11-25-2008, 09:11 | #1 (permalink) |
No Life Poster Join Date: Feb 2007
Member: 449069 Status: Offline Thanks Meter: 61 | Problem with Gaoxinqi_A818 Which Shows 1% to 100% Normally on screen, but doesn't switches on. Safe Format successful, but In Vain. With full Format, i am getting following error ------------------------------------------------------ module v2.69 Device: Autodetect 6228, 6229, 6230 NAND Checking data, wait... Action: NAND reset read mode: 01 Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6228:8A02:8A02]... CPU: MT6228 high speed boot enabled chip: 0031:0000:0101 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... version: 3.0207 loader: 3.748.0 NAND id: ECF10095 page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00EC:00F100000095 [08400000] NOR chip is not installed Initialize Done Set baud ... 460800 Set baud Done Identification ... reading structure area... detecting structure... source data: page only identification#1 protocol ver: 04 ver. sw 1: MT6228_05C_PCB04_GPRS_MT6228_S02.MAUI_05C_W06_24_M P_V18.BIN ver. sw 2: MAUI.05C.W06.24.MP.V18, 00000000 ffs offset/size: 02000000/06000000 id-page1 Ok nfi area detection finished: Ok identification#1 structure: 2nd [standard] generation Identification Done Write ... formatting... .................................................. ...........................error: code: 9800006900 Write Fail Finished, time used: 52 sec Remove/Install battery now ! -------------------------------------------------------------- When i tried to erase flash chip, I Get Following. ---------------------------------------------------------------- module v2.69 Device: Autodetect 6228, 6229, 6230 NAND Checking data, wait... Action: erase flash chip Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6228:8A02:8A02]... CPU: MT6228 high speed boot enabled chip: 0031:0000:0101 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... version: 3.0207 loader: 3.748.0 NAND id: ECF10095 page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00EC:00F100000095 [08400000] NOR chip is not installed Initialize Done Set baud ... 460800 Set baud Done Identification ... reading structure area... detecting structure... source data: page only identification#1 protocol ver: 04 ver. sw 1: MT6228_05C_PCB04_GPRS_MT6228_S02.MAUI_05C_W06_24_M P_V18.BIN ver. sw 2: MAUI.05C.W06.24.MP.V18, 00000000 ffs offset/size: 02000000/06000000 id-page1 Ok nfi area detection finished: Ok identification#1 structure: 2nd [standard] generation Identification Done Write ... formatting... .................................................. .................................error: code: 9800006900 Write Fail Finished, time used: 52 sec Remove/Install battery now ! ----------------------------------------------------- Please Guide how to recover!!!! Thanks |
11-25-2008, 09:38 | #2 (permalink) |
Member: 449069 Status: Offline Thanks Meter: 61 | After Erasing, Set gets dead, After writing Backed up Flash, Set comes to original condition Here is the writing log. ------------------------------------------------------------ module v2.69 Device: Autodetect 6228, 6229, 6230 NAND Checking data, wait... Action: write NAND flash read mode: 01 write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs source data: page only identification#1 protocol ver: 04 ver. sw 1: MT6228_05C_PCB04_GPRS_MT6228_S02.MAUI_05C_W06_24_M P_V18.BIN ver. sw 2: MAUI.05C.W06.24.MP.V18, 00000000 ffs offset/size: 02000000/06000000 id-page1 Ok nfi area detection finished: Ok Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6228:8A02:8A02]... CPU: MT6228 high speed boot enabled chip: 0031:0000:0101 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... version: 3.0207 loader: 3.748.0 NAND id: ECF10095 page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00EC:00F100000095 [08400000] NOR chip is not installed Initialize Done Set baud ... 460800 Set baud Done Identification ... reading structure area... detecting structure... warning: probably flash chip completely erased, no bootloader found nfi area detection finished: failed error: can't detect nand chip parameters, default values assigned Identification Done Write ... write core area 1 of 2... write core area 2 of 2... Write Done Finished, time used: 561 sec Remove/Install battery now ! ---------------------------------------------------- Please Guide how to recover |
11-26-2008, 15:05 | #4 (permalink) |
Member: 449069 Status: Offline Thanks Meter: 61 | @ Support, One Request If the file is not on support area, The Firmware Should have been detected as new One(or at least user should have been asked to send the file on to support area), I Think This will be helpful..... If anybody has this file please share, The model Looks exactly alike Mini O2. MT6228_05C_PCB04_GPRS_MT6228_S02.MAUI_05C_W06_24_M P_V18 Thanks |
Problem with unlocking Samsung E1080 | ..::alexis::.. | HWK | 18 | 09-25-2011 14:23 |
big problem with my mx key | sshreesai | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 03-31-2010 10:07 |
problem with nokia 6234 | pachicoo | Universalbox | 2 | 03-29-2010 15:19 |
.: Strange Problem with T610 power on with p-supply but never with battrey :. | Jani-Jan | Sony Ericsson Hardware Repair | 5 | 05-25-2004 16:31 |
