12-13-2008, 10:32 | #1 (permalink) |
No Life Poster Join Date: Sep 2006
Member: 343326 Status: Offline Thanks Meter: 1,463 | Need flash file for NKTEL C9000 Today in my hand NKTEL C9000 in dead condition. I try to Format the phone with complete mode but phone can't power on. Also here is i read it's detailed info take a look...... Code: COM5 [VCP1] selected module v2.70 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read/check detailed information Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:8903:0001 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: X7210_ABROAD_PCB01_GPRS_MT6225_S00.7210_TV0057_ABROAD_V1_0_5.BIN ver. sw 2: 7210_TV0057_ABROAD_V1.0.5, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 98004900000002:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... Can't detect eeprom/ffs area Do you want to use standard ffs address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs address selected by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF detecting ffs structure pass 1... ...................... detect standard fat location pass #1... .............................................. detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs detected ok: element #1 detecting ffs structure pass 2... ...................... detect standard fat location pass #1... .............................................. detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs detected ok element #2 Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Finished, time used: 76 sec Remove/Install battery now ! What is the exatelt problem to this set....... |
12-13-2008, 20:36 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,536 | hello! i would advice to make flahsing, but unfortunately no such flash file on support (X7210_ABROAD_PCB01_GPRS_MT6225_S00.7210_TV0057_AB ROAD_V1_0_5) can you find same working phone to read out backup? |
12-14-2008, 06:31 | #3 (permalink) | |
Member: 343326 Status: Offline Thanks Meter: 1,463 | Quote:
Thankx for the advice. I too try to flash the phone but Unfortunately no Such flash file on support area If any one have this file then simply share here or send it to Infinity team as soon as possible | |
06-12-2009, 14:31 | #4 (permalink) |
Junior Member Join Date: Jul 2008
Member: 821884 Status: Offline Sonork: [email protected] Thanks Meter: 0 | hi plizzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz hallp me i have problem NKTEL C9000 insart sim |
06-12-2009, 23:14 | #6 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,536 | Quote:
clear sim card contacts and card itself. if will nothelp- assemble cable and try to format FFS. only if format methods safe and complete will not work- continue by flashing | |
Need flash file for NKTEL A8800 | mirecle | CPF-BOX Ⅱ | 1 | 03-09-2010 19:40 |
Need flash file for NKTEL A8800 | mirecle | Chinese Models & Cloned Phones | 1 | 03-08-2010 21:43 |
need flash file 4 nktel a200-6223 | soshan | SpiderMan | 0 | 02-04-2010 10:19 |
need flash file for nktel v60..plz share | peter002 | SpiderMan | 0 | 08-03-2009 17:23 |
Need flash file for dejan 1.05 or full flash for 6250 with polish language | Rafal | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 08-10-2002 20:13 |
