01-25-2012, 13:18 | #11 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! measure by multimeter where is tx/rx take any iphone cable, pull out pins and set them to correct place. solder cable to this pins- and your cable is ready |
02-22-2013, 14:31 | #12 (permalink) |
No Life Poster Join Date: Aug 2005
Member: 175945 Status: Offline Sonork: ziiyyaad Thanks Meter: 704 | software version: 1.28 platform: MT: MT62xx (autodetect) MT6205-6253 cable type: 1x24 (L24A) mode: Slow searching adapter at COM115 (115200)... too many retries (4) adapter found, version: 2000 Loading platforms configuration... Initializing platforms... Press and HOLD phone Power button now ! pins: 24, plain power/activation cycles: 1/7 power-off delay: 20 start Rx/Tx: 1/1 detecting pins... warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) warning: command confirmation absent too many retries (4) 19200 fixed double checking pin... CPU: MT6235 done result: Rx:19 Tx:17 time required: 237 sec Trying to Power-On... Power is On Power is On |
02-22-2013, 14:32 | #13 (permalink) |
Member: 175945 Status: Offline Sonork: ziiyyaad Thanks Meter: 704 | COM115 [VCP0] selected module v4.13 Device: _Autodetect MT6228-6268 NAND Checking data, wait... Action: read/check information interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8C00:8A00 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0006]: 00EC:00A100000015 [SAMSUNG] K9F1G08Q0M chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: absent done Set baudrate (115200)... done interesting cpu type found: 6235:8C00:8A00 ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 05000000/03000000 firmware size: 80Mb ffs size: 48Mb detect sec ro... detect custom parameters... detect project-id... project-id: F6A_CLD_IV_SA1G256_10A_MSFWRC_200W_V3-2_V008 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... |
02-22-2013, 14:33 | #14 (permalink) |
Member: 175945 Status: Offline Sonork: ziiyyaad Thanks Meter: 704 | COM115 [VCP0] selected module v4.13 Device: _Autodetect MT6228-6268 NAND Checking data, wait... Action: read/check information interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8C00:8A00 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0006]: 00EC:00A100000015 [SAMSUNG] K9F1G08Q0M chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: absent done Set baudrate (115200)... done interesting cpu type found: 6235:8C00:8A00 ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 05000000/03000000 firmware size: 80Mb ffs size: 48Mb detect sec ro... detect custom parameters... detect project-id... project-id: F6A_CLD_IV_SA1G256_10A_MSFWRC_200W_V3-2_V008 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... incorrect ext bootloader signature: 10B500F0 bootloader version: _BOOTLOADER_F6A_CLD_IV_SA1G256_10A_MSFWRC_200W_V3-2_V008.bin nfi area detection (3 cores) finished: Ok warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: NEOTEL35_10A_PCB01_GPRS_MT6235B_S01.F6A_CLD_IV_SA1 G256_10A_MSFWRC_200W_V3-2_V008.BIN_FLNK511F57ACC_B075 project-id: F6A_CLD_IV_SA1G256_10A_MSFWRC_200W_V3-2_V008, 00000000 code offset: 00000000 rom info structure: [standard] type (07) TCL-ID is absent ===> done ==================== New firmware found (v.4.13, database date: 12.06.2012): NEOTEL35_10A_PCB01_GPRS_MT6235B_S01.F6A_CLD_IV_SA1 G256_10A_MSFWRC_200W_V3-2_V008.BIN_FLNK511F57ACC_B075 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare ? Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== Disconnect... done Finished, time used: 3 min 20 sec Remove/Install battery now ! |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
Service Provider Lock 1-4 ? | StompSC | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-27-2012 11:00 |
All 4 locks on 6110 | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 04-19-2010 02:44 |
£2,000 for 5110/6110 unlock software 1 2 3 4 | Dean O'Grady | Wanted Products | 14 | 03-19-2005 10:52 |
I CAN UNLOCK 1,2,3,4 FOR ANY PHONE £40 (1+) -- £30 (20+) | andrew bennett | Main Sales Section | 1 | 07-26-1999 19:33 |
