Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jan 2010 Location: In the Caribbean Age: 41
Member: 1202427 Status: Offline Sonork: 100.1604781 Thanks: 30
| Need help with a ZTE G-X990 Hello, I need some help here. The thing is I received this zte model with aparently improper flashing because it showed Invalid IMEI. I repaired it successfully and it received no radio coverage. So decided to flash it, in case it had being incorrectly flashed with another box. I have downloaded 2 versions from the x990 support folder, I flash them, the process ends correctly but then it reports it can not find the FFS. This phone has a NAND flash chip. When I try to format the ffs it seems as if it were trying to format a NOR flash chip. I am posting the current state of the logs of MModule after reading general information. I need some clue or idea from support or some more experienced user to figure out if the phone has a defective flash ship, or the current version of MModule is not working this model properly or if I am selecting something wrong at the time of flashing: COM4 [VCP0] selected module v4.09 Device: ZTE-X990 Checking data, wait... Action: read/check information interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0004]: 00EC:0076005A003F [SAMSUNG] K9K1208X0C chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: absent done Set baudrate (115200)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/06000000 firmware size: 32Mb ffs size: 96Mb detect sec ro... detect custom parameters... detect project-id... project-id: X990_V2_Z5_FR_D1EF111 detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: ZTEMT35_09A_GEMINI_BOOTLOADER_V005_MT6235B_X990_V2 _Z5_FR_D1EF111 nfi area detection (3 cores) finished: Ok warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: ZTEMT35_09A_GEMINI_PCB01_GPRS_MT6235B_S01.X990_V2_ Z5_FR_D1EF111.BIN project-id: X990_V2_Z5_FR_D1EF111, 00000000 code offset: 00000000 rom info structure: [standard] type (07) TCL-ID is absent ===> done Disconnect... done Finished, time used: 49 sec Remove/Install battery now ! There is a warning withing this log, almost at the end, that says it can not find the ffs area. I am open to sugestions. Br, Zeddicus. |
| | #3 (permalink) |
| Follow up with G-X990 Hello, Yes, phone is dead now. That is, it will not turn on, but if connected to the box via the USB port using my box integrated pinfinder L10C adapter it is detected and can be flashed. I made another trial yesterday. I made a full format of FFS area, which did not report any error and flashed it again, but no response from the phone what so ever. Here is log: Code: ==== [21/11/2011 07:19:03 p.m.] ==== COM4 [VCP0] selected module v4.09 Device: ZTE-X990 Checking data, wait... Action: erase whole flash chip interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0004]: 00EC:0076005A003F [SAMSUNG] K9K1208X0C chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: absent done Set baudrate (115200)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/06000000 firmware size: 32Mb ffs size: 96Mb detect sec ro... detect custom parameters... detect project-id... project-id: X990_V2_Z5_FR_D1EF111 detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: ZTEMT35_09A_GEMINI_BOOTLOADER_V005_MT6235B_X990_V2_Z5_FR_D1EF111 nfi area detection (3 cores) finished: Ok warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: ZTEMT35_09A_GEMINI_PCB01_GPRS_MT6235B_S01.X990_V2_Z5_FR_D1EF111.BIN project-id: X990_V2_Z5_FR_D1EF111, 00000000 code offset: 00000000 rom info structure: [standard] type (07) TCL-ID is absent ===> done Format... 00000000-03FFFFFF... Format done Disconnect... done Finished, time used: 1 min 0 sec Remove/Install battery now ! Code: ==== [21/11/2011 07:22:03 p.m.] ==== COM4 [VCP0] selected module v4.09 Device: ZTE-X990 Checking data, wait... Action: write flash NAND write: Firmware ZTE-X990_ZTEMT35_09A_GEMINI_PCB01_GPRS_MT6235B_S01.X990_V2_Z9_ES_D1EF107_2010-06-13_En_Es.B4M_4.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... bootloader version: ZTEMT35_09A_GEMINI_BOOTLOADER_V005_MT6235B_X990_V2_Z9_ES_D1EF107 nfi area detection (3 cores) finished: Ok interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0004]: 00EC:0076005A003F [SAMSUNG] K9K1208X0C chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: absent done Set baudrate (115200)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... detect sec ro... detect custom parameters... detect project-id... detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: nand header is empty: probably flash chip completely erased warning: can not detect header nfi area detection (0 cores) finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done nfi area detection... bootloader version: ZTEMT35_09A_GEMINI_BOOTLOADER_V005_MT6235B_X990_V2_Z9_ES_D1EF107 nfi area detection (3 cores) finished: Ok startup code area #1 check... done number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . . . . . . . . . . write core... Disconnect... done Finished, time used: 27 min 46 sec Remove/Install battery now ! How can I provide ffs log? If I try to use the file system tab it fails with an error. Up to this point, I really do not know what else to do. Br, Zeddicus. |
| | #4 (permalink) |
| More information Ok. Now, here is more log information, this time trying to format ffs using service tab, ffs: complete mode: Code: COM4 [VCP0] selected
module v4.10
Device: ZTE-X990
Action: reset settings ("format ffs") NAND
Connect...
Connecting...
Booting...
CPU: 6235:8A04:8A01
status: FF
bbchip bl ver: FE
chip size: 64Mb
bits i/o: 08
address cycles: 04
done
done
ram test...
testing 32bit...
testing 16bit...
ram test passed
detect ffs...
firmware size: 32Mb
ffs size: 96Mb
detect sec ro...
project-id: X990_V2_Z9_ES_D1EF107
detect NAND info...
TCL-ID detection...
rom info ver: 07
sw version: ZTEMT35_09A_GEMINI_PCB01_GPRS_MT6235B_S01.X990_V2_Z9_ES_D1EF107.BIN
project-id: X990_V2_Z9_ES_D1EF107, 00000000
TCL-ID is absent
===> done
warning: can not format: HW_STORAGE_NOR is not present
Format...
autodetection mode...
error: can not format: 0BDC:S_DA_INVALID_RANGE
Format...
error: last error: 0BDC:S_DA_INVALID_RANGE
Disconnect...
done
Remove/Install battery now ! NAND flash id[0004]: 00EC:0076005A003F [SAMSUNG] K9K1208X0C So, there is a NAND K9K1208X0C Samsung flash chip installed on the phone, not a NOR. Br, Zeddicus |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Need software upgrade for Nokia 5110 | ptkrf | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 26 | 09-25-2012 02:41 |
| HELP!!! BACKGROUND SCREEN LOGO | Michael Go | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 12-25-2011 23:56 |
| Help with 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 3 | 05-25-2009 16:29 |
| need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 1 | 06-02-1999 16:23 |
| need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 0 | 05-26-1999 11:35 |
