02-12-2008, 20:30 | #1 (permalink) |
Insane Poster Join Date: May 2004 Age: 46
Member: 67188 Status: Offline Thanks Meter: 1 | problem with new version v 2.27 chines miracle COM4 [VCP0] selected Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6225:8A03:8A00]... CPU: MT6225 chip: 0001:8003:0000 Connecting, wait... Release Power button now ! Phone detected, wait... warning: can't read software version, probably unknown firmware detecting structure #2... 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 warning: wrong packet cs 19 20 21 22 23 24 25 error: detection failed (26 tries), read flash and send to support connection lost error: operation failed ! Finished, time used: 11 sec Remove/Install battery now ! i have nokia n82i |
02-13-2008, 14:11 | #3 (permalink) |
Member: 67188 Status: Offline Thanks Meter: 1 | complete format in complete format write: COM4 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 chip: 0001:8003:0000 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 error: no any expected answer: wrong answer after chip cfi request flash: EC257E25082501:18E59F00000000 flash: Samsung D 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: E558_JQ3F8_E558_GPRS_MT6225_S00.V60_01_1.BIN ver. sw2: E558_JQ3F8.V60.01.1, 00000000 ffs offset/size: 00E00000/001FF000 detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF reading [eeprom[E558_JQ3F8_E558_GPRS_MT6225_S00.V60_01_1.BIN]]... warning: wrong data size at 0x00E03000, retry... warning: wrong data size at 0x00E03000, retry... warning: wrong data size at 0x00E03000, retry... warning: wrong data size at 0x00E03000, retry... warning: wrong data size at 0x00E03000, retry... warning: wrong data size at 0x00E03000, retry... warning: wrong data size at 0x00E03000, retry... warning: wrong data size at 0x00E03000, retry... warning: wrong data size at 0x00E03000, retry... error: too many retries during read operation Probably errors exist during flash read operation. Do you want to repeat read operation ? error: no any expected answer Probably errors exist during flash read operation. Do you want to repeat read operation ? error: no any expected answer Probably errors exist during flash read operation. Do you want to repeat read operation ? error: no any expected answer Probably errors exist during flash read operation. Do you want to repeat read operation ? error: no any expected answer Probably errors exist during flash read operation. Do you want to repeat read operation ? error: no any expected answer Probably errors exist during flash read operation. Do you want to repeat read operation ? error: no any expected answer Probably errors exist during flash read operation. Do you want to repeat read operation ? operation canceled by user |
02-13-2008, 23:38 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Please, give me an answers to all my questions: 1. What was original phone condition ? 2. What is battery voltage ? 3. Did you had a chance to open phone and check it's hardware ? 4. Did you tried to repeat the same operation ? 5. if yes, what is the results ? 6. if the same error exist: is the error on the same address or on different addresses during reading ? 7. did you tried to make "format" with disabled "backup" option in "settings" page ? |
02-15-2008, 22:21 | #11 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Please, give me an answers to all my questions: 1. What was original phone condition ? 2. What is battery voltage ? 3. Did you had a chance to open phone and check it's hardware ? 4. Did you tried to repeat the same operation ? 5. if yes, what is the results ? 6. if the same error exist: is the error on the same address or on different addresses during reading ? 7. did you tried to make "format" with disabled "backup" option in "settings" page ? |
02-17-2008, 13:28 | #13 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Dear Friend, Currently many "Chinese" models with the same name but absolutely different hardware exist on market. Exmple: exist at least 20 phones with name "Chinese Nokia-N95" but all models has difference in hardware, different bottom connectors, different pinouts and and has different firmware, so we recommend you to include the next information in your request regarding pinout: 1. detailed description of model: brand name, model name, complete text from phone back label, any other marks that you can find on phone cover 2. phone CPU chip name 3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB) 4. attach phone photo 5. attach phone bottom connector photo 6. include information about Gnd and Charge pins on phone bottom connector After you have this information prepared, you can find pinout by yourself more easy than before, just check the next detailed description how to get pinout for your model: 1. use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 2. if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\ 3. if not helps, please read: http:///vbb/showpo...36&postcount=7 4. if not helps, please read: http:///vbb/showthread.php?t=433447 |
Ustpro2 - problem with new versions ! | raven25 | UST Pro II | 4 | 08-24-2006 00:06 |
problem with new version nsdongle | fonesunlock | NSPRO | 0 | 12-14-2005 11:17 |
problem with new version 1.22 | ADD-GSM | Twisterflasher | 6 | 07-05-2004 13:48 |
