06-06-2010, 16:11 | #1 (permalink) |
Freak Poster Join Date: Dec 2006 Location: Khartoum-Sudan
Member: 420318 Status: Offline Sonork: 100.1661057 Thanks Meter: 65 | problem writing imei i have a tv mobile c 100 type:bar i can't write imei here the result after doing write imei mode 3 Action: read/check information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: AT+ESLP=0 Hardware version: MT6225, E05 Software version: REBOUND25_GEMINI_HW" Software date: N.V580.Y30 Barcode: 2006.06.14 imei-1: MT0123456789012 imei-2: 356610015231513 imei-3: 350076879418867 Finished, time used: 10 sec Remove/Install battery now ! any advice?? |
06-07-2010, 11:03 | #4 (permalink) |
Member: 420318 Status: Offline Sonork: 100.1661057 Thanks Meter: 65 | after ffs: safe mode 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:F103:000E status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: N.V580.Y30M10.0202.08A0812M.1.4D091020G01 Version: REBOUND25_GEMINI_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 35007687941886 connection Ok building list... done items to clear: 157 warning: wrong packet cs warning: wrong packet cs items cleared: 157 of 157 building list... done items remains: 0 Finished, time used: 30 sec Remove/Install battery now ! and genral info: Action: read/check information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6225, E05 Hardware version: REBOUND25_GEMINI_HW Software version: N.V580.Y30M10.0202.0 Software date: 2006.06.14 Barcode: MT012345678901234567 imei-1: 356610015231513 imei-2: 356610015231513 imei-3: 356610015231513 Finished, time used: 15 sec Remove/Install battery now ! but no network( EMERGENCY) the info when dailing *#06# is: IMEI:356610015231513 IMEISV:78 i upload the firmware as: from alone alone <[email protected]> to [email protected] date Sun, Jun 6, 2010 at 7:25 PM subject new firmware R370M00_PCB01_GPRS_MT6225_S00.N_V580_Y30M10_0202_0 8A0812M_1_4D091020G01.BIN Last edited by sudsud; 06-07-2010 at 11:08. |
06-07-2010, 11:30 | #6 (permalink) |
Member: 420318 Status: Offline Sonork: 100.1661057 Thanks Meter: 65 | Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei write method: mode-1 imei write channel: imei #1 for dual sim/mono CPU new imei-1: 357968005873820 Verification failed ! What to do: 1. Power-Off phone 2. Press software "Write" button 3. Power-On phone Finished, time used: 15 sec Remove/Install battery now ! general info after mode 1: Action: read/check information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: AT+ESLP=0 Software version: MT6225, E05" Software date: REBOUND25_ Barcode: N.V580.Y30M10.0202.08A0812M.1.4D091020G01 imei-1: 2006.06.14" imei-2: MT0123456789012 imei-3: 356610015231513 Finished, time used: 8 sec Remove/Install battery now ! then i made ffs: safe mode again to get the old imei and here imei change mode 2" Action: "repair imei" imei write method: mode-2 imei write channel: imei #1 for dual sim/mono CPU new imei: 357968005873820 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:F103:000E status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: N.V580.Y30M10.0202.08A0812M.1.4D091020G01 Version: REBOUND25_GEMINI_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 35661001523151 connection Ok detecting structure #2... 5 11 done 67 byte(s) read verification... verification done: 35796800587382 Finished, time used: 19 sec Remove/Install battery now ! then the general info become: Action: read/check information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: AT+ESLP=0 Hardware version: MT6225, E05 Software version: REBOUND25_GEMINI_HW" Software date: N.V580.Y30 Barcode: 2006.06.14 imei-1: MT0123456789012 imei-2: 356610015231513 imei-3: 357968005873820 Finished, time used: 9 sec Remove/Install battery now ! |
06-07-2010, 11:55 | #7 (permalink) |
Member: 420318 Status: Offline Sonork: 100.1661057 Thanks Meter: 65 | again ffs safe mode: COM20 [VCP0] selected module v3.07 Action: reset settings ("format ffs") Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:F103:000E status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: N.V580.Y30M10.0202.08A0812M.1.4D091020G01 Version: REBOUND25_GEMINI_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 35796800587382 connection Ok building list... done items to clear: 141 warning: wrong packet cs warning: wrong packet cs items cleared: 141 of 141 building list... done items remains: 0 Finished, time used: 27 sec Remove/Install battery now ! general info after ffs: Action: read/check information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6225, E05 Hardware version: REBOUND25_GEMINI_HW Software version: N.V580.Y30M10.0202.0 Software date: 2006.06.14 Barcode: MT012345678901234567 imei-1: 356610015231513 imei-2: 356610015231513 imei-3: 356610015231513 Finished, time used: 14 sec Remove/Install battery now ! then imei write mode 3: COM20 [VCP0] selected module v3.07 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "repair imei" imei write method: mode-3 imei write channel: imei #1 for dual sim/mono CPU new imei: 357968005873820 ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:F103:000E status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #02 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #03 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished ==================== New firmware detected (v.3.07, database date: 16.01.2010): R370M00_PCB01_GPRS_MT6225_S00.N_V580_Y30M10_0202_0 8A0812M_1_4D091020G01.