09-17-2008, 17:49 | #1 (permalink) |
No Life Poster Join Date: Sep 2006
Member: 343326 Status: Offline Thanks Meter: 1,463 | Need Pinout Of Nokia Copy phone..... I need pinout of this model. It is Nokia Phone Copy. But back of the sticker it is show Only IMEI & Gsm Frequency. Connector - 1 x 12 Gnd - Pin 1 I seen N95_2-slider.txt but it's Gnd point is 12...... & it's Gnd point is show 1 Please If some one have this model pinout share here. Thankx in advance. |
09-17-2008, 18:04 | #2 (permalink) |
Registered User Join Date: Jan 2007 Location: South Africa/Pakistan
Member: 437195 Status: Offline Thanks Meter: 1,734 | u can do this... 1. set multimeter to voltage measuring. 2. set one multimeter probe to some grounded phone part (if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal) 3. with second probe touch one by one all phone pins (phone battery attached) (to get better result i would advice to set needle on the end of second probe) memorese pins with voltage between 2,7-2,9volts. those are tx/rx |
09-17-2008, 21:40 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! use pinfinder or mentioned above method. please note that in case of voltage measuring method you must have battery fully charged and attached to phone. better if phone will be powered On, but will work on powered OFF phone too |
need pinout same nokia copy china n97 | mohammed imran | Infinity-Box | 5 | 01-27-2010 08:53 |
pinout of nokia n73 needed (connector broken) | ..::khaled::.. | Infinity-Box | 3 | 07-12-2008 17:33 |
Need Pinout Of This Phone | alamgarh | Infinity-Box | 1 | 06-16-2008 20:54 |
need pinout of nokia n80 chinees | aliakbar | Infinity-Box | 0 | 08-21-2007 12:07 |
need pinout of nspro and pinout of all cables | cobra02a | NSPRO | 2 | 10-23-2006 20:33 |
