10-24-2011, 03:32 | #1 (permalink) |
Insane Poster Join Date: Dec 2007
Member: 660421 Status: Offline Thanks Meter: 26 | Need Help to bypass MT6253 calibrate on start-up i can't bypass the calibrate tap screen on start-up would you please to help me here is the log : Code: COM10 selected module v4.01 Action: touchscreen calibration How to calibrate touchscreen: - for this operation you need to have full flash backup from phone - if you have full flash backup already press "Yes", select full flash file and follow instructions given by software - if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure Do you have full flash backup ? Loading file v.02... HEXING53_09A_GEMINI_PCB01_GPRS_MT6253_S00.X239_7A_QVGA_MAXTRON_V18_110523.BIN_FLNPF38F3040M0Y3DE__fullflash_20111022-204050.B0M.bin loaded error: can't detect ffs/eeprom structure id error: operation failed ! Finished, time used: 25 sec Remove/Install battery now ! thank you, br madshark |
10-24-2011, 03:36 | #2 (permalink) |
Member: 660421 Status: Offline Thanks Meter: 26 | this is full backup firmware with eeprom pls to check it, Maxtron MG-278.rar - 4shared.com - online file sharing and storage - download thank you |
10-24-2011, 06:54 | #3 (permalink) |
No Life Poster Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | hello bro first to use latest version of mmoudle v4.02 then i think you donot choose autodetect MT6253 NOR in model plz choose and post result |
The Following User Says Thank You to Deepesh Sharma For This Useful Post: |
10-24-2011, 13:46 | #4 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Install latest Mmodule v4.05, read firmware and then try to do Calibrate TouchScreen process. Try with all modes one by one. Wr. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
10-24-2011, 17:17 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! COM3 [Winachsf0] selected module v4.05 Action: touchscreen calibration How to calibrate touchscreen: - for this operation you need to have full flash backup from phone - if you have full flash backup already press "Yes", select full flash file and follow instructions given by software - if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure Do you have full flash backup ? Loading file v.02... HEXING53_09A_GEMINI_PCB01_GPRS_MT6253_S00.X239_7A_ QVGA_MAXTRON_V18_110523.BIN_FLNPF38F3040M0Y3DE__Ma xtron-MG278.bin loaded ffs/eeprom record offset detected ffs/eeprom record size detected ffs/eeprom record offset detected ffs/eeprom record size detected Model: _Autodetect MT6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! |
10-26-2011, 08:30 | #6 (permalink) |
Member: 660421 Status: Offline Thanks Meter: 26 | hello, MModule 04.05 downloaded i try in every step mode choosing Autodetect MT6253 NOR the Log : mode-auto Code: COM10 selected module v4.05 Action: touchscreen calibration How to calibrate touchscreen: - for this operation you need to have full flash backup from phone - if you have full flash backup already press "Yes", select full flash file and follow instructions given by software - if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure Do you have full flash backup ? Loading file v.02... HEXING53_09A_GEMINI_PCB01_GPRS_MT6253_S00.X239_7A_QVGA_MAXTRON_V18_110523.BIN_FLNPF38F3040M0Y3DE__fullflash_20111022-143050.B0M.bin loaded error: can't detect ffs/eeprom structure id error: operation failed ! Finished, time used: 18 sec Remove/Install battery now ! Code: COM10 selected module v4.05 Action: touchscreen calibration mode: 1 Model: _Autodetect MT6253 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A04:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E04 Date: 2000.00.00 Version: 1.0 Version: X239_7A_QVGA_MAXTRON_V18_110523 Version: HEXING53_09A_GEMINI_HW ==================== New firmware found (v.4.05, database date: 20.10.2011): X239_7A_QVGA_MAXTRON_V18_110523 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== detecting structure #2... 1 2 3 5 7 8 9 11 12 13 done 86 byte(s) read imei: 35474804498515 connection Ok detecting structure #5 (mode-1)... 0 2 3 4 5 6 7 8 10 12 13 14 15 16 18error: detection failed (15 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't detect ffs/eeprom structure id error: operation failed ! Finished, time used: 21 sec Remove/Install battery now ! Code: COM10 selected module v4.05 Action: touchscreen calibration mode: 2 Model: _Autodetect MT6253 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A04:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E04 Date: 2000.00.00 Version: 1.0 Version: X239_7A_QVGA_MAXTRON_V18_110523 Version: HEXING53_09A_GEMINI_HW ==================== New firmware found (v.4.05, database date: 20.10.2011): X239_7A_QVGA_MAXTRON_V18_110523 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== detecting structure #2... 