffs offset/size [02]: 00E00000/00200000 rom info structure: [standard] type (07) TCL-ID is absent ===> done startup code area #1 check... done number of cores: 1 loading files... number of areas: 1 done write... write core... Disconnect... done Finished, time used: 8 min 39 sec Remove/Install battery now ! |
03-18-2011, 23:35 | #13 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @ashish51047004 please, try to keep phone with you for one more day, we will try to make more tests and give you new software. |
03-19-2011, 03:39 | #14 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @ashish51047004 Try to flash phone with latest ChineseMiracle v3.28 (it's just uploaded in support area). Waiting for your results. |
03-19-2011, 06:41 | #15 (permalink) | |
Member: 696872 Status: Offline Thanks Meter: 18 | thanx infinity team problem solved hi infinityteam with new verson ChineseMiracle v3.28 my problem solved to no licensed to produce 100% solved here is log module v3.28 Device: Autodetect 6253 NOR Checking data, wait... Action: write flash write: Firmware GOLDDRAGON53_JAVA_12832_09A_PCB01_GPRS_MT6253_S00. A19BV10_GFIVE_DSIM_IT32DE_V02__G-Five-M73_2010-09-30_16m_En_Fr_Id_Hi_Urdu_Farsi_Ar.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs No licensed to produce fix... warning: Unknown (or damaged) firmware structure ! send full flash backup file to [email protected] nor area detection... "format ffs" active interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[0093]: 0089:890300000000 [INTEL] PF38F30xxM0x1xx chip size: 16Mb otp status/size: S_DA_NOR_OTP_EXIST/00000108 NAND flash chip: not installed internal RAM size: 00020000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: A19BV10_GFIVE_DSIM_IT32DE_V02 detect NOR info... number of areas/bytes to read: 1:00040000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: GOLDDRAGON53_JAVA_12832_09A_PCB01_GPRS_MT6253_S00. A19BV10_GFIVE_DSIM_IT32DE_V02.BIN project-id: A19BV10_GFIVE_DSIM_IT32DE_V02, 00000000 code offset: 00000000 ffs offset/size [02]: 00E00000/00200000 rom info structure: [standard] type (07) TCL-ID is absent ===> done startup code area #1 check... done number of cores: 1 loading files... number of areas: 1 done write... write core... Format... Disconnect... done Finished, time used: 5 min 6 sec Remove/Install battery now ! [/IMG] Quote:
thanks infinity team i need infinitycdma tool activation plz help me | |
The Following User Says Thank You to ashish51047004 For This Useful Post: |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
Nokia Flash Content. | Phantom | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-01-2000 23:28 |
