02-24-2015, 14:47 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: APPLE i Center Age: 39
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | Samsung Copy S7562 MTK6575A with Damage Boot @infinity team this phone was dead by wrong firmware,now phone can not with usb cable i try to find its K-COLO golden point on PCB,shorted with ground connect usb cable and and by pressing volume down key the phone connect with usb cable with PC show mtk drivers and on software i seen its preloader is erased,i read a flash file from the same phone and tried with cm2MTK moulder with differed methods but cm2MTK module hangs while flashing and result the flashing fails.............................here is flashing log how to flash this type of phones when boot is erased if some one experience please share Code: ========================= Start ========================= 2/24/2015 / 5:43:40 PM ========================================================= Card found: S/N 1E74:0128 Chinese Miracle II [MTK module] v 1.12 Start at : [2/24/2015 / 5:43:53 PM] Operation : Check / Read Info [ v1.12 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x82 WD Disable stat : 0x0000 BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMZW5 [eMMC] : FLASH_CID : 1501004E35575A4D420191DECCD021D1 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x00000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Done! Elapsed: 00:00:16 Reconnect Power/Cable! Finish at : [2/24/2015 / 5:44:09 PM] Load File File_Info : ztesz75_cu_ics FileVersion : MT6575 Load File Ok Start at : [2/24/2015 / 5:44:56 PM] Operation : Flash [ v1.12 ] ======= Flash Files set for flashing : [ MCU ] : SMDK4210__SAMSUNG__GT-S7562__ALPS.ICS.MP.V2.16__Android_4.0.4__20130705_065145.ispff 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x82 WD Disable stat : 0x0000 BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMZW5 [eMMC] : FLASH_CID : 1501004E35575A4D420191DECCD021D1 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x00000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! USBDL : Error init HSUSB!!! Operation Failed Elapsed: 00:00:21 Reconnect Power/Cable! Finish at : [2/24/2015 / 5:45:18 PM] Start at : [2/24/2015 / 5:45:24 PM] Operation : Flash [ v1.12 ] ======= Flash Files set for flashing : [ MCU ] : SMDK4210__SAMSUNG__GT-S7562__ALPS.ICS.MP.V2.16__Android_4.0.4__20130705_065145.ispff 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x82 WD Disable stat : 0x0000 BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMZW5 [eMMC] : FLASH_CID : 1501004E35575A4D420191DECCD021D1 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x00000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! USBDL : Skip HSUSB init Brand : samsung ProdName : bird75_d_cu_ics ProdModel : GT-S7562 Device : bird75_d_cu_ics AndroidVer: 4.0.4 MTKxCPU : SMDK4210 MTKxPRJ : ALPS.ICS.MP.V2.16 ISPFF ID : 6575 TARGET ID : 6575 Flash pre-erase enabled Erase Flash now ... ========================= Start ========================= 2/24/2015 / 5:48:16 PM ========================================================= Card found: S/N 1E74:0128 Chinese Miracle II [MTK module] v 1.12 Load File File_Info : ztesz75_cu_ics FileVersion : MT6575 Load File Ok Start at : [2/24/2015 / 5:48:48 PM] Operation : Flash [ v1.12 ] ======= Flash Files set for flashing : [ MCU ] : SMDK4210__SAMSUNG__GT-S7562__ALPS.ICS.MP.V2.16__Android_4.0.4__20130705_065145.ispff 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x82 WD Disable stat : 0x0000 BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMZW5 [eMMC] : FLASH_CID : 1501004E35575A4D420191DECCD021D1 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x00000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! USBDL : Skip HSUSB init Brand : samsung ProdName : bird75_d_cu_ics ProdModel : GT-S7562 Device : bird75_d_cu_ics AndroidVer: 4.0.4 MTKxCPU : SMDK4210 MTKxPRJ : ALPS.ICS.MP.V2.16 ISPFF ID : 6575 TARGET ID : 6575 Flash pre-erase enabled Erase Flash now ... ========================= Start ========================= 2/24/2015 / 5:50:03 PM ========================================================= Card found: S/N 1E74:0128 Chinese Miracle II [MTK module] v 1.12 Start at : [2/24/2015 / 5:50:22 PM] Operation : Check / Read Info [ v1.12 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:39 Reconnect Power/Cable! Finish at : [2/24/2015 / 5:51:01 PM] Load File Bad file detected! Load