10-31-2010, 19:26 | #2 (permalink) |
Banned Join Date: Sep 2009 Location: PM P L Z Age: 36
Member: 1116719 Status: Offline Thanks Meter: 542 | i found on support area flashfiles/ChineseMiracle/_MT6225/eeprom/NEOTEL25_08B_GEMINI_PCB01_GPRS_MT6225_S00.NOKIA_88 00_CARBON_ART_ffs_01.B0E.bin but is siz............ 37.kb |
10-31-2010, 21:03 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! this is eeprom file. to flash your phone correctly- please make "read detailed information" and post here log. we will advice correct flash file |
11-01-2010, 08:31 | #5 (permalink) |
Member: 1116719 Status: Offline Thanks Meter: 542 | ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info ver: 05 sw version: NEOTEL25_08B_GEMINI_PCB01_GPRS_MT6225_S00.NOKIA_88 00_CARBON_ART.BIN project-id: Nokia_8800_Carbon_Art, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: NEOTEL25_08B_GEMINI_PCB01_GPRS_MT6225_S00.NOKIA_88 00_CARBON_ART__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\NEOTEL25_08B_GEMI NI_PCB01_GPRS_MT6225_S00.NOKIA_8800_CARBON_ART__ff s_20101031-231436.B0E.bin flash: EC257E25082501:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC257E25082501:18E59F00000000 Finalization Done Finished, time used: 4 min 51 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
11-01-2010, 16:29 | #6 (permalink) |
Member: 1116719 Status: Offline Thanks Meter: 542 | after flashing only vibrat.. HELP COM11 [VCP0] selected module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware NEOTEL25_08B_GEMINI_PCB01_GPRS_MT6225_S00.NOKIA_88 00_CARBON_ART_16m_En_Ru_Fr_De_Ml_Id_Th_Vn_Tr_Farsi _Ar.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:3103:0007 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is absent rom info detection finished rom info ver: 05 sw version: NEOTEL25_08B_GEMINI_PCB01_GPRS_MT6225_S00.NOKIA_88 00_CARBON_ART.BIN project-id: Nokia_8800_Carbon_Art, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (05) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area [00000000]: 00080000-00FFFFFF... ffs/eeprom found near: 00B80000 Detected ffs/eeprom address is non-standard: 00B80000 Posible reasons: 1. ffs/eeprom is Ok but address is non-standard 2. ffs/eeprom is damaged and can't be detected 3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make full flash backup for emergency case 3. repeat required operation Are you sure that detected ffs/eeprom address is correct ? autodetected ffs/eeprom address confirmed by user: 00B80000 detecting ffs/eeprom size... ffs/eeprom size: 00480000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00B80000-00FFFFFF firmware area: 00000000-00B7FFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: NEOTEL25_08B_GEMINI_PCB01_GPRS_MT6225_S00.NOKIA_88 00_CARBON_ART__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\NEOTEL25_08B_GEMI NI_PCB01_GPRS_MT6225_S00.NOKIA_8800_CARBON_ART__ff s_20101101-065754.B0E.bin flash: EC257E25082501:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... done detecting startup code area #2... startup code area #2 is absent Area: Firmware flash: EC257E25082501:18E59F00000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 35 min 13 sec Remove/Install battery now ! |
11-02-2010, 17:59 | #8 (permalink) | |
Member: 1116719 Status: Offline Thanks Meter: 542 | Quote:
This time phone dead .only vibrat plz tel me flash file name give me flaah file ... how to on this mobile why r u anwer after 24 hr ? why ? need your id back up auto http://rapidshare.com/files/42851957...065754.B0E.bin Last edited by >>.123.<<; 11-02-2010 at 18:04. | |
11-03-2010, 17:22 | #11 (permalink) |
Member: 1116719 Status: Offline Thanks Meter: 542 | 10-31-10 to 11-04-10 4days ago you have solution InfinityHELP ? yes or no 4day how is wait your anwer u r oline after 24hr why ? u give me flash file ? |
11-04-2010, 10:03 | #12 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | 1. read this: http://forum.gsmhosting.com/vbb/f296...-days-1132561/ 2. flash phone with good flash file. You can download a lot of flash files from support area. If you can not find flash file in support area you must read flash from the same good phone and flash your dead phone. Thread with YOUR LIE is closed. We do not want to continue thread where users lie about "4 days" etc. Please, be honest in future !!! |
