06-03-2011, 12:05 | #1 (permalink) |
Freak Poster Join Date: Mar 2009 Location: jind
Member: 998896 Status: Offline Thanks Meter: 15 | read full flash for no lincse to prdous module v3.31 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot Off chip: 0001:4903:0003 status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... slowest Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... warning: wrong cs at 0x00010318, retry... warning: wrong cs at 0x00010318, retry... warning: wrong cs at 0x00010318, retry... warning: wrong cs at 0x00010318, retry... warning: wrong cs at 0x00010318, retry... warning: wrong cs at 0x00010318, retry... warning: wrong cs at 0x00010318, retry... warning: wrong cs at 0x00010318, retry... warning: wrong cs at 0x00010318, retry... error: too many retries during read operation search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: GOLDDRAGON25_GEMINI_PCB01_GPRS_MT6225_S00.K01_KENX INDA_DM_ST32T3_AA_V18.BIN project-id: K01_KENXINDA_DM_ST32T3_AA_V18, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 error: wrong answer: 79 error: wrong answer: 00 : wrong answer after chip id request error: wrong answer: FF : wrong answer after chip cfi request error: wrong answer: 00 : wrong answer after chip id request Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... error: wrong answer: 00 . search sec info#1 finished error: wrong answer: 0B error: connection lost Finished, time used: 1 min 24 sec Remove/Install battery now ! plz halp me... |
06-04-2011, 21:19 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! some communication problems...can be caused by bad com port drivers too. if this box uses prolific usb-to-com converter- try to use driver from our support site |
06-05-2011, 12:49 | #7 (permalink) |
No Life Poster Join Date: Jul 2008 Location: pakistan hafizabad
Member: 811013 Status: Offline Sonork: 03468717163 Thanks Meter: 744 | error: wrong answer: 79 error: wrong answer: 00 : wrong answer after chip id request error: wrong answer: FF : wrong answer after chip cfi request error: wrong answer: 00 : wrong answer after chip id request Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... error: wrong answer: 00 . search sec info#1 finished error: wrong answer: 0B error: connection lost Finished, time used: 1 min 24 sec hloo Hardware prblam flsha chip not workes |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
