02-01-2011, 13:45 | #1 (permalink) |
Freak Poster Join Date: Oct 2006
Member: 366714 Status: Offline Thanks Meter: 21 | Nokia 8800 (Chinees) no power ???? I flash Nokia 8800 slide phone, still it is no power. Here is the log... Please help COM57 [VCP0] selected module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware CM_Nokia-8800i_HT8800 HT8800.0601.30W_2006-09-25_16m_En_Ru_Th_Cn_Cn_w_eeprom.B0M.bin skip: Customization/Language Pack skip: Customization write: Eeprom/ffs H526_05C_PCB01_GPRS_MT6226_S01.P02_SP_SSD_NB0_1_2_ 0TMC1_26B__ffs_20110201-160244.B0E.bin ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031EC1:9252 status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: H526_05C_PCB01_GPRS_MT6226_S01.P02_SP_SSD_NB0_1_2_ 0TMC1_26B.BIN project-id: P02_SP_SSD_NB0_1.2.0TMC1_26B, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: H526_05C_PCB01_GPRS_MT6226_S01.P02_SP_SSD_NB0_1_2_ 0TMC1_26B__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\8800\H526_05C_PCB 01_GPRS_MT6226_S01.P02_SP_SSD_NB0_1_2_0TMC1_26B__f fs_20110201-172906.B0E.bin flash: 01227E22202200:29EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent detecting startup code area #2... startup code area #2 is absent Area: Firmware flash: 01227E22202200:29EA0000000000 Write: Firmware Area: Eeprom/ffs flash: 01227E22202200:29EA0000000000 Write: Eeprom/ffs usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 41 min 4 sec Remove/Install battery now ! |
02-01-2011, 21:29 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,531 | hello! you have flashed your phone with wrong flash file you have to use following firmware for flashing: H526_05C_PCB01_GPRS_MT6226_S01.P02_SP_SSD_NB0_1_2_ 0TMC1_26B |
