01-27-2009, 15:07 | #1 (permalink) |
Insane Poster Join Date: May 2007 Location: colombia Age: 37
Member: 516358 Status: Offline Thanks Meter: 12 | please help sciphone i68 dead after enginner mode hello I have a computer problem with a clone of iphone (sciphone + i68) after putting in so engineer and restore some settings the phone is dead: S I tried to restore infinity but always pulls me connection error (I used the pinout that is directly to board but not recognized as fix this? I have more of these 2 teams but all say they quald band signal but none I have tried to restore via usb and rj but always gives me the same mistake I would like to know I can put to work thanks for your attention! forgiveness for my bad English |
01-29-2009, 01:30 | #4 (permalink) |
Member: 516358 Status: Offline Thanks Meter: 12 | hello thank you for responding so quickly very good team and hopefully can fix it! around here the log and screen I have a backup EPROM and fullflash I made another sciphone i68 , where you can upload it for me to make the flash thanks for your attention and I apologize for my bad English ==== log: [28/01/2009 06:12:48 p.m.] ==== COM8 [VCP0] selected module v2.75 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "repair imei" imei write method: mode-3 imei write channel: imei #1 for dual sim/mono CPU new imei: 358967002774527 ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:BC03:0007 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 89890100040089:89890100000000 flash: Intel ST [def 0080x040000] 32Mb detecting chip #01 in region #00... flash: 89890100040089:89890100000000 flash: Intel ST [def 0080x040000] 32Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 89890100040089:89890100000000 flash: Intel ST [def 0080x040000] 32Mb Warning: probably flash chip empty, erased, incorrectly flashed or damaged. What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box UN-CHECKED ! 3. make flash write operation If still no luck: send mail to support ([email protected]) with detailed description of problem, attach the next files in your e-mail: 1. C:\Archivos de programa\InfinityBox\ChineseMiracle\operation.log 2. C:\Archivos de programa\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx. bin detecting chip #01 in region #00... flash: 89890100040089:89890100000000 flash: Intel ST [def 0080x040000] 32Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 02000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detecting security area (code #2)... .................................................. .................................................. .................................................. .................................................. .................................................. ...... security area (code #2) is absent detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 01C00000 flash: 89890100040089:89890100000000 checking area [00000000]: 00000000-01FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 01C00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00400000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:01C00000-01FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom... file saved: C:\Archivos de programa\InfinityBox\ChineseMiracle\eeprom_2009012 8-182253.B0E.bin flash: 89890100040089:89890100000000 Backup required data Done Patch required data ... imei is not detected ! What to do: 1. Power-On phone 2. wait 20-30 sec 3. Power-Off by "Power" button, don't remove battery ! 4. Repeat "repair imei" procedure again If imei can't be detected: 1. make "complete" ffs/eeprom format 2. Power-On phone 3. wait 20-30 sec 4. Power-Off by "Power" button, don't remove battery ! 5. Repeat "repair imei" procedure again If imei can't be detected: read flash and send to support: [email protected] Patch required data Fail Finished, time used: 610 sec Remove/Install battery now ! |
01-29-2009, 11:40 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, It looks like flash chip of your phone is erased. You must flash phone with good firmware. If you have good flash backup from the same phone you can send backup to [email protected] Also you can try to use the next files from support: \flashfiles\ChineseMiracle\_MT6225\TELSDA25_07B_PC B01_GPRS_MT6225_S00.LS_I68_62025_64_A_V1_0__Scipho ne-i68_32m_En_Ru_El_Nl_Fr_Es_It_De_Ml_Th_Vn_Cn_Tr_Pt. B0M.bin \flashfiles\ChineseMiracle\_MT6225\TOP25_06B_PCB01 _GPRS_MT6225_S00.MAUI_06B_W07_28_MP_V8__SCiPhone_i 68_32m_En_Ru_Nl_Fr_Es_It_De_Th_Vn_Cn_Tr_Pt_Cn_Ar.B 0M.bin \flashfiles\ChineseMiracle\_MT6225\32m\TELSDA25_07 B_PCB01_GPRS_MT6225_S00.LS_I68_62025_64_A_V1_3__SC iPhone-i68+_32m_En_Ru_El_Nl_Fr_Es_It_De_Ml_Th_Vn_Cn_Tr_Pt .B0M.bin |
01-29-2009, 19:34 | #6 (permalink) |
Member: 516358 Status: Offline Thanks Meter: 12 | Thank you very much infinity team sciphone lives of the new medium with excellent array of the following flash \flashfiles\ChineseMiracle\_MT6225\32m\TELSDA25_07 B_PCB01_GPRS_MT6225_S00.LS_I68_62025_64_A_V1_3__SC iPhone-i68+_32m_En_Ru_El_Nl_Fr_Es_It_De_Ml_Th_Vn_Cn_Tr_Pt .B0M.bin as could fix the problem and not signal invalid sim very very grateful! |
01-30-2009, 01:53 | #8 (permalink) | |
Member: 516358 Status: Offline Thanks Meter: 12 | Quote:
Hi | |
The Following 2 Users Say Thank You to kiubo For This Useful Post: |
01-31-2009, 13:43 | #13 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
correct flash file name can be given only after you assemble Com port cable and make "read detailed information". also: what problem is with your phone? maybe we can advice repair method which will not require flashing | |
01-31-2009, 20:34 | #15 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! i would advice to start from Format FFS (safe) if will not help - then continue with Format FFS (complete) !before make backup for emergency case! |
CRUISER TEAM PLEASE HELP ME K310i dead after unloking | .::ricky rayya::. | Phone Unlocking Codes & Maps | 5 | 04-20-2007 08:40 |
Zulea,please Help!! my 802sh dead after flashing | superwing1248 | SonyEricsson (USB-Smart) | 2 | 10-18-2005 12:57 |
Please help rescue 6680 dead after trying to connect | Keke | Nokia Base Band 5 ( BB-5 ) | 0 | 10-10-2005 10:32 |
Please HELP!!!! A-300 dead after flashing | RomaK | VLSI, Conexant, Skyworks and Old Models | 1 | 11-15-2002 20:09 |
