11-24-2010, 12:31 | #1 (permalink) |
No Life Poster Join Date: Feb 2009 Location: INDIA
Member: 973227 Status: Offline Sonork: 100.1583121 Thanks Meter: 270 | Sir please help me for this chinese c5 i cant connect it in pinfinder , i seen there is spedtrum cpu inside(SC6600L2-224G) and also as the spedtrum cpu phones are detected in device manager by port but this phone is not detecting this phone is brand new and i opened it first time also customer having some more same phones to repair , but i have no idea to connect this also tried in some other tools to connect but no success. there inside phone i found rx-tx & ground dots , i also tried by that but no success. sir will you please guide me for this?? software version: 1.24 platform: SPD: Spreadtrum SC6600M, SC6600R cable type: 1x12 (L12C) mode: Slow searching adapter at COM9 (115200)... too many retries adapter found, version: 4000 Loading platforms configuration... Initializing platforms... Press and HOLD phone Power button now (not required but recommended) ! pins: 12, plain power/activation cycles: 1/10 power-off delay: 20 start Rx/Tx: 1/1 detecting pins... failed to detect pins time required: 16 sec Trying to Power-On... Power is On |
11-24-2010, 19:42 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! when connecting test points you must follow next rule: Tx point must be connected to RX pin of RJ45 port. Rx point must be connected to Tx pin of RJ45 port. GND to box GND (pin8) |
11-25-2010, 18:38 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! when you connect to test points you dont use pinfinder port. you must use regular RJ45 port. check this example in pictures: http://forum.gsmhosting.com/vbb/f296...-cable-386780/ |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
