02-22-2017, 18:03 | #1 (permalink) |
Registered User Join Date: Jan 2007 Location: SAHARA OCCIDENTAL
Member: 425935 Status: Offline Thanks Meter: 40 | plz help me to repair imei for SONY Z6 WHEN I REPAIR THE IMEI STEEL INVALID CAN ANY ONE HAVE NVRAM FOR THIS PHONE LOOK HERE Card found : S/N : 47D279D4 , v0135 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Brom Init not done Boot Error! Operation Failed Elapsed: 00:00:04 Reconnect Power/Cable! Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 7001004545344541340127BB35C66335 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , 4AE4E [eMMC] : FLASH_CID : 7001004545344541340127BB35C66335 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E2000000 [eMMC] : FLASH_UCP : 3616 MiB [eMMC 4 GiB] DEV RID : 0x3F844DC6AAA86340928319732D9A3E6E INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Z6 ProdName : a831_324_ax_cht_z6_mexi ProdModel : Z6 Device : a831_324_ax_cht_z6_mexi AndroidVer: 5.1 MTKxCPU : MT6572 MTKxPRJ : a831_ax_324_cht_z6_mexi_v1.06 Done! Elapsed: 00:00:08 Reconnect Power/Cable! Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 7001004545344541340127BB35C66335 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , 4AE4E [eMMC] : FLASH_CID : 7001004545344541340127BB35C66335 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E2000000 [eMMC] : FLASH_UCP : 3616 MiB [eMMC 4 GiB] DEV RID : 0x3F844DC6AAA86340928319732D9A3E6E INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Z6 ProdName : a831_324_ax_cht_z6_mexi ProdModel : Z6 Device : a831_324_ax_cht_z6_mexi AndroidVer: 5.1 MTKxCPU : MT6572 MTKxPRJ : a831_ax_324_cht_z6_mexi_v1.06 SECURITY : IMEI_SW [1] : 355613072712624 IMEI_SW [2] : 355613072712632 BTMAC Addr : 5E65466572A6 WiFi MAC : E8D5EBECCF2F MODEM : BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V36_P3_1_wg_n Done! Elapsed: 00:00:10 Reconnect Power/Cable! |
02-23-2017, 12:24 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Backup NVRAM. Do repair Unknown BB. Restart phone and verify it state. If all ok - rrestore NVM and make factory reset. |
