Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > Chinese Miracle & PinFinder
Old 07-20-2007, 10:59   #1 (permalink)
.::Zafar Communication::.'s Avatar
Member: 71045
nokia 6300 copy is in problem
i have found three hand set which was in problem
problem in same in three phone power on and after sometime power off or hang when i connect with the software and try to read the eeprom following error
Action: read eeprom
Boot...
baud autodetection active
19200
Connecting, wait...
Initializing[6226:8A02:8A01]...
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: 98004900000002:2BEA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
Initialize Done
Set baud...
921600
Set baud Done
Check space...
device parameters autodetection in progress..
total flash region size: 01000000
detect device identification, method #1...
detection phase #1...
detect device parameters finished
memory structure: 2nd [enhanced] (or higher) generation
warning: make backup before any action !
identification detection finished
device-id: 195839F8
protocol version: 04
version sw1: RATECH26_06A_PCB01_GPRS_MT6226_S01.R6300_03_0_2T01 S0605.BIN
version sw2: R6300_03_0.2T01S0605
ffs offset/size: 00E00000/00200000
detecting eeprom area in 1 chip(s)...
checking area[00000000]: 00000000-00FFFFFF...
Can't detect eeprom area
Do you want to use standard eeprom address[00E00000] ?
operation terminated by user
error: critical error#1 during eeprom size detection
error: can't detect eeprom address/size
error: autodetection failed
Finished, time used: 118 sec
Remove/Install battery now !
firs time i do no then i again term i use standered ok after that does not power on
then i got the working phone i read the eeprom and full backup and try to write in the hand set
while writing when i select the file following message appear for security reasong make rpl becaue after flashing may be your hand set does not power on read the document
2 step
i read the manal try
try to read detail information ask rpl software give following informtio give
COM8 [VCP2] selected
Device: Autodetect
Checking data, wait...
advanced flash detection active
Action: read/check detailed information
Boot...
19200
Connecting, wait...
high speed disabled
Boot Done
Initialize...
Initialize Done
Set baud...
921600
Set baud Done
Check space...
warning: probably identification data damaged, power-on problem possible
error: rpl file not found: F:\InfinityBox\ChineseMiracle\id.195839F8._RATECH2 6_06A_PCB01_GPRS_MT6226_S01.R6300_03_0_2T01S0605.B IN_51C76837_.rpl
warning: unknown identification structure: RATECH26_06A_PCB01_GPRS_MT6226_S01.R6300_03_0_2T01 S0605.BIN_51C76837
error: ASK file can't be created, user action required:
- find good working phone with the same firmware[RATECH26_06A_PCB01_GPRS_MT6226_S01.R6300_03_0_2T01 S0605.BIN]
- make "Read detailed information, ask/rpl" operation
- send "backup_system_log_..." file to support
- make "Read Full Flash" operation
- send flash backup file(s) to support
- include in your e-mail full text from phone back label (phone name etc.)
- be little bit patient and wait update
device-id: 195839F8
standard eeprom address selected by user
detecting eeprom size...
eeprom size: 00200000
eeprom chip: 00
eeprom area detected[00000000]: 00E00000-00FFFFFF
detection phase #3...
...........error: unexpected termination/freez: 002C0000
done
detecting structure pass 1...
detect standard location pass #1...
detect extended location pass #1...
detect standard offset pass #1...
detect standard data...
can't detect standard data
eeprom element #1 detection failed
Finished, time used: 136 sec
then i try to flash with working hand set back up still no sucess hand set does not power on
please recomend what is going wrong 3 handset is in hand
thanks & regards
Zafar Janjua
Old 07-20-2007, 16:01   #2 (permalink)
Member: 148515
hello!
infinityhelp@yahoo.com.hk
Old 07-21-2007, 09:24   #3 (permalink)
Member: 71045
hello!
sir
pleae check i send the mail to fullfill your requirment
thanks & regards
Zafar Janjua
Old 07-22-2007, 10:12   #4 (permalink)
Member: 148515
hello!
will process them ASAP
mtk nokia 6300 copy orginal co'nt connect yarra SpiderMan 6 05-27-2009 17:18
Nokia 6300 Copy Jack Like Moto V3 maplegsm Chinese Miracle & PinFinder 3 10-26-2007 15:23
Nokia 6600 is in problem .::Zafar Communication::. Twisterflasher 3 07-06-2005 08:55
Nokia 9210 is in problem .::Zafar Communication::. Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 02-01-2005 05:53
vBulletin Optimisation provided by vB Optimise v2.5.2 (Lite) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. ()
Page generated in 0.19977 seconds with 8 queries
