01-08-2017, 12:46 | #1 (permalink) |
Junior Member Join Date: Jun 2014
Member: 2213738 Status: Offline Sonork: 100 Thanks Meter: 8 | need solution to unlock zte s752 Operation : Check / Read Info [ v1.54 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 347 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : FECAEDA60C157198EC10A5FB5DEC1700 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09 [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Done! Elapsed: 00:00:04 Reconnect Power/Cable! Operation : Read Flash [ v1.54 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 347 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : FECAEDA60C157198EC10A5FB5DEC1700 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09 [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Reading Flash Content now ... Read Flash now Read Ok , 4194304 bytes read Check and collect compile info File_Info : RDR61D_F118_PCB01_gprs_MT6261_S00.VDF_MZ_ZTE-S752V1_0_0B04.bin FileVersion : VDF_MZ_ZTE-S752V1.0.0B04 [ScatCFG] : MT6261 / VDF_MZ_ZTE-S752V1.0.0B04 / NOR , SF Firmware saved to : C:\InfinityBox\CM2MTK\Read_out \RDR61D_F118_PCB01_gprs_MT6261_S00\ Done! Elapsed: 00:00:20 Reconnect Power/Cable! here is link to readout : RDR61D_F118_PCB01_gprs_MT6261_S00 - Download - 4shared |
03-16-2017, 11:16 | #3 (permalink) | |
Registered User Join Date: Mar 2008 Location: @ blacksheep digital
Member: 731353 Status: Offline Thanks Meter: 254 | Quote:
05-04-2017, 09:35 | #4 (permalink) |
Freak Poster Join Date: Jan 2015 Location: Malawi
Member: 2330405 Status: Offline Sonork: 100.1661964 Thanks Meter: 37 | flash this unlocked bin https://www.4shared.com/get/UoZ3KNQ9...61D_F118_.html |
08-14-2017, 12:41 | #5 (permalink) |
Freak Poster Join Date: Jun 2013 Location: Zimbabwe, mutare
Member: 1957238 Status: Offline Thanks Meter: 80 | zte s752 unlock done! use nck mtk generic module select zte r255 and usb mode log below USB Connection selected. EXE VERSION: NCKDongle MTK Tool 1.49 Connect phone in boot mode ... USB\VID_0E8D&PID_0003&REV_0100 Com port ok : COM15 Phone detected...Please wait Conected ok with target ... Starting meta mode..... IMEI[1]: 861369039783813 IMEI[2]: 861369039783813 Start read, wait.... Block1[N]: Locked (remain:0) Code : 12345678 Block2[NS]: Unlocked Block3[SP] Unlocked Block4[C]: Unlocked Unlock file done Unlock file done Processing done. Unlock done. Clean tmp directory....wait. Clean tmp directory....done. META END OK. All done. i don't think infinity will ever support these new models for sp unlock because it was requested long time ago but still no answer from them. |
08-14-2017, 13:27 | #6 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | Quote:
ALL THINGS WILL BE SUPPORTED IN CM2MTK V2.0 WBR sahil2000ind | |