File File_Info : ztesz75_cu_ics FileVersion : MT6575 Load File Ok Start at : [2/24/2015 / 6:22:26 PM] Operation : Flash [ v1.12 ] ======= Flash Files set for flashing : [ MCU ] : SMDK4210__SAMSUNG__GT-S7562__ALPS.ICS.MP.V2.16__Android_4.0.4__20130705_065145.ispff 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x82 WD Disable stat : 0x0000 BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage Will use Secure DA for boot target DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMZW5 [eMMC] : FLASH_CID : 1501004E35575A4D420191DECCD021D1 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x00000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! USBDL : Init HSUSB Ok! Brand : samsung ProdName : bird75_d_cu_ics ProdModel : GT-S7562 Device : bird75_d_cu_ics AndroidVer: 4.0.4 MTKxCPU : SMDK4210 MTKxPRJ : ALPS.ICS.MP.V2.16 ISPFF ID : 6575 TARGET ID : 6575 Flash pre-erase disabled Write Flash now ... [ MCU ] : SMDK4210__SAMSUNG__GT-S7562__ALPS.ICS.MP.V2.16__Android_4.0.4__20130705_065145.ispff Init Ok , Sending blocks ... Write failed :( Flash Error! Check Cable, Battery , try again Operation Failed Elapsed: 00:01:26 Reconnect Power/Cable! Finish at : [2/24/2015 / 6:23:53 PM] Start at : [2/24/2015 / 6:24:00 PM] Operation : Flash [ v1.12 ] ======= Flash Files set for flashing : [ MCU ] : SMDK4210__SAMSUNG__GT-S7562__ALPS.ICS.MP.V2.16__Android_4.0.4__20130705_065145.ispff 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x82 WD Disable stat : 0x0000 BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMZW5 [eMMC] : FLASH_CID : 1501004E35575A4D420191DECCD021D1 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x00000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! USBDL : Init HSUSB Ok! ========================= Start ========================= 2/24/2015 / 6:24:27 PM ========================================================= Card found: S/N 1E74:0128 Chinese Miracle II [MTK module] v 1.12 Load File File_Info : ztesz75_cu_ics FileVersion : MT6575 Load File Ok Start at : [2/24/2015 / 6:24:53 PM] Operation : Flash [ v1.12 ] ======= Flash Files set for flashing : [ MCU ] : SMDK4210__SAMSUNG__GT-S7562__ALPS.ICS.MP.V2.16__Android_4.0.4__20130705_065145.ispff 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x82 WD Disable stat : 0x0000 BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage Will use Secure DA for boot target DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMZW5 [eMMC] : FLASH_CID : 1501004E35575A4D420191DECCD021D1 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x00000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! USBDL : Skip HSUSB init Brand : samsung ProdName : bird75_d_cu_ics ProdModel : GT-S7562 Device : bird75_d_cu_ics AndroidVer: 4.0.4 MTKxCPU : SMDK4210 MTKxPRJ : ALPS.ICS.MP.V2.16 ISPFF ID : 6575 TARGET ID : 6575 Flash pre-erase disabled Write Flash now ... [ MCU ] : SMDK4210__SAMSUNG__GT-S7562__ALPS.ICS.MP.V2.16__Android_4.0.4__20130705_065145.ispff Init Ok , Sending blocks ... Write failed :( Flash Error! Check Cable, Battery , try again Operation Failed Elapsed: 00:12:13 Reconnect Power/Cable! Finish at : [2/24/2015 / 6:37:07 PM] |
02-25-2015, 05:57 | #4 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Alternate - not sure yet. Will collect some samples and try. | |
02-26-2015, 07:45 | #5 (permalink) | |
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | samsung copy s7582 MT6575 boot Golden Kcolo Point Quote:
a full dump from working phone,the same phone SMDK4210__SAMSUNG__GT-S7562__MTK6575__ALPS.ICS.MP.V2.16__Android_4.0.4__ 20130705_065145 a working and tested boot point,Kcolo Point.here | |
The Following 2 Users Say Thank You to ..::AppleLinks::.. For This Useful Post: |
03-03-2015, 05:16 | #6 (permalink) |
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | let starts its final story: the phone is revived by flashing with flash tool with having preloaded files,and after when i power on it was hang on samsung LOGO,after that i flash with CM2 WITH RADED FILES WITH cm2,NOW PHONE IS WORKING WELL..going WELL @ALL POST YOUR STORY HERE BEFORE FLASH WITH PRELOADER FILES Code: Operation : Flash [ v1.13 ] ======= Flash Files set for flashing : [ MCU ] : SMDK4210__SAMSUNG__GT-S7562__MTK6575__ALPS.ICS.MP.V2.16__Android_4.0.4__20130705_065145.ispff 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x82 WD Disable stat : 0x0000 BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMZW5 [eMMC] : FLASH_CID : 1501004E35575A4D420191DECCD021D1 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x00000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! USBDL : Skip HSUSB init AFTER FLASH PRE LOADER FILES WITH ORG FLASH TOOL COMPLETE FLASH WITH CM2MTK WITH SAME PHONE FILES READIED BY CM2MTK BIN FILE. Code: ========================= Start ========================= 3/2/2015 / 4:02:32 PM ========================================================= Card found: S/N 1E74:0128 Chinese Miracle II [MTK module] v 1.13 Load File File_Info : ztesz75_cu_ics FileVersion : MT6575 Load File Ok Start at : [3/2/2015 / 4:03:00 PM] Operation : Flash [ v1.13 ] ======= Flash Files set for flashing : [ MCU ] : SMDK4210__SAMSUNG__GT-S7562__MTK6575__ALPS.ICS.MP.V2.16__Android_4.0.4__20130705_065145.ispff 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x82 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMZW5 [eMMC] : FLASH_CID : 1501004E35575A4D420191DECCD021D1 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Brand : samsung ProdName : bird75_d_cu_ics ProdModel : GT-S7562 Device : bird75_d_cu_ics AndroidVer: 4.0.4 MTKxCPU : SMDK4210 MTKxPRJ : ALPS.ICS.MP.V2.16 ISPFF ID : 6575 TARGET ID : 6575 Flash pre-erase enabled Erase Flash now ... Flash pre-erase done Write Flash now ... [ MCU ] : SMDK4210__SAMSUNG__GT-S7562__MTK6575__ALPS.ICS.MP.V2.16__Android_4.0.4__20130705_065145.ispff Init Ok , Sending blocks ... Write done , 3728 blocks sent Done! Elapsed: 00:15:49 Reconnect Power/Cable! Finish at : [3/2/2015 / 4:18:50 PM] |
03-03-2015, 05:32 | #7 (permalink) |
No Life Poster Join Date: Jan 2013 Location: (Tech land)
Member: 1864000 Status: Offline Thanks Meter: 2,893 | @..::AppleLinks::.. Bro here is simple trick ,first write only preloader file by free tool.After that you can remove jumper from kkolo and gnd ,Read and write will work. |
03-07-2015, 11:42 | #9 (permalink) | |
No Life Poster Join Date: Feb 2007 Location: Ethiopia
Member: 449991 Status: Offline Thanks Meter: 933 | i have same problem with same phone Quote:
i have same problem with same phone with magic cable able to write preloder pc now detact board but i need full flash bucup please upload again link dead | |
03-07-2015, 12:10 | #11 (permalink) | |
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | Quote:
Simple File Sharing and Storage. | |
03-07-2015, 14:37 | #12 (permalink) | |
Member: 449991 Status: Offline Thanks Meter: 933 | pls fix it not work Quote: Dangerous File Blocked The file you attempted to download was determined to be dangerous. For your protection, MediaFire does not enable distribution of dangerous files. Still have questions, or think we've made a mistake? Please contact support for further assistance. pls fix it not work | |
03-30-2015, 10:31 | #13 (permalink) | |
SMDK4210__SAMSUNG__GT-S7562__MTK6575__ALPS.ICS.MP.V2.16__Android_4.0.4__ 20130705_065145 - Download - 4shared | |
The Following User Says Thank You to ..::AppleLinks::.. For This Useful Post: |
03-30-2015, 12:24 | #14 (permalink) |
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | @jayadi i have a samsung copy 7582 with mtk6572 and flash chip is SCANDISK, i try with diferent firmwares read with cm2mtk but no luck,is different flash chip have different flash files or what???? ,phone was dead with flashing cm2mtk with readed flash files from same s7582 with mt6572 cpu.....can u help me about it????? |
03-30-2015, 13:15 | #15 (permalink) | |
Code: Card found: S/N 1E74:0128 Chinese Miracle II [MTK module] v 1.15 Scatter Load Ok , BaseBand : MT6572 , Project : hexing72_wet_jb3 , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.15 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 36 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 45010053454D3034473A3486BEFC7173 DA Stat : v4.2 on BBID : 0x88 Configure emi settings DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0045 , OEM : 0100 [eMMC] : FLASH_INF : G40ME [eMMC] : FLASH_CID : 45010053454D3034473A3486BEFC7173 [eMMC] : FLASH_LEN : 0x00000000EC000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : hexing72_wet_jb3 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Switching to HSUSB HSUSB Init Ok SecCfg Passed , 1799 BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BMT remark not need. Will skip Sending Preloader ... Use : preloader_hexing72_wet_jb3.bin Preloader Sent , Init passed | |
