05-01-2009, 08:54 | #1 (permalink) |
Freak Poster Join Date: Apr 2006
Member: 254086 Status: Offline Thanks Meter: 24 | nokia 1600 after formet ffs phone is dead now This the bck file of that phoneflash[TOP23_07A_PCB01_GPRS_MT6223P_S00.N1112_V5_53.BIN]_20090430-033411.B0M no1600 N This the eprron eeprom[TOP23_07A_PCB01_GPRS_MT6223P_S00.N1112_V5_53.BIN]_20090430-035622.B0Eno 1600 but when i m trying to restore that bck up its showing this type error This the log ==== log: [5/1/2009 12:21:21 AM] ==== COM8 [VCP0] selected module v2.73 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A04:8A00]... CPU: MT6223 high speed boot On chip: 0011:B7B3:000C boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #03 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 detect device identification#1... detection phase #1... error: wrong answer: C7 . detection phase #2... error: unexpected termination/freez: 00000000 warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... error: unexpected termination/freez: 00000000 warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00700000 error: no any expected answer error: no any expected answer : wrong answer after chip id request error: no any expected answer error: no any expected answer error: no any expected answer : wrong answer after chip cfi request error: no any expected answer error: no any expected answer : wrong answer after chip id request Can't detect eeprom/ffs area Do you want to use standard ffs address: 00700000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation operation terminated by user error: critical error#1 during ffs size detection error: can't detect eeprom/ffs address/size Check firmware integrity Done Check firmware content ... Check firmware content Fail Finished, time used: 203 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [5/1/2009 12:25:38 AM] ==== COM8 [VCP0] selected module v2.73 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Boot ... Press and HOLD Power button now ! error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 62 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [5/1/2009 12:27:00 AM] ==== COM8 [VCP0] selected module v2.73 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: erase flash chip Boot ... Press and HOLD Power button now ! error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 95 sec Remove/Install battery now ! so sir any solution pls |
nokia 6500c after flashing with new version shows nokia n thn blink nw phone is dead | saurabh_bhola | Universalbox | 4 | 08-07-2008 15:26 |
help...6280 error unlocking phone is dead now | lie_james | J.A.F. V-SPEC | 4 | 05-26-2008 02:44 |
Problem With W220, Phone Is Dead Now | chowdary | Infinity-Box | 1 | 04-29-2007 22:48 |
I flash R479 to a R47A phone, is Dead now..help | ckkckk | Motorola P2k | 7 | 08-31-2006 19:59 |
X600 Flashing Stops at 37% while flashing BIN File ,,, Phone is DEAD now | Aamir_Zia | SYSOL Platform | 7 | 12-18-2004 18:40 |