1 2 3 5 7 8 9 11 12 13 done 86 byte(s) read imei: 35474804498515 connection Ok detecting structure #5 (mode-2)... 0warning: wrong packet cs 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19error: detection failed (20 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't detect ffs/eeprom structure id error: operation failed ! Finished, time used: 1 min 30 sec Remove/Install battery now ! Code: COM10 selected module v4.05 Action: touchscreen calibration mode: 3 Model: _Autodetect MT6253 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A04:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E04 Date: 2000.00.00 Version: 1.0 Version: X239_7A_QVGA_MAXTRON_V18_110523 Version: HEXING53_09A_GEMINI_HW ==================== New firmware found (v.4.05, database date: 20.10.2011): X239_7A_QVGA_MAXTRON_V18_110523 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== detecting structure #2... 1 2 3 5 7 8 9 11 12 13 done 86 byte(s) read imei: 35474804498515 connection Ok detecting structure #5 (mode-3)... 0 1 2 3 5 6 7 9 10 11 12 13 15 16 17 19error: detection failed (16 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't detect ffs/eeprom structure id error: operation failed ! Finished, time used: 14 sec Remove/Install battery now ! Code: COM10 selected module v4.05 Action: touchscreen calibration mode: 4 Model: _Autodetect MT6253 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A04:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E04 Date: 2000.00.00 Version: 1.0 Version: X239_7A_QVGA_MAXTRON_V18_110523 Version: HEXING53_09A_GEMINI_HW ==================== New firmware found (v.4.05, database date: 20.10.2011): X239_7A_QVGA_MAXTRON_V18_110523 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== detecting structure #2... 1 2 3 5 7 8 9 11 12 13 done 86 byte(s) read imei: 35474804498515 connection Ok detecting structure #5 (mode-4)... 0 2 3 4 5 6 7 8 9 10 12 13 14 15 16 17 18 19error: detection failed (18 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't detect ffs/eeprom structure id error: operation failed ! Finished, time used: 14 sec Remove/Install battery now ! Thank you |
10-26-2011, 18:29 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! i am loading your backup, please find same name file! Loading file v.02... HEXING53_09A_GEMINI_PCB01_GPRS_MT6253_S00.X239_7A_ QVGA_MAXTRON_V18_110523.BIN_FLNPF38F3040M0Y3DE__fu llflash_20111022-204050.B0M.bin loaded ffs/eeprom record offset detected ffs/eeprom record size detected ffs/eeprom record offset detected ffs/eeprom record size detected Model: _Autodetect MT6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! This is file from your archive, FULL FLASH folder |
10-28-2011, 22:42 | #8 (permalink) |
Member: 660421 Status: Offline Thanks Meter: 26 | Finally my problemo solved the log : mode auto Code: COM10 selected module v4.05 Action: touchscreen calibration How to calibrate touchscreen: - for this operation you need to have full flash backup from phone - if you have full flash backup already press "Yes", select full flash file and follow instructions given by software - if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure Do you have full flash backup ? Loading file v.02... HEXING53_09A_GEMINI_PCB01_GPRS_MT6253_S00.X239_7A_QVGA_MAXTRON_V18_110523.BIN_FLNPF38F3040M0Y3DE__fullflash_20111022-143050.B0M.bin loaded ffs/eeprom record offset detected ffs/eeprom record size detected ffs/eeprom record offset detected ffs/eeprom record size detected Model: _Autodetect MT6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A04:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E04 Date: 2000.00.00 Version: 1.0 Version: X239_7A_QVGA_MAXTRON_V18_110523 Version: HEXING53_09A_GEMINI_HW ==================== New firmware found (v.4.05, database date: 20.10.2011): X239_7A_QVGA_MAXTRON_V18_110523 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== 86 byte(s) read warning: wrong packet cs imei: 35474804498515 connection Ok 512 byte(s) read 85 byte(s) read reading data #2... 512 byte(s) read calibration value: 0 writing data... verification... verification Ok Finished, time used: 21 sec Remove/Install battery now ! its can be done by choosing "Model _Auto detect MT6202-6239 NOR" many thanks to Infinity, now the phone working perfectly without touchscreen Wbr, madshark |
01-30-2012, 12:46 | #10 (permalink) | |
Member: 660421 Status: Offline Thanks Meter: 26 | Quote:
coz,, sharing of knowledge and experience was more important.. i think,,, and I am very glad to know that my posts can help You sorry 4 my eng.. br, madshark | |
The Following User Says Thank You to madshark96 For This Useful Post: |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
