Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > Chinese Miracle & PinFinder
Old 01-03-2009, 06:51   #1 (permalink)
Member: 432364
Nktel 2800 can't calabrate touch screen
Hi
Infinity team
I have one china nktel 2800 with broken touch screen....Touch screen calabration suceessed with method -2 ....But still phone asking for calabrate....I also tried with formate but same....Here is readed eeprom n full flash plz check
http://rapidshare.com/files/17893451...57_V1_0_10.rar
Thx.
B.r.
Sunil.
Old 01-03-2009, 15:58   #2 (permalink)
Member: 148515
hello!
you must try one by one every single method of touchscreen calibration.
please repeat this and confirm that none of them worked for you
Old 01-05-2009, 11:58   #3 (permalink)
Member: 432364
hello!
I tried with all method....Only by method 2 i got successfull message....Other all method showing failed...Thats why i posted here....
Thx for reply
B.r
Sunil.
Old 01-05-2009, 21:00   #4 (permalink)
InfinityN's Avatar
Member: 720034
Hello,
Please, post here operation log so we can check it.
The Following User Says Thank You to InfinityN For This Useful Post:
Old 01-07-2009, 10:43   #5 (permalink)
Member: 432364
Originally Posted by InfinityN View Post
Hello,
==== log: [12/31/2008 4:47:55 PM] ====
COM35 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: "format ffs"
Boot...
19200 fixed
Connecting, wait...
Initializing[6225:8A03:8A00]...
CPU: MT6225
high speed boot enabled
chip: 0001:0603:000D
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 98004900000002:18E59F00000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
460800
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw1: M2800_PCB01_GPRS_MT6225_S00.M2800_ABROAD_TV0057_V1_0_10.BIN
ver. sw2: M2800_Abroad_TV0057_V1.0.10, 00000000
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading: eeprom[M2800_PCB01_GPRS_MT6225_S00.M2800_ABROAD_TV0057_V1_0_10.BIN]...
file saved: D:\All box\Infinity\Flash files\Chinese miracle\Nktel 2800\eeprom[M2800_PCB01_GPRS_MT6225_S00.M2800_ABROAD_TV0057_V1_0_10.BIN]_20081231-165002.B0E.bin
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
Write Done
Finalization...
formatting...
Finalization Done
Finished, time used: 179 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
==== log: [12/31/2008 4:51:24 PM] ====
Action: touchscreen calibration
Model: Autodetect 6205-6227 NOR
19200 autodetect
CPU: MT6225
Connecting, wait...
Phone detected, wait...
Hardware: MT6225,E03
Date: 2006.06.14
Version: 1.0
Version: M2800_Abroad_TV0057_V1.0.10
Version: LONGYU25_GEMINI_HW
detecting structure #2...
 4 5 11 done
67 byte(s) read
imei: 13579024681122
warning: current phone imei is incorrect !
It's need to repair imei for correct phone functionality !
connection Ok
detecting structure #5 (mode-2)...
 0 1 2 3 6 7 8 done
209 byte(s) read
writing data...
verification...
error: verification failed
Finished, time used: 29 sec
==== log: [12/31/2008 4:53:06 PM] ====
19200 autodetect
CPU: MT6225
Connecting, wait...
Date: 2006.06.14
Version: 1.0
 4 5 11 done
67 byte(s) read
connection Ok
detecting structure #5 (mode-3)...
 0 1 2 3 4 5 6 7 10 11 12 13 14 15 16 17error:
detection failed (16 tries)
What to do:
Try another calibration method, if still no luck:
1. make full flash backup for emergency case
2. make "format ffs"
3. Power-On phone
4. Power-Off phone by "Power" button (do NOT remove battery)
5. Repeat "Calibration" operation again
6. if still no luck read full flash and send to support with subject: touchscreen calibration failed
error: can't read required data
error: operation failed !
Finished, time used: 18 sec
==== log: [12/31/2008 4:54:24 PM] ====
19200 autodetect
CPU: MT6225
Connecting, wait...
Date: 2006.06.14
Version: 1.0
 4 5 11 done
67 byte(s) read
connection Ok
detecting structure #5 (mode-1)...
 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19error:
detection failed (20 tries)
What to do:
3. Power-On phone
Finished, time used: 92 sec
==== log: [12/31/2008 4:57:59 PM] ====
19200 autodetect
CPU: MT6225
Connecting, wait...
Date: 2006.06.14
Version: 1.0
 4 5 11 done
67 byte(s) read
connection Ok
detecting structure #5 (mode-4)...
