Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > Chinese Miracle & PinFinder
Old 01-25-2008, 17:35   #1 (permalink)
Member: 452524
Post Pinout for Enmac MQ8200 & MQ7200
Hey mates!
Wonder if any one of you mates happen to know the pinout for Enmac MQ8200 & MQ7200? I have found this Infinity Flash : MQ-8200_UNITONE26_06A_PCB01_GPRS_MT6226_S01.ENMAC_MQ8 200_ENTOUCH_M6BZ1X2_V01_16m_En_Cn_Ar_w_eeprom.B0M. bin
MQ8200:
MQ7200:
Thanks for your time & efforts!
Old 01-27-2008, 00:48   #2 (permalink)
Member: 56090
I have already posted repair flash for Enmac MQ8200 Artouch ,pinouts are near sim card reader and also printed
Salam
Old 01-27-2008, 15:29   #3 (permalink)
Member: 452524
Thanks, abdoune!
Do you happen to know the pinout order in the connector. I could not trace the printed pinout tags to the pins on the connector. It would be a pain in the (__(__) to solder and desolder whenever there's a mobile to repair.
Appreciate your time & efforts.
YoursForever
Old 01-27-2008, 19:01   #4 (permalink)
Member: 148515
hello!
no need to trace, just use multimeter to check connection between test point and connector pins.
just keep in mind, sometimes there is small resistor between them.
so dont look for resistance 0 ohm, maybe will be little resitance, i met smthng like 475 ohm or similar
Pinout for Enmac MQ8200 vive01 Chinese Miracle & PinFinder 1 03-13-2008 10:19
Pinout for Enmac MQ8200 & MQ7200 YoursForever Chinese Cocktail 3 01-17-2008 18:01
need pinouts for "3d Sound & Fm" mobile brain00000 Chinese Miracle & PinFinder 0 11-02-2007 08:56
need pinouts for nokia 6620 & 6670 monolito Nokia Hardware & Hardware-Repair Area 1 01-31-2007 14:27
Page generated in 0.74737 seconds with 11 queries
