Old 02-25-2009, 18:43   #1 (permalink)
3lsheikh's Avatar
Member: 521296
Sonork: 100.1574136
Thanks Meter: 21
Pinout For J~max j-95
i need Pinout For J~max j-95
Thanks
Old 02-26-2009, 22:38   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
please post connector type.
are you sure that this is mt62xx MCU based phone?
tip: you can check this by typing *#0044# and pressing green (send) button.
if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software
Old 02-28-2009, 20:11   #3 (permalink)
3lsheikh's Avatar
Member: 521296
Sonork: 100.1574136
Thanks Meter: 21
Connector type 1x5
like micro usb (new nokia & new motorola)
yes its mtk based phone (MT6225A 0839-bgtl ctg0c999)
thank you for replay
Old 02-28-2009, 21:02   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Did you tried to open phone and check Rx/Tx test points at phone PCB ?
Old 02-28-2009, 22:13   #5 (permalink)
3lsheikh's Avatar
Member: 521296
Sonork: 100.1574136
Thanks Meter: 21
yes and not found..................
i make cable for pinfinder and did not found pin out
Old 02-28-2009, 23:19   #6 (permalink)
Member: 148515
hello!
last thing to try is following:
attach battery power to phone terminals and next measure voltages on all available test points and system connector pins.
as soon as you see 2,7-2,9 volts voltage- those pins are tx/rx
Old 02-28-2009, 23:26   #7 (permalink)
3lsheikh's Avatar
Member: 521296
Sonork: 100.1574136
Thanks Meter: 21
Thank You I Found PinOut
This Is Flash File ..
http://www.4shared.com/file/90046629...000146B0M.html
I Will Updat Flash File To Your e-mail
File Type: txt PinFinder Log.txt (998 Bytes, 53 views)
The Following 2 Users Say Thank You to 3lsheikh For This Useful Post:
Old 03-01-2009, 09:04   #8 (permalink)
Member: 130995
Hello,
Thanks a lot, files downloaded.
Old 05-23-2009, 11:52   #9 (permalink)
Member: 4600
Thanks Meter: 79
Please explain tx, rx .
thx.
Old 05-27-2009, 00:57   #10 (permalink)
sbata-team's Avatar
Member: 909860
Sonork: +212600693045
Thanks Meter: 120
thx.
plz dear more explain for this pinout
Old 05-27-2009, 17:53   #11 (permalink)
3lsheikh's Avatar
Member: 521296
Sonork: 100.1574136
Thanks Meter: 21
Or replace tx&rx sorry the phone not in my hand post result
Old 07-07-2009, 21:53   #12 (permalink)
aslam870's Avatar
Member: 383033
Sonork: 100.1580642
Thanks Meter: 441
Question
We really need more specific description of connection mode.
Where we need to connect Rx and Tx cables????????
Because this photo is something dificult to understand.
Best Regards..........aslam870
Old 07-08-2009, 20:30   #13 (permalink)
Member: 148515
hello!
connect blue and red wire to pins 2,3 of RJ45
black, GND pin, connect to pin 8 of RJ45
if you cant get connection- swap Tx/Rx wires with places
Old 07-08-2009, 22:02   #14 (permalink)
aslam870's Avatar
Member: 383033
Sonork: 100.1580642
Thanks Meter: 441
Smile Finally jmax j95 pinout
Finally here is an image with the correct pinout for JMax J95 (Working 100%) more easy to understand. Infinity Support, you can use this image without problems to update pinout data base.
Also received a message from Chinese Miracle Soft, something about a New Firmware Version detected. I copy the firmware and eeprom, maybe in a few days I upload both and send you the link for dowload.
Thanks to elsheikh, I used his photo like a guide.
With best regards................aslam870
The Following 3 Users Say Thank You to aslam870 For This Useful Post:
Old 07-12-2009, 18:49   #15 (permalink)
aslam870's Avatar
Member: 383033
Sonork: 100.1580642
Thanks Meter: 441
Infinity Team here you are the Magaupload Link with Flash and Eeprom of new version of J Max J95
http://www.megaupload.com/?d=PO92YTQJ
With best regards..............aslam870
Pinouts for Wi-Fi Mobile C5000 Stoyan Infinity-Box 3 04-01-2010 06:06
unlock code for motorola i 95 cl nextel ALIN Phone Unlocking Codes & Maps 0 11-01-2003 13:26
PinOut for GD 96 and 95 Format1 Panasonic 2 05-23-2003 06:51
I have winmodo 1.3 for gd35 and 95 AlexMobile Panasonic 5 08-29-2001 09:24
I have winmodo 1.3 for gd35 and 95 AlexMobile Exchange Section 3 08-29-2001 08:55
Page generated in 0.23234 seconds with 10 queries
