Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > Chinese Miracle & PinFinder
Old 07-27-2008, 15:26   #1 (permalink)
tuli's Avatar
Member: 511615
nokia n82 tv bluetooth (k808) pinout help
hi to every one . can anyone help for pinout of Nokia N82 Tv bluetooth ?
its so strange because i try to connect it with the cect t689 cable and give me this error
COM4 [VCP0] selected
Device: Autodetect 6228 NAND
Checking data, wait...
Action: read NAND flash
Boot...
19200 fixed
Connecting, wait...
error: boot phase#1 failed
Release Power button now !
Boot Fail
Finished, time used: 10 sec
Remove/Install battery now !
help me please ! thanks in advance
Old 07-27-2008, 15:29   #2 (permalink)
tuli's Avatar
Member: 511615
the problem of this phone is white display only and power off itself
Old 07-27-2008, 21:46   #3 (permalink)
Member: 148515
hello!
wrong pinout is used
Old 07-28-2008, 07:07   #4 (permalink)
tuli's Avatar
Member: 511615
thanks infinity team but what pinout can i use for this phone? can you help me to give the pinout ?
thanks in advance
Old 07-28-2008, 10:05   #5 (permalink)
Member: 148515
hello!
first of all make sure which MCU it is based?
Old 07-28-2008, 11:19   #6 (permalink)
tuli's Avatar
Member: 511615
how can find what mcu it's based?
it is double sim card, double memory cards and tv
pleas help me
Old 07-28-2008, 13:43   #7 (permalink)
Member: 583680
pleas help me
Seems You have Spreadtrum based phone
I have had model Ktech K808,dual sim,bt,TV with Spreadtrum CPU.
Pinout found with pin-finder
RX-12,TX-13
In pin-finder software select SPD:Spreadtrum and try to find pinout
Old 07-28-2008, 13:49   #8 (permalink)
Member: 583680
The Following User Says Thank You to ezzis For This Useful Post:
Old 07-28-2008, 17:00   #9 (permalink)
tuli's Avatar
Member: 511615
ezzis can you tell me hot to enter it in boot mode ? please help me
thanks
Old 07-28-2008, 17:52   #10 (permalink)
Member: 583680
thanks
Today customer brought to me this phone again -problem "emergency calls only".I will try some tests later this night and will report results.
Old 07-28-2008, 21:40   #11 (permalink)
Member: 771937
Sonork: 100.1605717
Originally Posted by ezzis View Post
today Customer Brought To Me This Phone Again -problem "emergency Calls Only".i Will Try Some Tests Later This Night And Will Report Results.
If Your Phone Is Mt62xx Base, Try This Cheak This Pin.
Old 07-30-2008, 09:18   #12 (permalink)
tuli's Avatar
Member: 511615
ok have a good work ezzis
Old 07-30-2008, 09:44   #13 (permalink)
Member: 583680
I tried to do something with other spreadtrum software but with no success.Seems that the real pinout is on small testpoints under battery.See picture below.Voltage on these points are 0.00v and in range 2.79-2.83v exactly.I have no free time to test these points, but i am sure that pinout is there.
If You have time-you can try this.
good luck and report any results
Old 07-30-2008, 10:08   #14 (permalink)
Member: 583680
mr. Tuli
You can try this method
http://forum./show...43&postcount=1
Old 07-30-2008, 11:10   #15 (permalink)
tuli's Avatar
Member: 511615
ok i will test it when will have free time . thanks for your help was usefull.
have a nice day
plz help me nokia n82 unable to perform bluetooth operation momen_osman Nokia Base Band 5 ( BB-5 ) 7 04-30-2010 11:44
nokia n82 keypad pannel way need.......help fuadgsm Nokia Hardware & Hardware-Repair Area 0 05-25-2009 07:46
pinout for TV BLUEtOOTH FM phone PILONCILLO Chinese Models & Cloned Phones 3 12-31-2008 22:37
nokia n100 tv mobile cpu2 pinout please cepclub Chinese Miracle & PinFinder 3 08-08-2008 22:01
Nokia N82 Bluetooth pinout hicvb7 Chinese Miracle & PinFinder 6 04-02-2008 10:39
Page generated in 0.37328 seconds with 12 queries
