Old 05-04-2011, 08:35   #1 (permalink)
MADCIRA's Avatar
Member: 65352
Thanks Meter: 118
problem with write operation on chinese miracle v3.30
COM4 [VCP0] selected
module v3.30
Device: Autodetect 6228-6268 NAND
Checking data, wait...
Action: write flash NAND
write: Firmware
BLACKBERRY_9630_NEOTEL35_08B_GEMINI_PCB01_GPRS_MT6 235B_S01.B300_GH_EN1_TY1G_BE_JSTW_V004__firmware_2 0110503-191215.B4M
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
nfi area detection...
bootloader version: _BOOTLOADER_B300_GH_EN1_TY1G_BE_JSTW_V004.bin
nfi area detection (3 cores) finished: Ok
interface: BROM_DLL_v3.1016.00
Connect...
Connecting...
Booting...
Release Power button now !
bootcode current/expected: 3.2/3.2
CPU: 6235:8A04:8A01
status: FF
bbchip bl ver: FE
NOR flash chip: not installed
NAND flash id[0014]: 0098:00D100900015 [TOSHIBA] TC58NVG0S3AFT
chip size: 128Mb
page/spare size: 0800/0040
pages per block: 0040
bits i/o: 08
address cycles: 04
internal RAM size: 00010000
external RAM: S_DA_RAM_ERROR
done
Set baudrate (921600)...
done
ram test...
testing 32bit...
32bit ram test passed
testing 16bit...
16bit ram test passed
ram test passed
===> detect existing firmware structure...
detect ffs...
ffs offset/size: 04000000/04000000
firmware size: 64Mb
ffs size: 64Mb
detect sec ro...
detect custom parameters...
detect project-id...
project-id: B300_GH_EN1_TY1G_BE_JSTW_V004
detect NAND info...
number of areas/bytes to read: 1:001A0000
reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)...
warning: id-page1 area is invalid
nfi area detection (0 cores) finished: failed
TCL-ID detection...
TCL-ID detection done
startup code area #1 detection...
startup code area #1 detection done
rom info ver: 07
sw version: NEOTEL35_08B_GEMINI_PCB01_GPRS_MT6235B_S01.B300_GH _EN1_TY1G_BE_JSTW_V004.BIN
project-id: B300_GH_EN1_TY1G_BE_JSTW_V004, 00000000
code offset: 00000000
ffs offset/size [01]: 04000000/04000000
rom info structure: [standard] type (07)
TCL-ID is absent
===> done
New firmware found (v.3.30, database date: 17.04.2011):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
startup code area #1 check...
done
number of cores: 3
loading files...
number of areas: 3
done
write...
write bootloader...
write core...
error: can not write flash (12): C414:??
error: last error: C414:??
Disconnect...
done
Finished, time used: 2 min 47 sec
Remove/Install battery now !
fullflash was sent to [email protected]
phone was good,my job is to translate this unit......but i have problem with write fullflash,always stop as u see in log
can u help me
Best Regards
MADCIRA
Old 05-04-2011, 19:08   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
does this happen with both (translated and nontranslated) flash files?
Old 05-04-2011, 19:19   #3 (permalink)
MADCIRA's Avatar
Member: 65352
Thanks Meter: 118
yes even with this from support NEOTEL35_08B_GEMINI_PCB01_GPRS_MT6235B_S01.B300_GH _EN1_TY1G_JST_V005__128m_En_Fr_Es_Dk_Pl_Pt_It_De_M l_Id_Vn_Tr_Ru_Ar_Th_Cn.B4M
my backup doesn't help sometimes error 20% sometimes 23%,doesn't stop at same adress
already talk with s.Mobi,because i have another MT6235B and LPE doenst load fullflash,i have Error! Language table not found!
this is 4-5 MT6235B which i can't translate......my customer wait me for solution,but now with this phone i have problem,dead unit,can't write backup
Old 05-04-2011, 20:30   #4 (permalink)
Member: 148515
hello!
please post your original, not translated backup
better if you upload it to RapidShare AG, Cham, Switzerland
Old 05-04-2011, 21:44   #5 (permalink)
fernando reyes's Avatar
Member: 516363
Sonork: 100.1601307
Thanks Meter: 35
konka c612 sim card blocked
have try all methods bt phone still locked
operation log:
COM6 [VCP0] selected
module v3.30
Device: Autodetect 6205-6239 NOR
Action: "sp-unlock"
unlock method: standard fast
Unlock procedure can be faster if you skip ffs/eeprom area backup procedure.
