11-30-2008, 11:04 | #1 (permalink) |
Registered User Join Date: Mar 2007 Location: Bandung, Indonesia
Member: 461468 Status: Offline Thanks Meter: 139 | Nokia N73/H73 made in Malaysia DEAD after flash used support area files We have a problem with phone restart used simcard just nokia greetings and back again to restart, tried to flash the phone from support area files "CM_CECT-H73_YW.05B.W06.04.1.2_Y300Z_HW ...... Phone was become dead. Reflash used backup files is okay but do not solve the problem. And we checked CPU is MT6217, herewith log phone info: Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6217, E00 Hardware version: YW6217_HW Software version: YW6217.Y300Z_HX_1.5" Software date: 2004.07.02 Barcode: MT012345678901234567 imei: 135790246811220 Finished, time used: 32 sec Power off phone now ! Did you have any solution for this? Herewith backup files flash n eeprom. http://rapidshare.com/files/16880240...3_H73.rar.html Regards, ABELL Cellular, Bandung-Indonesia YM: [email protected] |
11-30-2008, 13:12 | #3 (permalink) |
Member: 461468 Status: Offline Thanks Meter: 139 | Hello, We have formated ffs with "complete" mode, result the same no changed sirs. The phone still restart on welcome/greetings nokia prictures. Regards, |
12-02-2008, 03:27 | #8 (permalink) |
Member: 461468 Status: Offline Thanks Meter: 139 | Hello Infinity, Would you please to deleted "welcome greetings/pictures of hand greetings nokia" of flash files backup. And please upload to your support. May be the soultion make the fone okay. Thks & Rgds, |
12-02-2008, 12:08 | #10 (permalink) | |
To be honest I did not understand well what you talk about. Please, explain more. | |
12-02-2008, 13:54 | #11 (permalink) |
Freak Poster Join Date: May 2005 Location: Tiaret Age: 39
Member: 145088 Status: Offline Thanks Meter: 13 | It seams to be hardware problem because even the keypad don't work.....!!!! open the phone and check the PCB if it is water damaged, clean it and try to reformat ffs And post result PS : other thing i need the pinout of this phone |
12-02-2008, 14:50 | #12 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: Rajasthan (Kota)
Member: 265606 Status: Offline Sonork: 1603113 Thanks Meter: 460 | Quote:
what a r u saying ................? plz explain it and details about it completly | |
12-03-2008, 05:15 | #13 (permalink) | |
Member: 461468 Status: Offline Thanks Meter: 139 | Quote:
Hello, This is a pinout but we did not find on infinifty cable set for connector. Rgds, | |
12-03-2008, 05:28 | #14 (permalink) | |
I mean can u make the flash files from backup without "Welcome/greetings note/pictures when the phone power on". The phone problems restarting on greeting/welcome note/pictures Nokia hands when power switch on. the problem not water damaged or etc. I assume this is bad software due I was check the hardware is okay n I was trying with new version of chinese miracle soft ver 2.70 Thks & Rgds, | |
12-03-2008, 19:14 | #15 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, It's first time when we have this kind of request. For sure it will be no pictures deleted from firmware due to it can not helps to solve any problem. If you think that it's software problem you can try to flash phone with other firmware with similar firmware version. But I strongly suggest you to double check phone hardware, f.e. power controller etc. |
blue 151 x dead after flashing from download area | akhil_bbsr | Infinity-Box | 6 | 04-02-2008 12:54 |
1110i rh 93 made in india dead after unlock | dindou78 | MT-BOX | 6 | 02-29-2008 06:27 |
RH-93 1110i made in india dead after unlock | bilousoft | MT-BOX | 4 | 12-24-2007 07:15 |
A200 Dead After Flash using manager phone | X-Treme | VLSI, Conexant, Skyworks and Old Models | 3 | 10-25-2002 21:29 |
