Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Mar 2007
Member: 476697 Status: Offline Thanks: 16
| pinout N82 RM-313 hello I need pinout N82 RM-313.please help me conector 5pin http://img341.imageshack.us/img341/7...ensionskd2.jpg |
| | #4 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: May 2005 Age: 36
Member: 148515 Status: Offline Thanks: 2,319
| are you sure that this is mt62xx MCU based phone? tip: you can check this by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software if yes- i can teach how to find pinout using multimeter by measuring voltages on phone pins |
| | #5 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2005 Age: 29
Member: 146708 Status: Offline Sonork: 100.108221 Thanks: 467
| Quote:
as far as i remember this pinout posted before.. let me check... | |
| | #6 (permalink) | |
| Quote:
N82 Meiye Type:Q8 Pinout Pls... pls check and post results... | |
| | #7 (permalink) | |
| Quote:
![]() please tell me step by step | |
| | #8 (permalink) |
| hello! 1. set multimeter to voltage measuring. 2. check bettery voltage, it should be more than 3,7volts 3. set one multimeter probe to some grounded phone part (if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal) 4. with second probe touch one by one all phone pins (phone battery attached) (to get better result i would advice to set needle on the end of second probe) memorise pins with voltage between 2,7-2,9volts. those are tx/rx |
| The Following User Says Thank You to InfinityHelp For This Useful Post: |
| | #9 (permalink) |
| | #10 (permalink) | |
| Quote:
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Can UB flash N82 rm-313 by USB now? | epic | Universalbox | 2 | 12-18-2007 22:47 |
