08-05-2016, 09:52 | #1 (permalink) |
Freak Poster Join Date: Feb 2006 Location: suadt.com
Member: 235782 Status: Offline Thanks Meter: 82 | not read firmware MTK - LOCKED with SPRELOADER Chinese Miracle II [MTK module] v 1.51 Operation : Format FileSystem [ v1.51 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : DONE Boot Error! Operation Failed Elapsed: 00:00:11 Reconnect Power/Cable! Operation : Fix DL Errors [ v1.51 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : DONE Boot Error! Operation Failed Elapsed: 00:00:09 Reconnect Power/Cable! Operation : Check / Read Info [ v1.51 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : DONE Boot Error! Operation Failed Elapsed: 00:00:06 Reconnect Power/Cable! Operation : Read Flash [ v1.51 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : DONE Boot Error! Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! please help me |
08-06-2016, 07:31 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Make Boot unlock procedure. In CM2 - Security, FastBoot tol - unlock. |
08-07-2016, 11:36 | #3 (permalink) |
Member: 235782 Status: Offline Thanks Meter: 82 | Operation : Read Flash [ v1.54 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : BROM DRAM configured from IDB! Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , 2a4GB [eMMC] : FLASH_CID : 90014A484247346132A40E96E9085397 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0x68D77D6DE362C2650608BB7C21B57807 INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : FULL-SPEED Boot Ok! Reading Flash Content now ... USBDL : Error init HSUSB!!! Operation Failed Elapsed: 00:00:24 Reconnect Power/Cable! |
08-25-2016, 06:14 | #5 (permalink) |
Freak Poster Join Date: Aug 2005 Location: tamil nadu Age: 38
Member: 170244 Status: Offline Thanks Meter: 418 | Operation : Clear UserLocks [Pin/Pwd/Pattern/FVLock/GoogleAcc] [ v1.54 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 48 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x07000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with AUTH Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : DONE Boot Error! Operation Failed Elapsed: 00:00:05 Reconnect Power/Cable! Operation : FastBoot : Unlock BootLoader [ v1.54 ] Power Off Phone , re-connect battery , Insert USB cable! Wait for phone... Phone found! [ 47 ] Sync... Protocol : 0.5 Device : WT6755_66_SZ_L Storage : eMMC BootLoader : Locked Warranty : Not tampered ( Under Warranty ) Secure : Enabled ExtraStat : FB Load Supported! Boot Unlock/Relock init failed! Operation NOT SUPPORTED! Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! |
08-25-2016, 06:24 | #6 (permalink) | |
No Life Poster Join Date: Mar 2012 Location: India
Member: 1728736 Status: Offline Sonork: 100.1615042 Thanks Meter: 1,098 | Quote:
then try | |
