Old 12-28-2009, 14:50   #1 (permalink)
k_abhi's Avatar
Member: 1019814
Thanks Meter: 653
sigmatel S88 shows NOT CALIBRATED
Hello frnds, I got a china sigmatel model- S88, with hang problem...... so I'd formatted it with spiderman, formatting shown completed without any errors. But when I'd switched on the handset it is showing Not Calibrated........... I'd also calibrated it with Infinity box, Calibrating got completed but still handset showing same message?????????? I'd also flashed it with infinity and calibrated but same!!!!!!!!!!!!!!! Could anyone explain what happened to the handset???????/ And what to do now?????/ Plz
The Following 2 Users Say Thank You to k_abhi For This Useful Post:
Old 12-29-2009, 04:30   #2 (permalink)
sigamani's Avatar
Member: 817776
Thanks Meter: 109
i have same problem.....
Old 12-29-2009, 06:06   #3 (permalink)
Member: 593491
Thanks Meter: 53
s88
brother do ffs formate on infinty and change imei then do revers celebration in different mood
The Following User Says Thank You to babaformula For This Useful Post:
Old 12-29-2009, 06:47   #4 (permalink)
Ramzan khan's Avatar
Member: 405696
Thanks Meter: 148
S88 formate on infinty and change imei then do celebration. if still problem then rehot 6225 or 6226
Old 12-29-2009, 21:36   #5 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
you must format phone using infinity and next try one by one all calibration method.
this is only needed what touchscreen is damaged. If not- do calibration manualy, by taping LCD with a pen
Old 12-30-2009, 09:06   #6 (permalink)
k_abhi's Avatar
Member: 1019814
Thanks Meter: 653
hello!
sir, I've tried it with infinity box, calibration shows completed with all modes...... but still it displays this message on power on "NOT CALIBRATED" there is no option to calibrate manualy 'coz it doesnt goes to calibrate option. Infact touchscreen is also ok, I've changed it 10 times........................ Plz help me out I'm tooooooooo confused
Old 12-30-2009, 23:28   #7 (permalink)
Member: 148515
hello!
show us all calibration logs
Old 12-31-2009, 20:43   #8 (permalink)
k_abhi's Avatar
Member: 1019814
Thanks Meter: 653
hello!
Hello sir, first of all Wish U all a HAPPY & PROSPEROUS NEW YEAR...........!!!!!!!!
Here's handsets display photo to understand actually whats happening...
http://www.4shared.com/file/18553148...2009_001_.htmlHere's the handset's format log with infinity---------
COM22 [VCP1] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: "format ffs"
Boot...
19200 fixed
Connecting, wait...
Initializing[6225:8A05]...
CPU: MT6225
high speed boot enabled
chip: 0001:4503:000C
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 2088C4FFFFFFFF:2088C400000000
flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
115200
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw1: T600_V04_PCB01_GPRS_MT6225_S00.T600_V04_ENFRARRUSP PEVI_SIGMATEL.BIN
ver. sw2: T600_V04_EnFrArRuSpPeVi_SIGMATEL, 00000000
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
Can't detect eeprom/ffs area
Do you want to use standard ffs address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs address selected by user
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading: eeprom[T600_V04_PCB01_GPRS_MT6225_S00.T600_V04_ENFRARRUSP PEVI_SIGMATEL.BIN]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[T600_V04_PCB01_GPRS_MT6225_S00.T600_V04_ENFRARRUSP PEVI_SIGMATEL.BIN]_20091231-201939.B0E.bin
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
Write Done
Finalization...
formatting...
Finalization Done
Finished, time used: 259 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Then I've calibrated it ............ it shows completed like this>>>>>>
mode 1-
Action: touchscreen calibration
Model: Autodetect 6205-6227 NOR
19200 autodetect
CPU: MT6225
Connecting, wait...
Phone detected, wait...
Hardware: MT6225,E05
Date: 2006.06.14
Version: 1.0
Version: T600_V04_EnFrArRuSpPeVi_SIGMATEL
Version: T600_V04_HW
detecting structure #2...
5 11 done
67 byte(s) read
imei: 35619900120321
connection Ok
detecting structure #5 (mode-1)...
1 4 5 6 done
211 byte(s) read
writing data...
verification...
verification Ok
Finished, time used: 12 sec
for all next three modes..... only detecting structure #5 varies like this-------
for mode 2, it is 0 1 3 6 done;
for mode 3, it is 0 done;
for mode 4, it is o done..........
can u plz tell me whatz goin wrong with this phone??????????
The Following User Says Thank You to k_abhi For This Useful Post:
Old 01-01-2010, 02:33   #9 (permalink)
Member: 1028430
Thanks Meter: 65
put s18 flash file, it will solve your problem
Old 01-01-2010, 02:37   #10 (permalink)
Member: 1028430
Thanks Meter: 65
your s 88 shows not calibrated on the screen just like nokia shows contact service,the only way is to flash the phone with sigmatel s18 flash file, it will surely solve your problem, if it doesnt then contact me
Old 01-01-2010, 19:13   #11 (permalink)
k_abhi's Avatar
Member: 1019814
Thanks Meter: 653
I need s88 flash files............. could u give me link plz??????//
Old 01-02-2010, 12:11   #12 (permalink)
k_abhi's Avatar
Member: 1019814
Thanks Meter: 653
Anybody from Infinity team, Spiderman team, any china mobile master...........
PLEASE HELP ME OUT>!!!!!!!!!
I've tried to write new s88 eeprom files to this phone........ but then alsoit is showing - NOT CALIBRATED........anybody plz help... here's the write file log-
Action: write NOR flash
"smart write" active
skip: Firmware
skip: Customization/Language Pack
skip: Customization
write: Eeprom/ffs
Boot...
19200 fixed
Connecting, wait...
CPU: MT6225
Boot Done
Initialize...
Initialize Done
Set baud...
115200
Set baud Done
eeprom/ffs found near: 00E00000
ffs chip: 00
file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[T600_V04_PCB01_GPRS_MT6225_S00.T600_V04_ENFRARRUSP PEVI_SIGMATEL.BIN]_20100102-135207.B0E.bin
Write...
Area: Eeprom/ffs
Write: Eeprom/ffs
error: error# 000000FF
error: flash write error: 00E40000:00002000
error: no any expected answer
error: unexpected termination/freez: 00000000
Write Fail
Finished, time used: 276 sec
Old 01-02-2010, 15:23   #13 (permalink)
Member: 148515
hello!
we will check this firmware
Old 01-03-2010, 07:12   #14 (permalink)
k_abhi's Avatar
Member: 1019814
Thanks Meter: 653
hello!
'll b waiting for ur reply.........
Old 01-03-2010, 09:36   #15 (permalink)
Member: 733449
Sonork: 100.334100
Thanks Meter: 292
Mate, u just write back your eeprom file which save you during format ffs.
china s88 shows - NOT CALIBRATED k_abhi SpiderMan 1 01-01-2010 14:44
China Sigmatel S88 " Not calibrated" problem micro_hsr Chinese Models & Cloned Phones 3 12-19-2009 10:48
Sigmatel s88 show screen error amit.alag Chinese Models & Cloned Phones 3 08-22-2009 06:42
sigmatel s88 shows only not calibrate rakesh15 Infinity-Box 0 06-11-2009 06:51
Show not calibrated on screen youarethebest Infinity-Box 6 05-10-2009 23:56
Page generated in 0.24628 seconds with 10 queries
