05-28-2012, 16:16 | #1 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,419 | q mobile e786 flash read error module v4.27 Device: _Autodetect MT6252-6253 NOR Checking data, wait... Action: read flash NAND interface: BROM_DLL_v3.1108.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6250:CA02:0100 status: FF bbchip bl ver: FE NOR flash chip: S_DA_NOR_UNSUPPORTED_DEV_ID flash id: 00EF:004000150000 NOR_UNKNOWN NAND flash chip: 0BE9:S_DA_NFI_NOT_SUPPORT internal RAM size: 00004C00 external RAM: absent done Set baudrate (921600)... done error: no any detected/known flash chip found: 0BC0:S_DA_DEVICE_NOT_FOUND error: last error: 0BC0:S_DA_DEVICE_NOT_FOUND Disconnect... done Finished, time used: 34 sec Remove/Install battery now ! |
06-01-2012, 07:47 | #6 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,861 | Hello, Just got one phone for test with similar problem. Phone was booted well after I press and hold "power" button all time during boot process. "Power" button should be released after you will see "Set baudrate..." message. |
06-01-2012, 13:20 | #7 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,419 | RESULT IS SAME SIR TRIED WITNEW VER 4.28 ALSO HOLD POWER BUTTON TILL BAUND RATE SET TRIES WITH DIFFERENT SET BUT PROBLEM IS STILL SAME ALSO TRIED AT LOW baudrate COM4 [VCP0] selected module v4.28 Device: _Autodetect MT6250-6253 etc. Checking data, wait... Action: read flash NAND interface: BROM_DLL_v3.1108.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6250:CA02:0100 status: FF bbchip bl ver: FE NOR flash chip: S_DA_NOR_UNSUPPORTED_DEV_ID flash id: 00EF:004000150000 NOR_UNKNOWN NAND flash chip: 0BE9:S_DA_NFI_NOT_SUPPORT internal RAM size: 00004C00 external RAM: absent done Set baudrate (115200)... done error: no any detected/known flash chip found: 0BC0:S_DA_DEVICE_NOT_FOUND error: last error: 0BC0:S_DA_DEVICE_NOT_FOUND Disconnect... done Finished, time used: 23 sec Remove/Install battery now ! |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
Eeprom reading | KLImax | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 09-22-2011 15:55 |