What to do:
3. Power-On phone
Finished, time used: 15 sec
==== log: [12/31/2008 4:59:32 PM] ====
Action: "sp-unlock"
unlock method: standard
Boot...
19200 fixed
Connecting, wait...
CPU: MT6225
Boot Done
Initialize...
Initialize Done
Set baud...
460800
Set baud Done
detecting security area (code #2)...
security area (code #2) is absent
ffs chip: 00
detecting ffs structure pass 1...
detect standard fat location pass #1...
detect standard fat offset pass #1...
detect standard fat data...
fat layout detection complete
ffs element #1 detected ok
file saved: D:\Program Files\InfinityBox\ChineseMiracle\eeprom[M2800_PCB01_GPRS_MT6225_S00.M2800_ABROAD_TV0057_V1_0_10.BIN]_20081231-170101.B0E.bin
detection procedure, wait...
error: phone is not locked or unknown eeprom
Patch required data Fail
Finished, time used: 87 sec
==== log: [12/31/2008 5:03:33 PM] ====
19200 autodetect
CPU: MT6225
Connecting, wait...
Date: 2006.06.14
Version: 1.0
 4 5 11 done
67 byte(s) read
connection Ok
warning: wrong packet cs
 0warning: wrong packet cs
 1 4 5 6 7 8 9 10 11 14 15 16 17 18 19error:
What to do:
3. Power-On phone
Finished, time used: 31 sec
==== log: [12/31/2008 5:04:20 PM] ====
19200 autodetect
CPU: MT6225
Connecting, wait...
Date: 2006.06.14
Version: 1.0
 4 5 11 done
67 byte(s) read
connection Ok
What to do:
3. Power-On phone
Finished, time used: 86 sec
==== log: [12/31/2008 5:05:57 PM] ====
19200 autodetect
CPU: MT6225
Connecting, wait...
Date: 2006.06.14
Version: 1.0
 4 5 11 done
67 byte(s) read
connection Ok
 0 1 2 3 4 5 6 7 8 9 10 11 12 13 16 17 18 done
209 byte(s) read
writing data...
verification...
verification Ok
Finished, time used: 44 sec
==== log: [12/31/2008 5:07:53 PM] ====
19200 autodetect
CPU: MT6225
Connecting, wait...
Date: 2006.06.14
Version: 1.0
 4 5 11 done
67 byte(s) read
connection Ok
What to do:
3. Power-On phone
Finished, time used: 20 sec
==== log: [12/31/2008 5:09:15 PM] ====
19200 autodetect
CPU: MT6225
Connecting, wait...
Date: 2006.06.14
Version: 1.0
 4 5 11 done
67 byte(s) read
connection Ok
What to do:
3. Power-On phone
Finished, time used: 14 sec
==== log: [12/31/2008 5:09:37 PM] ====
19200 autodetect
CPU: MT6225
Connecting, wait...
Date: 2006.06.14
Version: 1.0
 4 5 11 done
67 byte(s) read
connection Ok
What to do:
3. Power-On phone
==== log opened: [12/31/2008 5:15:40 PM] ====
Application: D:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.exe
Loading data, wait...
[Infinity Box] v2.72
S/N: 1237:0112
Wait...
Done
==== log: [12/31/2008 5:16:09 PM] ====
module  v2.72
19200 autodetect
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
Connecting, wait...
Date: 2006.06.14
Version: 1.0
 4 5 11 done
67 byte(s) read
connection Ok
209 byte(s) read
writing data...
verification...
verification Ok
Finished, time used: 45 sec
Thx.
B.r.
Sunil.
Old 01-07-2009, 18:22   #6 (permalink)
InfinityN's Avatar
Member: 720034
Hello,
New ChineseMiracle update should be released tomorrow morning, pls wait new update and then try to make calibration again.
Nktel 2800 (MT6225) rebooting... bruno128 Chinese Models & Cloned Phones 5 09-29-2009 07:29
how to save my message from NKTEL 2800 zarifjan Chinese Models & Cloned Phones 0 06-28-2009 08:43
Can't calibrate touch screen on Alfatel H1 amol_sm Chinese Miracle & PinFinder 3 05-31-2009 22:04
Nktel 2800 pin out cnnmbc Chinese Miracle & PinFinder 1 02-14-2009 16:48
i750 can't calibrate touch screen..... aikonmani Samsung Hardware Repair Area 2 11-25-2008 16:45
Page generated in 0.30806 seconds with 11 queries
