12-20-2009, 11:59 | #16 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,531 | CPU independent mode will not work if "COM port option" is disabled in phone Engeneering menu. access it using keyboard codes and check if COM port is enabled, ussually it must be set from OFF or COM2 to COM1 state. arround 10% of chinese phones have com port disabled from factory, this is why IMEI can not be changed via Mode-1, can not work CPU independent pinout search and some other operations. |
01-01-2010, 19:39 | #17 (permalink) |
Freak Poster Join Date: Sep 2009 Location: www.telefony-nawigacje.pl
Member: 1122479 Status: Offline Thanks Meter: 22 | so the rx tx was in micro usb connector but pinfinder can't find pins so i solder wire direct from infinity (rx,tx,gnd) and read by chinese miracle...where is problem?now i can work with phone but why pinfinder can't find pins? |
01-04-2010, 14:15 | #20 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,531 | hello! in this case you must check, that you soldered to this connector 5 wires. they must be from pin 1 to 5 of DB26 selecting L05B search is done only by 5 first pins. if you soldered others- you will not get any result |
The Following 2 Users Say Thank You to InfinityHelp For This Useful Post: |
8800 ARTE RM-233 schematic | chimeto | Nokia Hardware & Hardware Repair | 2 | 06-10-2015 21:08 |
-=8800 Arte RM-233 Media Memory corrupted=- | Dr_Diesel | Nokia Hardware & Hardware Repair | 5 | 09-09-2010 00:49 |
Need 8800 arte RM-233 chinese language fw | kungpaoski | Nokia Base Band 5 ( BB-5 ) | 0 | 12-10-2009 01:52 |
Nokia 8800 Arte RM-233 Contact Service... | abdullah0116 | Universalbox | 12 | 09-04-2009 21:52 |
