05-25-2009, 22:39 | #1 (permalink) |
Insane Poster Join Date: Apr 2009
Member: 1012502 Status: Offline Thanks Meter: 2 | pinout for mini iphone clone i have chinese mobile D2009 (rose color) It is miniiphone clone, on the back is written IPHONE 16GB, I need to know change language to czech. Could you talk me pinout? I have pin finder too, but I cant remove cover from battery, (battery is like in original iphone), so i cant to use pin finder Do you know correct pinout? Where can I download CZECH dictionary? (or SLOVAK DICT) |
05-26-2009, 09:52 | #2 (permalink) |
Member: 1012502 Status: Offline Thanks Meter: 2 | As MINI Iphone 16 GB, i mean this phone: http://www.focalprice.com/2009_Tri_b...344P_8665.html There is cover on battery, could you tell me correct pinout? |
05-26-2009, 23:09 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! unfortunately, i dont have pinout for this model in my collection. i have done one full size Iphone today, removed screws, battery cover, desoldered battery. connected pinfinder and made needed. |
05-27-2009, 08:53 | #6 (permalink) |
Member: 1012502 Status: Offline Thanks Meter: 2 | Ok, but I have one more questions: I made everything, without DESOLDERED BATTERY.. Need I desoldered battery too?? Second Possibility: Or why dont work AUTO PIN FINDER??? (I think that then battery must be CONNECTED???) Third Possiblity: Probably this phone is PCB, or NOT? But I dont see PCB TEST POINTS LIKE in nokia 8800 arte, do you have any picture with PCB from other phones??? |
05-27-2009, 22:06 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! battery must be desoldered. phone must be powered from pinfinder power. in other case pinout will be not found i dont think it use test points on PCB. 12pin connector has enough pins for keeping Tx/Rx |
05-29-2009, 20:19 | #10 (permalink) |
Junior Member Join Date: Apr 2009
Member: 1021440 Status: Offline Thanks Meter: 1 | Same problem with Mini iPhones Hi All, I have the same Mini iPhone and a few more like TV iPhone and another model of Mini iPhone. I have used the Spiderman Box to work of these phone. I gave me no results, so I have tested the pins manually and got the pinout (at least the TX and RX). As for the groud, it might have more then one GND. You can eliminate pins using the earphones and USB cable pins. The bottom line was that the TX and RX were found in all 3 types of phones, but no results (no communication). On the Mini iPhones that has a back cover, I have used the external power of 3.7V instead of the battery (that of the Spiderman Box which is 5V and not 3.7V like the battery) and I have defined the pins manually. Further more, I have disassembled one unit and found that the chip is 6225A. The bottom line is that will the Infinity box do a better job on this one? I know for sure that it can be done since I have talked with a guy that is doing it on a daily basis (there are two methods) but he did not want to expose his secrets. |
08-02-2009, 17:34 | #12 (permalink) |
Freak Poster Join Date: Jul 2005 Location: Portmore, Jamaica Age: 52
Member: 160245 Status: Offline Thanks Meter: 19 | I also have one of these units, i desoldered the battery and tried using pinfinder with usual settings for Chinese phone but was unable to get rx tx. Tried everything i know for chanese phones but still unable. Help please |
08-02-2009, 17:48 | #13 (permalink) |
Member: 160245 Status: Offline Thanks Meter: 19 | Here is the operation logs for my attempt at finding pins for D2009 mini-iphone ==== log opened: [7/30/2009 9:39:39 PM] ==== Application: C:\Program Files\InfinityBox\PinFinder\PinFinder.exe Initializing... software version: 1.19 Smart-Card S/N: 0F5E Smart-Card firmware version: 0112 Initializing PinFinder... Initializing database... base database version: 01 user database version: 01 Loading configuration... Initializing cable list... Initializing platforms... Initialization finished searching adapter at COM3... adapter found, version: 2000 S/N: -------------------------------------------- done Initializing... done Cable: 1x12 (L12C) software version: 1.19 cable type: 1x12 (L12C) platform: MT: MT6205, MT6217-MT6228, MT6230 searching adapter at COM3... adapter found, version: 2000 pins: 12, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed failed to detect pins time required: 66 sec Trying to Power-On... Power On ! Set parameter to value 20 (or more) and repeat operation (parameter "Finder activation tries") software version: 1.19 cable type: 1x12 (L12C) platform: CPU independent (autodetect) algorithm searching adapter at COM3... adapter found, version: 2000 pins: 12, plain power cycles: 1 activation cycles: 5 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Phone should be Powered-On ! Power-On phone now and press "Ok" Be sure that phone is not in sleep mode during pinout detection ! Press any phone key from time to time to wake-up phone. detecting pins... failed to detect pins time required: 155 sec Set parameter to value 20 (or more) and repeat operation (parameter "Finder activation tries") Cable: 1x12 (L12C) Power Off ! software version: 1.19 cable type: 1x12 (L12C) platform: MT: MT62xx (autodetect) searching adapter at COM3... adapter found, version: 2000 pins: 12, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed error: boot initialization step #2 failed: 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed failed to detect pins time required: 54 sec Trying to Power-On... Power On ! Set parameter to value 20 (or more) and repeat operation (parameter "Finder activation tries") Power Off ! Power On ! software version: 1.19 cable type: 1x12 (L12C) platform: MT: MT62xx (autodetect) searching adapter at COM3... adapter found, version: 2000 pins: 12, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... failed to detect pins time required: 62 sec Trying to Power-On... Power On ! Set parameter to value 20 (or more) and repeat operation (parameter "Finder activation tries") software version: 1.19 cable type: 1x12 (L12C) platform: MT: MT62xx (autodetect) searching adapter at COM3... adapter found, version: 2000 pins: 12, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed failed to detect pins time required: 63 sec Trying to Power-On... Power On ! Set parameter to value 20 (or more) and repeat operation (parameter "Finder activation tries") software version: 1.19 cable type: 1x12 (L12C) platform: MT: MT62xx (autodetect) searching adapter at COM3... adapter found, version: 2000 pins: 12, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed failed to detect pins time required: 67 sec Trying to Power-On... Power On ! Set parameter to value 20 (or more) and repeat operation (parameter "Finder activation tries") Power On ! Power On ! Power On ! software version: 1.19 cable type: 1x12 (L12C) platform: CPU independent (autodetect) algorithm searching adapter at COM3... adapter found, version: 2000 pins: 12, plain power cycles: 1 activation cycles: 5 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Phone should be Powered-On ! Power-On phone now and press "Ok" Be sure that phone is not in sleep mode during pinout detection ! Press any phone key from time to time to wake-up phone. detecting pins... failed to detect pins time required: 155 sec Set parameter to value 20 (or more) and repeat operation (parameter "Finder activation tries") |
08-03-2009, 23:30 | #15 (permalink) | |
Member: 160245 Status: Offline Thanks Meter: 19 | Quote:
Press and HOLD phone Power button now ! detecting pins... 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed failed to detect pins time required: 67 sec | |
help with pinout for CECT KA08 mini iphone clone | shimi77 | Chinese Models & Cloned Phones | 28 | 10-28-2010 18:57 |
Need pinout for mini iphone clone (please!) | flatline76 | Chinese Models & Cloned Phones | 0 | 07-24-2009 17:58 |
A07 mini iphone clone language ? | designer | Chinese Models & Cloned Phones | 0 | 06-09-2009 18:01 |
A07 mini Iphone clone | lena-plu6ka | Chinese Models & Cloned Phones | 3 | 03-11-2009 11:35 |
LH01 mini Iphone clone | phönix | Infinity-Box | 13 | 02-15-2009 21:03 |
