05-11-2009, 12:06 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: InsidE AndroiD Age: 37
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks Meter: 473 | problem with chinese xtelecom X3128 it is sssaying eeprom or ffs area not correct i press yes mostly sets are powered on with complete formatting but this one is not going to power on the version of this fone is this: ::E506_B25_PCB01_GPRS_MT6226_S01.00_0.BIN i make full format but no succes then i flashed the fone with this firmware on support of infinity box :::E506_B25_PCB01_GPRS_MT6226_S01.00_0_16m_En_Ru_A r.B0M.bin but no succes need help regarding this phone ==== log: [5/11/2009 4:47:05 PM] ==== COM3 [VCP0] selected module v2.82 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:2AC1:06C2 status: FF high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.71F37329.[E506_B25_PCB01_GPRS_MT6226_S01.00_0.BIN_9713BC0D].rpl identification#1 detection finished device-id: 71F37329 identification#1 protocol ver: 04 ver. sw 1: E506_B25_PCB01_GPRS_MT6226_S01.00_0.BIN ver. sw 2: E506_B25.00.0, F243EC68 ffs offset/size: 00800000/001FF000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00800000 flash: EC257E25082501:29EA0000000000 checking area [00000000]: 00000000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00800000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00800000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00800000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: EC257E25082501:29EA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: EC257E25082501:29EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\E 506_B25_PCB01_GPRS_MT6226_S01.00_0__system_log_71F 37329_9713BC0D_20090511-165039.B0X.bin Finished, time used: 194 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! |
05-13-2009, 19:46 | #6 (permalink) |
No Life Poster Join Date: May 2006 Location: Sambrial (Sialkot)
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | i have also tested bin file of spider man .................i will upload if needed? i have 2 dead sets fixed just today with this file. |
05-14-2009, 09:44 | #7 (permalink) |
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks Meter: 473 | thanks sir for converting the bin file at the moment cstomer's taken back but he ll come in a day or two i ll try and post result thanks again INFINITY=SUPERB BOX |
05-14-2009, 18:30 | #8 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
i appreciate your offer!!! but, do not send until we get some test report regarding converted file Last edited by InfinityHelp; 05-14-2009 at 18:40. | |
Strange problem with Chinese phones | jollymolly | UCT (Universal China Tool) by ET | 6 | 06-21-2010 07:21 |
A very big problem with chinese miracle ... | asmodi | Infinity-Box | 10 | 08-07-2008 16:17 |
Strange Problem With Chinese Nokia N82 | mukasa | Infinity-Box | 2 | 07-15-2008 09:23 |
plz problem with phone Xtelecom flash | zakryia | Infinity-Box | 7 | 03-28-2008 15:21 |
