05-26-2009, 09:03 | #1 (permalink) |
Insane Poster Join Date: Apr 2009
Member: 1012502 Status: Offline Thanks Meter: 2 | Nokia 8800 ARTE RM, D2009, NOKIA 5800 Express I cant find pinoout for these models: nokia 8800 ARTE - china phone clone nokia 5800 express music-china phone clone D2009 - mini iphone 16GB version, here i cant remove cover from battery (probably name of this model is D188 too) something like KA08 for example for nokia arte I can use cable L05B, but in menu for infinity box software, is no L05B cable, how can I set in this software L05B cable??? |
05-26-2009, 09:50 | #3 (permalink) |
Member: 1012502 Status: Offline Thanks Meter: 2 | version Hi, I have newest version of pinfinder, btw which version is newest? I have problem with this phone: http://www.focalprice.com/2009_Tri_b...344P_8665.html Do you know pinout for this phone??? Any idea of pinout? these phone has name 2009 ??? |
05-26-2009, 09:52 | #4 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,421 | here is latest ver http://forum.gsmhosting.com/vbb/showthread.php?t=748318 and tell me phone connector type !! how many pin mobile have like 2x5 / 1x5 etc Br Faisal_Computer |
05-26-2009, 09:59 | #5 (permalink) |
Member: 1012502 Status: Offline Thanks Meter: 2 | Hi, this mobile has 12 pins and from pinfinder set of cables is suitable only L12C cable SO it has 12 pins 2x6 pin I cant connect pinfinder to this phone, because, I cant remove battery (it is like original iphone cover)... See pictures. http://www.focalprice.com/2009_Tri_b...344P_8665.html |
05-26-2009, 10:11 | #7 (permalink) |
Member: 1012502 Status: Offline Thanks Meter: 2 | OK, I can open it... But for example, NOKIA 8800 ARTE, there is no problem with connection phone to pinfinder, but I cant find correct pinout... it is cable L05B, I have this cable, this one is suitable, but in software is no L05B, can it makes problems with finding RX TX? It has 5 PINS but cable L5A is something else.... |
05-27-2009, 09:15 | #11 (permalink) |
Member: 1012502 Status: Offline Thanks Meter: 2 | ok, so nokia arte 8800 is PCB, no chance to use INFINITY PIN FINDER, very bad!!! But what next? I see 13 test points in PCB. I have "3 OPEN WIRES" by infinity pin finder, which one I need to use? 4 wires, 8 wires, 12 wires?? OK, must I solder all 13 test points with this cable, or need I solder only test points RX, TX with OPEN cable??? (understand me? must i make 12 soldering, or 2 solderings are enough???) How can I measure voltage for 1 -13 test point? where is GND on this phone??? |
05-27-2009, 22:18 | #12 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! if you want find test points automaticly- you must solder all test points to open cable. if you want to measure voltage- then you must take out wire from negative battery terminal and last: pinout for this phone is available in our pinout collection \InfinityBox\pinout also here is very understandable picture, which explanes how to search test points: http://forum.gsmhosting.com/vbb/show...95&postcount=6 Last edited by InfinityHelp; 05-27-2009 at 22:50. |
05-28-2009, 08:52 | #13 (permalink) |
Member: 1012502 Status: Offline Thanks Meter: 2 | ok, and once question more: What does it means exactly this: "...then you must take out wire from negative battery terminal" You said that battery must be attached, or not??? How can I attach battery without "negative battery terminal"?? Or I dont understand exactly, do you have another picture??? |
8800 ARTE RM-233 schematic | chimeto | Nokia Hardware & Hardware Repair | 2 | 06-10-2015 21:08 |
Nokia 8800 arte RM-233 Imei invalid after usb flash | .::MD_AKTER::. | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 07-09-2010 03:23 |
Nokia 8800 Arte false file RM-233-9.41V15 version @)--- | jahednn | Nokia Base Band 5 ( BB-5 ) | 0 | 11-05-2009 15:21 |
Nokia 8800 Arte RM-233 Contact Service... | abdullah0116 | Universalbox | 12 | 09-04-2009 21:52 |