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info ver: 04 sw version: R370M00_PCB01_GPRS_MT6225_S00.N_V580_Y30M10_0202_0 8A0812M_1_4D091020G01.BIN project-id: N.V580.Y30M10.0202.08A0812M.1.4D091020G01, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: R370M00_PCB01_GPRS_MT6225_S00.N_V580_Y30M10_0202_0 8A0812M_1_4D091020G01__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\R370M00_PCB01_GPR S_MT6225_S00.N_V580_Y30M10_0202_08A0812M_1_4D09102 0G01__ffs_20100607-134816.B0E.bin flash: 98000300000001:18E59F00000000 Backup required data Done ====> Patch required data ... 16 step(s) required Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 98000300000001:18E59F00000000 Write: ffs Write Done ====> Finalization ... Finalization Done Finished, time used: 7 min 16 sec Remove/Install battery now ! general info after imei mode 3: Action: read/check information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: AT+ESLP=0 Hardware version: MT6225, E05 Software version: REBOUND25_GEMINI_HW" Software date: N.V580.Y30 Barcode: 2006.06.14 imei-1: MT0123456789012 imei-2: 356610015231513 imei-3: 357968005873820 Finished, time used: 9 sec Remove/Install battery now ! still can't change imei?? thank you in advance little question what IMEISV:78 mean? |
06-07-2010, 21:09 | #10 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! try to change both IMEIs via bluetooth: IMEI change without cable over Bluetooth link step-by-step tutorial - GSM-Forum |
06-08-2010, 09:05 | #11 (permalink) |
Member: 420318 Status: Offline Sonork: 100.1661057 Thanks Meter: 65 | oh my G_0_d* , dat's perfect , successfully imei changed using blutooth but the problem still , registration failed , i change many imei s from old handsets but the result still ( Emergency),, i can search for network manually but can't register , i think the phone is locked and need to sp- unlock i will post the result here of sp- unlock is it IMEISV:78 ??? what's dat mean? BIG THANK FOR InfinityHelp |
06-08-2010, 12:29 | #12 (permalink) |
Member: 420318 Status: Offline Sonork: 100.1661057 Thanks Meter: 65 | here general information with pin finder Action: read/check information Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: AT+ESLP=0 Hardware version: MT6225, E05 Software version: REBOUND25_GEMINI_HW" Software date: N.V580.Y30 Barcode: 2006.06.14 imei-1: MT0123456789012 imei-2: 357988025113288 imei-3: 352009025304432 Finished, time used: 8 sec Remove/Install battery now ! and here with bluetooth com port: Action: read/check information Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6225, E05 Hardware version: REBOUND25_GEMINI_HW Software version: N.V580.Y30M10.0202.0 Software date: 2006.06.14 Barcode: MT012345678901234567 imei-1: 352009025304432 imei-2: 357988025113288 imei-3: 352009025304432 Finished, time used: 5 sec Remove/Install battery now ! Again here sp-unlock standard COM20 [VCP0] selected module v3.15 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:F103:000E status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished ==================== New firmware detected (v.3.15, database date: 06.06.2010): R370M00_PCB01_GPRS_MT6225_S00.N_V580_Y30M10_0202_0 8A0812M_1_4D091020G01.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info ver: 04 sw version: R370M00_PCB01_GPRS_MT6225_S00.N_V580_Y30M10_0202_0 8A0812M_1_4D091020G01.BIN project-id: N.V580.Y30M10.0202.08A0812M.1.4D091020G01, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent detecting ffs/eeprom structure pass 1... ....................... ffs/eeprom: detect std location pass #1... .................................................. ... ffs/eeprom: detect standard offset pass #1... ffs/eeprom record offset detected ffs/eeprom: detect standard data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: R370M00_PCB01_GPRS_MT6225_S00.N_V580_Y30M10_0202_0 8A0812M_1_4D091020G01__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\R370M00_PCB01_GPR S_MT6225_S00.N_V580_Y30M10_0202_08A0812M_1_4D09102 0G01__ffs_20100608-141518.B0E.bin flash: 98000300000001:18E59F00000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 98000300000001:18E59F00000000 Write: ffs Write Done ====> Finalization ... Finalization Done Finished, time used: 12 min 36 sec Remove/Install battery now ! then phone genral info using pinfinder: Action: read/check information Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: AT+ESLP=0 Hardware version: MT6225, E05 Software version: REBOUND25_GEMINI_HW" Software date: N.V580.Y30 Barcode: 2006.06.14 imei-1: MT0123456789012 imei-2: 352943021391912 imei-3: 352943021391938 Finished, time used: 9 sec Remove/Install battery now ! also here using bluetooth Action: read/check information Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6225, E05 Hardware version: REBOUND25_GEMINI_HW Software version: N.V580.Y30M10.0202.0 Software date: 2006.06.14 Barcode: MT012345678901234567 imei-1: 352943021391938 imei-2: 352943021391912 imei-3: 352943021391938 Finished, time used: 5 sec Remove/Install battery now ! still emergency and i tried many imei s |
06-09-2010, 12:55 | #15 (permalink) |
Member: 420318 Status: Offline Sonork: 100.1661057 Thanks Meter: 65 | Thank you, InfinityHelp and Shakeel_pattoki when i try 2 call 112 without sim card it give me beeps ( unable to connect) but with sim card i can search for network manually then the operators in me country appers , when i choose the sim card operator it give me failed to register after a while BR |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
Nokia 51xx/61xx imei changer ver. 1.10?????? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 04-06-2012 16:22 |
6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-21-2011 01:44 |
