10-13-2010, 07:04 | #1 (permalink) |
Temporary banned !! Join Date: Dec 2008 Location: On To Hot
Member: 935605 Status: Offline Sonork: 100.1601177 Thanks Meter: 78 | pinfinder problem Example with same phone First time detect get rx 1 tx 3 Second rx 7 tx 9 Third rx 7 tx 9 When use miracle chinese module the correct combination is rx 7 tx 9. My question is why must 2-3 times detect ? Or is there a trick so we can get correct rx tx with just 1 time detect ? |
10-20-2010, 10:35 | #7 (permalink) | |
Member: 935605 Status: Offline Sonork: 100.1601177 Thanks Meter: 78 | Quote:
there cable rj45 and serial cable with the package. if you connect rj45 you must connect serial cable with female label in that cable there's 2 cable black and red, this for power to detect pinout phone don't use battery or power supply. connect this cable, red to + phone, black to - phone. chose cable type and cpu type, use SLOW method and press detect don't forget to press power button when program give warning then press ok on the message in computer. if right rx and tx on program increase until it find the right rx and tx if you connect serial use one with female label then chose your pin like e107 or else. connect cable red and black and procedure same as above to test use good phone, good luck | |
10-20-2010, 14:19 | #9 (permalink) |
Member: 935605 Status: Offline Sonork: 100.1601177 Thanks Meter: 78 | hello bro read this may can help you forum.gsmhosting.com/vbb/f296/how-use-pinfinder-sagem-lg-se-motorola-pantech-fly-o2-zte-etc-526956/ |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
6110 5.47 sw unlock problem | gsms | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-1999 19:43 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
