08-14-2010, 13:07 | #1 (permalink) |
Registered User Join Date: Aug 2010
Member: 1359163 Status: Offline Thanks Meter: 37 | Sciphone i999 What Flash http://img801.imageshack.us/img801/4...iphonei999.jpg now ifninity post log: COM13 [VCP0] selected module v3.19 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read ffs/eeprom ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF boot packet size: 0400 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 17 sec Remove/Install battery now ! when I change "Boot baudrate autoselect" I have same results -------------- When I try to format with safe mode. here is log: COM13 [VCP0] selected module v3.19 Action: reset settings ("format ffs") Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF rom: 4D453032 Connecting at 19200, wait... error: can not finalize test mode repeat operation and HOLD phone "Power" button more long time ! error: operation failed ! Finished, time used: 1 min 22 sec Remove/Install battery now ! How I find eeprom and flash to this phone ? infinity dont show that any idea to repair this i999 ? |
08-15-2010, 03:40 | #8 (permalink) |
Freak Poster Join Date: Aug 2008 Location: Hungary
Member: 829361 Status: Offline Thanks Meter: 107 | Tthis phone has NAND flash. You never can operate it if you try to detect as NOR. Change to "Autodetect 6228-6239 NAND" at the Settings tab. I know this phone and CM has no problem with it. Almost all 6235 phones has NAND flash, not NOR. |
08-16-2010, 10:53 | #11 (permalink) |
No Life Poster Join Date: Mar 2007 Location: PL Age: 44
Member: 477842 Status: Offline Thanks Meter: 80 | format safe log : COM13 [VCP0] selected module v3.19 Action: reset settings ("format ffs") Model: Autodetect 6228-6239 NAND Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF rom: 4D453032 Connecting at 19200, wait... error: can not finalize test mode repeat operation and HOLD phone "Power" button more long time ! error: operation failed ! Finished, time used: 1 min 21 sec Remove/Install battery now ! ------------------------------ format complete ===> detect existing firmware structure... detect ffs... detect sec ro... detect custom parameters... detect project-id... detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: header is empty: probably flash chip completely erased warning: can not detect header nfi area detection finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done Format (HW_STORAGE_NAND)... error: can not format: 0BFA:S_DA_HANDSET_FAT_INFO_NOT_FOUND error: last error: 0BFA:S_DA_HANDSET_FAT_INFO_NOT_FOUND Disconnect... done Finished, time used: 55 sec Remove/Install battery now ! |
08-16-2010, 21:48 | #13 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! hard to advice flash file without knowing original version. basing on your PCB code i can suggest: flashfiles/ChineseMiracle/_MT6235/NEOTEL35_08B_GEMINI_PCB01_GPRS_MT6235B_S01.LN233_H Y_V1_0R--100225__I999_128m_En_Ru_Gr_Nl_Fr_Es_It_Da_Sv_Pl_De _Ml_Id_Th_Vn_Cn_Tr_Farsi_Pt_Fi_Cz_Cn_He_Ar.B4M.bin flashfiles/ChineseMiracle/_MT6235/NEOTEL35_08B_GEMINI_PCB01_GPRS_MT6235B_S01.LN233_H Y_V1_0R--100315__i999_128m_En_Ru_Gr_Nl_Fr_Es_It_Da_Sv_Pl_De _Ml_Id_Th_Vn_Cn_Tr_Farsi_Pt_Fi_Cz_Cn_He_Ar.B4M.bin |
09-23-2010, 18:55 | #14 (permalink) | |
Member: 1359163 Status: Offline Thanks Meter: 37 | Quote:
here is log COM13 [VCP0] selected module v3.21 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: write flash NAND write: Firmware L01_GEMINI_07B_PCB01_GPRS_MT6225_S00.MAUI_07B_W08_ 16_MP_V4_F1_32m_En_Ru_El_Fr_Es_It_De_Ml_Id_Th_Vn_C n_Tr_Farsi_Pt_Cn_Ar.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... warning: incorrect header: 18F09FE518F09FE518F09FE518F09FE5 warning: can not detect header nfi area detection (0 cores) finished: failed error: unknown source file structure Finished, time used: 3 sec Remove/Install battery now ! every flash I have in bin format | |
09-23-2010, 19:41 | #15 (permalink) |
Member: 1359163 Status: Offline Thanks Meter: 37 | My mistake, because this is noit 6225 but 6235 after try flash NEOTEL35_08B_GEMINI_PCB01_GPRS_MT6235B_S01.LN233_H Y_V1_0R--100315__i999_128m_En_Ru_Gr_Nl_Fr_Es_It_Da_Sv_Pl_De _Ml_Id_Th_Vn_Cn_Tr_Farsi_Pt_Fi_Cz_Cn_He_Ar.B4M.bin I have log COM13 [VCP0] selected module v3.21 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: write flash NAND write: Firmware NEOTEL35_08B_GEMINI_PCB01_GPRS_MT6235B_S01.LN233_H Y_V1_0R--100315__i999_128m_En_Ru_Gr_Nl_Fr_Es_It_Da_Sv_Pl_De _Ml_Id_Th_Vn_Cn_Tr_Farsi_Pt_Fi_Cz_Cn_He_Ar.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... bootloader version: NEOTEL35_08B_GEMINI_BOOTLOADER_V005_MT6235B_LN233_ HY_V1_0R.bin nfi area detection (3 cores) finished: Ok "format ffs" active interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0005]: 00EC:0079005A003F [SAMSUNG] K9K1G08X0A chip size: 128Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (115200)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... detect sec ro... detect custom parameters... detect project-id... detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: header is empty: probably flash chip completely erased warning: can not detect header nfi area detection (0 cores) finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done nfi area detection... bootloader version: NEOTEL35_08B_GEMINI_BOOTLOADER_V005_MT6235B_LN233_ HY_V1_0R.bin nfi area detection (3 cores) finished: Ok startup code area #1 check... error: done number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . . . . . . . . write core... error: can not write flash: 0FAF:S_FT_NFB_DOWNLOAD_CODE_FAIL error: last error: 0FAF:S_FT_NFB_DOWNLOAD_CODE_FAIL Disconnect... done Finished, time used: 8 min 17 sec Remove/Install battery now ! |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
SIM restriction pending -- what does it mean? | Ryu | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 07-17-2011 10:05 |
