12-08-2008, 12:39 | #1 (permalink) |
Freak Poster Join Date: Mar 2008
Member: 718412 Status: Offline Thanks Meter: 5 | Procedure of changing MTK CPU ??? I've got problem here... I have a chinese phone with MTK 6226 inside, the CPU was really2 overheat, because user of the phone do a big mistake. But the phone works normally,like signal etc.. And then I try to change cpu and reflash with my own backup of full flash, but the phone can't be turned on.If i use the old cpu the phone works like before (with overheat of course). Now,my question is how the right procedure to change cpu? thanks, |
12-08-2008, 13:06 | #2 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Quote:
Many Chinese models has protection based on CPU ID. At first try to read flash from phone (with original CPU) and check text in operation log window very carefully. Post it here so we can check it too. Then we will see what to do. | |
12-08-2008, 16:07 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Hello, Infinity-Box has the most advanced methods for so called "decrypt" that was released very long time ago before any other tools. Please, follow my advice that was given in my previous message. |
12-09-2008, 05:59 | #5 (permalink) | |
Member: 718412 Status: Offline Thanks Meter: 5 | Quote:
COM4 [VCP6] selected module v2.70 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read NOR flash Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:F9CE:EC32 high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.E90D43B4.[U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B56.BIN_D AA6617D].rpl New firmware detected (2.70) : U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B56.BIN - make "Read full flash" operation - send "system_log_..." file to support: [email protected] - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) identification#1 detection finished device-id: E90D43B4 identification#1 protocol ver: 04 ver. sw 1: U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B56.BIN ver. sw 2: UPU25U26V03B56, 829E5925 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 98004900000002:2AEA0000000000 checking area [00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: flash[U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B56.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\Full_flash\flash_ K915_koRONY[U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B56.BIN]_20081201-210237.B0M.bin file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_E90D43B4_U26_06B_PCB01_GPRS_MT6226_S01.U PU25U26V03B56.BIN_DAA6617D_20081201-210353.B0X.bin Finished, time used: 976 sec Remove/Install battery now ! | |
12-09-2008, 09:33 | #6 (permalink) | |
Please, check marked text in your log. Please, follow the advice and we will be able to prepare new update and you will be able to repair phone after CPU replacement. | |
12-10-2008, 13:23 | #7 (permalink) |
Freak Poster Join Date: Feb 2004 Location: Malaysia Age: 40
Member: 52755 Status: Offline Thanks Meter: 10 | how if empty cpu?new cpu change. COM134 [VCP0] selected module v2.71 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read/check detailed information enhanced security fix enabled Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:FF0F:FFFFboot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 04227E22212200:18E59F00000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: 04227E22212200:18E59F00000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 04227E22212200:18E59F00000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: 04227E22212200:18E59F00000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: HX695_HW.S684_SM5_V3_0ITEST--080905.BIN ver. sw 2: S684_SM5_V3.0ITEST, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 04227E22212200:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF detecting ffs structure pass 1... ....................... detect standard fat location pass #1... .................................................. .... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs detected ok: element #1 detecting ffs structure pass 2... ....................... detect standard fat location pass #1... .................................................. .... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs detected ok element #2 Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Finished, time used: 61 sec Remove/Install battery now ! |
12-10-2008, 18:43 | #8 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,535 | hello! with new CPU you get dead phone because firmware is unknow for our program and it can not finalyse flashing correctly. please, send this firmware file "U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B56" to [email protected] after you send it- next CM update will finish job correctly and phone will be able to power On |
12-11-2008, 05:40 | #9 (permalink) | |
Freak Poster Join Date: Aug 2007 Location: Libya-Tripoly
Member: 565230 Status: Offline Thanks Meter: 22 | Quote:
Ofcourse it has ,and the best ever for me work perfect with empty cpu or taked from another phone(used).no defrent just be shore it's a good one. 1-Just change phone's cpu 2-flash the phone with original firmware , Finally get good worked phone Good luck the credits goes to infinityteam for good work B.R | |
12-11-2008, 16:33 | #10 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,535 | Quote:
this is absolutely correct, but with one exeption: if program detects this software version as "new"- phone will not power On with new CPU. this firmware must be sent to us for processing. after this Next update will solve this problem | |
12-12-2008, 00:49 | #11 (permalink) | |
Ofcourse i didn't mean for unknown firmware Thank you | |
change MTK chipset IMEI.for all cpu type. | kimlon_huang | Chinese Models & Cloned Phones | 23 | 08-07-2010 21:05 |
tv998 mtk cpu languace change possible ?? | RaSkAl01 | Infinity-Box | 8 | 04-18-2009 21:22 |
Unlock All Mtk Cpu | smart_mobile | Chinese Models & Cloned Phones | 3 | 11-16-2007 09:21 |
Dear Lead/Mizar pls show the procedure to change certificate of K750i with TP | sDinesh | Cruiser Suite | 12 | 12-15-2006 17:56 |
