04-27-2009, 04:52 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: MX-Key and me ...The Best
Member: 617692 Status: Offline Thanks Meter: 306 | nktel hangs problem Assalamo Alaikum I have a nktel c6000. After starts buttons does not works.is it software problem......?.... i have formated it with saf mode and complete mode and now downloading new files to full flash.... When I call to it, it recieves the call but all buttons do not work... I think it is hardware problem because if it is software problem and hangs, it does not recieve a call. pleasy any suggestion |
The Following User Says Thank You to farihabest For This Useful Post: |
04-27-2009, 05:57 | #3 (permalink) | |
No Life Poster Join Date: May 2006 Location: Sambrial (Sialkot)
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | Quote:
in your case mostly tuchscreen does not work .............you only need to disconnect tuchscreen connecn if not then need to repair keypad or change it | |
05-12-2009, 01:33 | #7 (permalink) |
No Life Poster Join Date: Oct 2005 Location: P A K I S T A N Age: 16
Member: 190344 Status: Offline Thanks Meter: 280 | yesterday i have an intresting case of 6300 china. problem was no key working . set after power on the set was auto off when showing inetwork. side volume keys were not depressed, they were ok checked by multimeter. the whole key pad was detached,not a single key was found fulty, the key pad area was clean, no sisg of water damaging power on key was ok from my point of view, 95% of keys stops working due to cpu.i and rest due to fulty key pad strip, or faulty key pad jack or due to shortage in the set or in the charging jack i rehot the cpu. now keys are working fine and restart problem is also gone. but alwyas check by formating.some time due to wrong flash file/ mismatching of flash file all keys may stop working. br hamid |
The Following User Says Thank You to biochemistali For This Useful Post: |
nktel hang and off | soy | Chinese Models & Cloned Phones | 4 | 01-06-2010 19:59 |
nktel A300 problem | goldenploto | Infinity-Box | 19 | 11-22-2009 02:41 |
china nktel a200 problem plz help | shakir hashmi | Infinity-Box | 5 | 05-26-2009 22:30 |
nktel A300 problem | goldenploto | Chinese Models & Cloned Phones | 0 | 03-18-2009 13:51 |
can anybody help nktel n77 problem? | debmobile | Infinity-Box | 4 | 03-17-2009 06:43 |
