Old 09-17-2010, 16:12   #1 (permalink)
jhon357add's Avatar
Member: 949016
Sonork: 161.7672
Thanks Meter: 25
Need Help To Work This Phone Vertu F3+
Hi I Need The Way To Setup This Phone To Work With Infinity I was Trying to set it in Engineer mode,But I cant Any Way To Do it.IF Any People Know Aboit Plz Post Something.
Old 09-17-2010, 19:45   #2 (permalink)
Member: 950629
Thanks Meter: 105
What is the problem of this phone.
anyway...
Use correct RX TX pinout and then boot it with infinity.
Old 09-17-2010, 20:34   #3 (permalink)
jhon357add's Avatar
Member: 949016
Sonork: 161.7672
Thanks Meter: 25
its Bad No service,I Need To Format or Repair Ixxx,So I need The Pinout
Old 09-17-2010, 22:03   #4 (permalink)
Member: 950629
Thanks Meter: 105
what is the CPU type?
Old 09-18-2010, 09:24   #5 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
what type connector is used in this phone?
do you have pinfinder?
are you sure that this phone is mt62xx family?
tip: you can check this by typing *#0044# and pressing green (send) button.
if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software
Old 09-18-2010, 13:23   #6 (permalink)
jhon357add's Avatar
Member: 949016
Sonork: 161.7672
Thanks Meter: 25
Hello I Just get My Pinfinder,But I Dont Know Use Good the Conector its like ZTE A36 And When I Type *#0044# Send It Change the Language to English,So I know Its Support By Infinity any help
Old 09-19-2010, 00:58   #7 (permalink)
Member: 950629
Thanks Meter: 105
do you have a pinfinder? if not you have to find rx tx points by your self.
Disassemble the phone and check the PCB for rx tx points.
Old 09-19-2010, 01:53   #8 (permalink)
Member: 950629
Thanks Meter: 105
If you found the RX TX point on PCB solder them as this
box Tx (RJ45 pin-2) to phone Rx point
box Rx (RJ45 pin-3) to phone Tx point
box GND(Rj45 pin 8) to phone GND point.
then follow this..Infinity Box Video Tutorial
If you not found a RX TX on PCB you have to check voltages on USB connecter for find the RX,TX. check this example.
Explain to find pinout on 12 pin usb connector.
1. At first, you need to find GND signal (3pin-00.2v)
2. The second step: you need to find Tx Rx signals. Choose the pinouts, that may probably suit. You have 12 pinouts:
1pin-0.00v - this pinout is wrong
2pin-2.78 - it may correspond to Tx Rx signals
3pin-00.2v - GND signal
4pin-2.75v - it may correspond to Tx Rx signals
5pin-1.09v - LOOKS LIKE Tx Rx signals, BUT IT IS NOT!
6pin-0.00v - this pinout is wrong
7pin-4.02v - this pinout is wrong
8pin-2.89v - it may correspond to Tx Rx signals
9pin-3.05v - this pinout is wrong
10pin-0.00v - this pinout is wrong
11pin-1.09v - it may correspond to Tx Rx signals
12pin-0.02v - YOU DON'T NEED these fake signals with high and low voltage
3. In order to find Tx you need to put multimeter to test, diod ( "+" and "-" = beep ).
When the phone is POWERED ON, Tx with GND make a sound beep.
When it is TURNED OFF, it shows 600-700 ohm.
It is suggested to do all the job using wire connection.
After following the above mentioned steps you'll find, that 2pin is Tx and 8pin is Rx. Tx has to be 1.7v or 2.7v and Rx - 1.8v or 2.8v. These characteristics may change depending on the processor parameters. But Tx and Rx is not the same. Tx can be 2.78v, 2.75v, 2.7v.
INFO:@Gsmtricks
If you have pinfinder folow this ... Infinity Pinfinder user manual Then this.. Infinity Box Video Tutorial
Old 09-19-2010, 11:26   #9 (permalink)
Member: 148515
hello!
step by step procedure is completely described in pinfinder user manual
Old 09-19-2010, 13:09   #10 (permalink)
jhon357add's Avatar
Member: 949016
Sonork: 161.7672
Thanks Meter: 25
i Just Get Pinfinder and Dont Work Dont Detect Any Phone Thats My Problem
Old 09-19-2010, 18:45   #11 (permalink)
Member: 148515
hello!
before searching pinout you must do 3 easy steps:
1. Make sure that this is mt62xx MCU based phone.
if you will see "language set: english"- you can be sure, that this phone is MT62xx.
Now activate Silent mode in phone by pressing and holding "#".
2. Count number of pins in system connector. After this is done-
pick correspondent cable. For example if you counted 2x6 pins- it is in total 12
so no point to put L14D cable instead of correct one, L12B.
3. Select cable type, connect power crocodiles in the place of battery.
push "Power On!" in software. Now phone is powered with pinfinder power.
Try to switch it On. This is main rule for success pinout search.
(Phone must turn ON)
if it does not turn On- no point to search for pinouts. you will not find it.
Start from modifying your main infinity box to deliver more power to pinfinder.
There is one diode which must be removed and shortcutted.
Open Pinfinder User Manual on Trubleshooting section and see in pictures how this must be done.
after you get phone powered- you are ready to find phone pinout.
press and Hold phone power button and start search.
Old 09-20-2010, 13:25   #12 (permalink)
jhon357add's Avatar
Member: 949016
Sonork: 161.7672
Thanks Meter: 25
Thank Infinity Team The Best Team Im Already Using My Pinfinder Thaks To You.
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 05-26-1999 11:35
Page generated in 0.24230 seconds with 9 queries
