Old 01-02-2009, 08:45   #1 (permalink)
Member: 432679
Thanks Meter: 118
S4 sigmatel unable to callibrate after complete ffs!!
this cell was having flight mode problem, so i did complte ffs.. after then when switch ON.. unable to callibrate touch screen....i tried all calibrate method from 1 ...5. no success operation failed error.
i replace the touchscreeen also,but no successs.
kindly asssit
regards!
==== log: [1/2/2009 12:14:42 PM] ====
COM8 [VCP0] selected
module v2.73
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: "format ffs"
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:6603:0000
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 98004900000002:18E59F00000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud ...
115200
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw 1: BOWAY25_GEMINI_PCB01_GPRS_MT6225_S00.S4_TOSHIBA_EF IAPVRHMIT_V035.BIN
ver. sw 2: S4_TOSHIBA_EFIAPVRHMIT_V035, 00000000
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
Finished, time used: 34 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
module v2.73
Action: touchscreen calibration
Model: Autodetect 6205-6227 NOR
19200 autodetect
CPU: MT6225
high speed boot On
Connecting, wait...
Phone detected, wait...
Hardware: MT6225,E03
Date: 2006.06.14
Version: 1.0
Version: S4_TOSHIBA_EFIAPVRHMIT_V035
Version: A760_V3.0_HW
detecting structure #2...
5 11 done
67 byte(s) read
imei: 13579024681122
warning: current phone imei is incorrect !
It's need to repair imei for correct phone functionality !
connection Ok
detecting structure #5 (mode-3)...
0 1 2 3 4 5 6 7 10 11 12 13 14 15 16 17error:
detection failed (16 tries)
What to do:
Try another calibration method, if still no luck:
1. make full flash backup for emergency case
2. make "format ffs"
3. Power-On phone
4. Power-Off phone by "Power" button (do NOT remove battery)
5. Repeat "Calibration" operation again
6. if still no luck read full flash and send to support with subject: touchscreen calibration failed
error: can't read required data
error: operation failed !
Finished, time used: 8 sec
Old 01-02-2009, 10:53   #2 (permalink)
.::BHATTI::.'s Avatar
Member: 203158
Sonork: 100.1592032
Thanks Meter: 358
well if none of them worked for u .. then u need the Flash File of this S4 sent to infinity .. they will help u .. like they helped me many times ...
The Following User Says Thank You to .::BHATTI::. For This Useful Post:
Old 01-02-2009, 13:53   #3 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
yes, waiting your email with subject "touchscreen calibration failed"
after detect pin out, unable to format ffs! syed.n Infinity-Box 2 01-08-2009 11:07
Sigmatel S90 After Complete FFS phone show Emergency Mode amol_sm Infinity-Box 3 09-28-2008 12:37
l7 unable to charge after unlock dino_d Smart-Clip 3 08-01-2008 09:39
MT6228: After Complete FFS PHONE DEAD dannyogolo Infinity-Box 3 10-17-2007 18:11
Page generated in 0.17303 seconds with 9 queries