Do you want to disable ffs/eeprom backup ?
ffs/eeprom backup disabled
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
high speed boot On
chip: 0011:8291:000C
status: FF
boot packet size: 0400
Boot Done
====> Initialize ...
flash: EC257E25082501:29EA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
otp offset: 00000000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [protected] type (04), 1 record(s)
TCL-ID is absent
startup code area #1 is Ok
startup code area #1 backup saved: C:\InfinityBox\ChineseMiracle\backup_security\id.3 3FEF693.[C612_SAH_PCB01_GPRS_MT6223P_S00.KAA612FM_SAH_SP_EN _FR_1_02_304.BIN_17E6F978].rpl
rom info detection finished
device-id: 33FEF693
rom info ver: 04
sw version: C612_SAH_PCB01_GPRS_MT6223P_S00.KAA612FM_SAH_SP_EN _FR_1_02_304.BIN
project-id: KAA612FM_SAH_Sp_En_Fr_1.02.304, 78F9E617
ffs offset/size [01]: 00900000/00700000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00900000
standard ffs/eeprom offset confirmed: 00900000
detecting ffs/eeprom size...
ffs/eeprom size: 00700000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00900000-00FFFFFF
firmware area: 00000000-008FFFFF
detecting startup code area #2...
startup code area #2 is absent
detecting ffs/eeprom structure pass 1...
ffs/eeprom: detect std location pass #1...
ffs/eeprom: detect ext location pass #1...
ffs/eeprom: detect standard offset pass #1...
ffs/eeprom record offset detected
ffs/eeprom: detect standard data...
ffs/eeprom record size detected
ffs/eeprom layout detection complete
ffs/eeprom detected ok: element #1
startup code area #1 fixed
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
Backup required data Done
====> Patch required data ...
lock area found
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write: lock-area-1
Write Done
====> Finalization ...
Finalization Done
file saved: C:\InfinityBox\ChineseMiracle\backup_security\C612 _SAH_PCB01_GPRS_MT6223P_S00.KAA612FM_SAH_SP_EN_FR_ 1_02_304__system_log_33FEF693_17E6F978_20110504-143245.B0X.bin
Finished, time used: 2 min 22 sec
Old 05-04-2011, 22:03   #6 (permalink)
Member: 516363
Sonork: 100.1601307
Thanks Meter: 35
operation log:
module v3.30
Action: "sp-unlock"
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
status: FF
Boot Done
Initialize Done
====> Set baud ...
115200
Set baud Done
TCL-ID is absent
device-id: 33FEF693
rom info ver: 04
TCL-ID is absent
ffs/eeprom chip: 00
lock area found
====> Write ...
Write: lock-area-1
Write Done
Finalization Done
im very sorry it was mi fault:
module v3.30
Action: "sp-unlock"
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
status: FF
Boot Done
Initialize Done
====> Set baud ...
115200
Set baud Done
TCL-ID is absent
New firmware found (v.3.30, database date: 01.05.2011):
device-id: 33FEF693
rom info ver: 04
TCL-ID is absent
ffs/eeprom chip: 00
lock area found
====> Write ...
Write: lock-area-1
Write Done
Finalization Done
file saved: C:\InfinityBox\ChineseMiracle\backup_security\C612 _SAH_PCB01_GPRS_MT6223P_S00.KAA612FM_SAH_SP_EN_FR_ 1_02_304__system_log_33FEF693_17E6F978_20110504-144505.B0X.bin
Finished, time used: 2 min 38 sec
Old 05-04-2011, 22:10   #7 (permalink)
Member: 516363
Sonork: 100.1601307
Thanks Meter: 35
it was ok but now after turn it off asking for code np
im very sorry for this trouble but never happen to me before
Old 05-05-2011, 07:29   #8 (permalink)
MADCIRA's Avatar
Member: 65352
Thanks Meter: 118
@fernando reyes
open your thread with problem
@InfinityHelp
here is orginal backup firmware
https://rapidshare.com/files/4606795...503-191215.B4M
Old 05-05-2011, 16:10   #9 (permalink)
Member: 516363
Sonork: 100.1601307
Thanks Meter: 35
Originally Posted by MADCIRA View Post
@fernando reyes
@InfinityHelp
im very sorry bro, the thing is that i belive that the problem is the module becouse i have done this model before but im gonna try to solved my self good luck with ur problem.
Old 05-05-2011, 19:03   #10 (permalink)
Member: 148515
hello!
try make format FFS complete
Old 05-06-2011, 08:03   #11 (permalink)
MADCIRA's Avatar
Member: 65352
Thanks Meter: 118
any news with my case, i have dead phone , customer wait me
Old 05-07-2011, 12:27   #12 (permalink)
MADCIRA's Avatar
Member: 65352
Thanks Meter: 118
mistery solved
another computer without internet connections
now I'm waiting s.Mobi to fix Error! Language table not found! in LPE
Best Regards
MADCIRA
Old 05-07-2011, 21:16   #13 (permalink)
Member: 148515
hello!
i have no ideas why this is happening.
try to write flash on different speeds.
from 921600 to 115200
Old 05-09-2011, 10:13   #14 (permalink)
MADCIRA's Avatar
Member: 65352
Thanks Meter: 118
already tried,speed is not problem...........another computer and normal flashing fix problem,very strange
in my country we say feed the dog and don't touch anything
na'rani keru i ne diraj nista !!!
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
Operator-Logo for 5110 MiMiR the WiseMan Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 06-25-1999 15:50
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-09-1999 17:04
Page generated in 0.31621 seconds with 10 queries
