Old 04-04-2011, 09:51   #1 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 770
rocker m6
i have a rocker m6 which is dead , this is the info readed and formatted successfully
COM3 [VCP1] selected
module  v3.27
Device: Autodetect 6253 NOR
Checking data, wait...
Action: reset settings ("format ffs") NAND
interface: BROM_DLL_v3.1016.00
Connect...
Connecting...
Booting...
Release Power button now !
bootcode current/expected: 3.2/3.2
CPU: 6253:8A02:8A00
status: FF
bbchip bl ver: FE
NOR flash id[00BB]: 0001:007E00630001 [SPANSION] S29VS128R_T
chip size: 16Mb
otp status/size: S_DA_NOR_OTP_NOT_SUPPORT/00000000
NAND flash chip: not installed
internal RAM size: 00020000
external RAM: S_DA_RAM_ERROR
done
Set baudrate (921600)...
done
ram test...
testing...
ram test passed
===>  detect existing firmware structure...
detect ffs...
ffs offset/size: 00000000/00000000
detect sec ro...
detect custom parameters...
detect project-id...
project-id: MAUI.09AW0936MP_SLIM.W09.36.V6
detect NOR info...
number of areas/bytes to read: 1:00040000
reading (HW_STORAGE_NOR)...
TCL-ID detection...
TCL-ID detection done
startup code area #1 detection...
startup code area #1 detection done
rom info ver: 07
sw version: HSYD_N138_04_PCB01_GPRS_MT6253_S00.MAUI_09AW0936MP_SLIM_W09_36_V6.BIN_FLNS71VS128RB0AHK0L0
project-id: MAUI.09AW0936MP_SLIM.W09.36.V6, 00000000
code offset: 00000000
ffs offset/size [02]: 00E00000/00200000
rom info structure: [standard] type (07)
TCL-ID is absent
===>  done
New firmware found (v.3.27, database date: 01.03.2011):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
area size: 16Mb
number of areas/bytes to read: 1:01000000
file saved: D:\Program Files\InfinityBox\ChineseMiracle\HSYD_N138_04_PCB01_GPRS_MT6253_S00.MAUI_09AW0936MP_SLIM_W09_36_V6.BIN_FLNS71VS128RB0AHK0L0__fullflash_20110404-140932.B0M.bin
Format...
Disconnect...
done
Finished, time used: 13 min 16 sec
Remove/Install battery now !
Old 04-04-2011, 14:48   #2 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 770
i am having a problem with this set , after format and writing the imei , the set is having no network ...
what to do ?
Old 04-04-2011, 18:19   #3 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
what was it's problem before format?
does it call SOS number?
Old 04-04-2011, 18:46   #4 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 770
before format the set was in blinking condition so i format that and the set was ON ,
is there any other options to keep in mind while formatting 6253 cpu based sets ?
Old 04-05-2011, 06:46   #5 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 770
someone please help me on this issue ......
Old 04-05-2011, 07:45   #6 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
If after format and imei repair, there is even no sos call, then there is maximum possibilty of hardware problem in phone.
Wr.
Old 04-05-2011, 10:56   #7 (permalink)
Member: 148515
Hello!
does it call 112 (SOS) number?
can you see other network if you do search via menu?
Old 04-06-2011, 20:15   #8 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 770
i cannot call 112 it says failed
and
when i do manual search it does not shows any network
Old 04-07-2011, 09:28   #9 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
In this case there is maximum possibility that phone has hardware problem related to network.
Wr.
Old 04-07-2011, 18:51   #10 (permalink)
Member: 148515
hello!
there is big chance that this phone has damaged hardware
E1 Rocker Original gsm_school_indo Motorola P2k 0 01-28-2007 16:18
Rocker Imode dongles £100 - Cruiser logs £2 - Voda logs £x - Imode flashing software unlockclips.com Main Sales Section 0 12-18-2006 15:14
I-Mode Rocker Dongles on Sale ! Narry Main Sales Section 0 12-12-2006 02:56
!!! Moto Rocker Ready To Ship !!! TaHiR Main Sales Section 0 11-03-2006 14:23
ROCKER E1 itunezzzzzzz SM4RTBOY Smart-Clip 19 05-17-2006 14:10
Page generated in 0.23546 seconds with 9 queries
