09-20-2010, 05:36 | #1 (permalink) |
Registered User Join Date: Mar 2007 Location: Bandung, Indonesia
Member: 461468 Status: Offline Thanks Meter: 139 | Nexian G381i MModule v. 3.59 - SIM2 IMEI write problem Thanks for ur update soft. I have succesfully repair IMEI this phone with v. 3.59 for IMEI SIM1 but IMEI SIM2 still could not write to the phone. And I tried used Chinese Miracle v3.22 not work for SIM2 IMEI writing. Please help how to solve this problem. Thanks & Regards, |
09-21-2010, 03:32 | #3 (permalink) |
Member: 461468 Status: Offline Thanks Meter: 139 | Thanks for ur reply Herewith the logs: COM9 [VCP0] selected module v3.59 Action: "repair imei" imei write method: mode-2 new imei: 359886034168673 Model: Nexian-NX-G381i Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:B46B:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: E510H_PR1_R0_V_9_ID Version: TINNO23C_08B_GEMINI_HW 81 byte(s) read imei: 35988603416867 connection Ok 81 byte(s) read verification... verification done: 35988603416867 Finished, time used: 14 sec Remove/Install battery now ! NOTE : All nexian type sold in Indonesia using 2 simcard, most problem "EMERGENCY call" due IMEI missing (000000000000 or FFFFFFFFFFFFF) in SIM1 and SIM2. I have try yesterday other G381i with same problem for SIM1 is working and SIM2 still could write IMEI. Thks for ur attetion n kind help. Regards, |
09-21-2010, 03:36 | #4 (permalink) |
Member: 461468 Status: Offline Thanks Meter: 139 | This is log with Chines miracle 3.22, tried to write SIM2: COM9 [VCP0] selected module v3.22 Action: "repair imei" imei write method: mode-2 imei write channel: imei #2 for dual sim/mono CPU new imei: 359886035408672 Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:B46B:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: E510H_PR1_R0_V_9_ID Version: TINNO23C_08B_GEMINI_HW detecting structure #2... 1 2 5 6 7 8 9warning: wrong packet cs 11 13 17 18 21 22 23 24 25 27 29error: detection failed (18 tries), read flash and send to support connection Ok detecting structure #2... 1 2 5 6 7 8 9 11 13warning: wrong packet cs 17 18 21 22 23 24 25 27 29error: detection failed (18 tries), read flash and send to support error: can't read required data error: operation failed ! Finished, time used: 29 sec Remove/Install battery now ! |
09-23-2010, 10:53 | #6 (permalink) |
Member: 461468 Status: Offline Thanks Meter: 139 | try not work with mode 1, herewith log: Action: "repair imei" Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! If you are sure that cable is good - select another baudrate (f.e. set baudrate to "autodetect") operation failed ! Finished, time used: 1 min 4 sec Remove/Install battery now ! |
09-23-2010, 10:59 | #7 (permalink) |
Member: 461468 Status: Offline Thanks Meter: 139 | this is with mode 3, logs: COM9 [VCP0] selected module v3.22 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: "repair imei" imei write method: mode-3 imei write channel: imei #2 for dual sim/mono CPU new imei: 359886035408672 ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot Off chip: 0011:B46B:000C status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent rom info detection finished rom info ver: 07 sw version: TINNO23C_08B_GEMINI_PCB01_GPRS_MT6223P_S00.E510H_P R1_R0_V_9_ID.BIN project-id: E510H_PR1_R0_V_9_ID, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/001F0000 rom info structure: [standard] type (07) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: TINNO23C_08B_GEMINI_PCB01_GPRS_MT6223P_S00.E510H_P R1_R0_V_9_ID__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\TINNO23C_08B_GEMI NI_PCB01_GPRS_MT6223P_S00.E510H_PR1_R0_V_9_ID__ffs _20100923-165758.B0E.bin flash: 01227E22202200:2AEA0000000000 Backup required data Done ====> Patch required data ... imei is not detected ! What to do: 1. Power-On phone 2. wait 20-30 sec 3. Power-Off by "Power" button, don't remove battery ! 4. Repeat "imei" procedure again If imei can't be detected: 1. make "complete" ffs/eeprom format 2. Power-On phone 3. wait 20-30 sec 4. Power-Off by "Power" button, don't remove battery ! 5. Repeat "imei" procedure again If imei can't be detected: read flash and send to support: [email protected] Patch required data Fail Finished, time used: 3 min 15 sec Remove/Install battery now ! |
09-23-2010, 18:59 | #8 (permalink) |
Freak Poster Join Date: Jun 2004 Location: Indonesia
Member: 69608 Status: Offline Thanks Meter: 63 | use chinese miracle work for me today.. loading data, tunggu... [Infinity Box] Chinese Miracle v3.22 smart-card: connected S/N: XXXX:XXXX tunggu... Alat: Autodetect 6205-6239 NOR selesai COM7 ready Action: "repair imei" Model: Autodetect 6205-6239 NOR memeriksa data, tunggu... telepon harus dihidupkan! Menghubungkan, tunggu... telepon terdeteksi, tunggu... imei-1: " imei menulis metode: cara-1 imei menulis terusan: imei #1 untuk sim rangkap/mono CPU new imei-1: 359886034373471 verifikasi OK selasai, waktu diperlukan: 8 sec lepas/pasang baterai sekarang ! Action: "repair imei" Model: Autodetect 6205-6239 NOR memeriksa data, tunggu... telepon harus dihidupkan! Menghubungkan, tunggu... telepon terdeteksi, tunggu... imei-2: " imei menulis metode: cara-1 imei menulis terusan: imei #2 untuk sim rangkap/mono CPU new imei-2: 359886035613479 verifikasi OK selasai, waktu diperlukan: 7 sec lepas/pasang baterai sekarang ! |
09-23-2010, 21:18 | #9 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! can you try IMEI canage via Bluetooth? here is how to make it: IMEI change without cable over Bluetooth link step-by-step tutorial - GSM-Forum |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
Nokia 51xx/61xx imei changer ver. 1.10?????? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 04-06-2012 16:22 |
6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-21-2011 01:44 |
