08-23-2008, 05:02 | #6 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Bangladesh
Member: 621121 Status: Offline Thanks Meter: 366 | cm ver 2.59 Action: read/check detailed information Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6217:8A00]... CPU: MT6217 high speed boot enabled boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22212200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22212200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22212200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22212200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00E00000 flash: 01227E22212200:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00800000 Detected eeprom/ffs address is non-standard: 00800000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00800000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 00800000 ffs chip: 00 eeprom/ffs area: 00000000:00800000-00FFFFFF detecting ffs structure pass 1... ............ detect standard fat location pass #1... ................................ detect extended fat location pass #1... ............ detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #1 detected ok detecting ffs structure pass 2... ............ detect standard fat location pass #1... ................................ detect extended fat location pass #1... ............ detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #2 detected ok Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... Finished, time used: 62 sec Remove/Install battery now ! Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... baud set to: 19200 error: connection failed ! Operation failed ! Finished, time used: 78 sec Power off phone now ! |
08-23-2008, 13:59 | #7 (permalink) |
No Life Poster Join Date: Jul 2005 Location: player /-GSM-\ Field
Member: 161115 Status: Offline Sonork: Here you can find it... Thanks Meter: 3,039 | tested flash file Download Link http://rapidshare.com/files/119233238/Sprint_S60.rar |
The Following User Says Thank You to SHOEB AHMED For This Useful Post: |
08-23-2008, 16:40 | #8 (permalink) | |
Member: 621121 Status: Offline Thanks Meter: 366 | Quote:
08-23-2008, 16:49 | #9 (permalink) | |
Member: 161115 Status: Offline Sonork: Here you can find it... Thanks Meter: 3,039 | see.................... Quote:
11-18-2008, 09:46 | #14 (permalink) | |
Freak Poster Join Date: Jul 2007 Location: TNC B A N G L A D E S H
Member: 541511 Status: Offline Sonork: 1583582 Thanks Meter: 51 | flash unlock s60 Quote:
http://rapidshare.com/files/164911784/file_S60.rar.html loader http://rapidshare.com/files/16491281...lodar.rar.html | |
12-07-2008, 14:11 | #15 (permalink) | |
Banned Join Date: Feb 2007
Member: 445578 Status: Offline Thanks Meter: 440 | Quote:
need sprint s80 flash file | sharif_tell | Chinese Models & Cloned Phones | 6 | 03-21-2010 15:05 |
need sprint s60 flash file pls help | gsm_bds | SpiderMan | 1 | 08-15-2009 10:51 |
sprint s60 flash file | .:ISMAIL_BD:. | SpiderMan | 0 | 08-15-2009 10:49 |
i need sprint s60 flash file | mithon | Chinese Models & Cloned Phones | 3 | 04-24-2009 18:40 |
need sprint p50 flash file | unlock & flash | Infinity-Box | 9 | 04-22-2009 08:36 |
