Old 12-30-2008, 16:10   #1 (permalink)
Member: 441483
Thanks Meter: 6
Somebody Help me...please
i need firmware for Ktouch A905....TM927_PCB04_GPRS_MT6228_S02.092710_670_V00 31.BIN
i have dead phone now....
Please....
Old 12-30-2008, 16:17   #2 (permalink)
.::BHATTI::.'s Avatar
Member: 203158
Sonork: 100.1592032
Thanks Meter: 358
check on support ... there are Lot of firmwares available on support by infinity Team .......
Old 12-30-2008, 16:36   #3 (permalink)
Member: 441483
Thanks Meter: 6
I'll try it...but i can't found it..Sir
Old 12-30-2008, 16:37   #4 (permalink)
TUR@N ALAM's Avatar
Member: 705213
Sonork: https://wa.link/aru52t
Thanks Meter: 2,735
Click here to download file
The Following User Says Thank You to TUR@N ALAM For This Useful Post:
Old 12-30-2008, 16:49   #5 (permalink)
Member: 441483
Thanks Meter: 6
Originally Posted by turan alom View Post
Thanks a lot...Sir
Old 12-30-2008, 17:47   #6 (permalink)
Member: 441483
Thanks Meter: 6
I try to use it...but still error...
COM3 [VCP0] selected
module v2.73
Device: Autodetect 6228, 6229, 6230 NAND
Checking data, wait...
Action: write NAND flash
read mode: 01
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
source data: page only
identification#1 protocol ver: 04
ver. sw 1: TM927_PCB04_GPRS_MT6228_S02.092710_670_V0031.BIN
ver. sw 2: 092710_670_V0031, 4A004E0F
ffs offset/size: 01900000/02700000
id-page1 Ok
nfi area detection finished: Ok
Boot ...
19200 fixed
Connecting, wait...
Initializing [6228:8A02:8A02]...
CPU: MT6228
high speed boot On
chip: 0031:0000:0101
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
version: 3.0207
loader: 3.748.0
NAND id: 98F18095
page size: 800+40
pages/block: 40
bits i/o: 08
address cycles: 04
blocks: 0400
ram size: 00800000
NOR: 0000:000000000000 [00000000]
NAND: 0098:00F100800095 [08400000]
NOR chip is not installed
Initialize Done
Set baud ...
115200
Set baud Done
Identification ...
reading structure area...
detecting structure...
id-page1 Ok
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is damaged, recalculation required
identification#1 detection finished
warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.27EADFDB.[TM927_PCB04_GPRS_MT6228_S02.092710_670_V0031.BIN_F 0B1FFB5].rpl
warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.27EADFDB._TM92 7_PCB04_GPRS_MT6228_S02.092710_670_V0031.BIN_F0B1F FB5_.rpl
warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.27EADFDB.[TM927_PCB04_GPRS_MT6228_S02.092710_670_V0031.BIN_F 0B1FFB5].rpl
warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.27EADFDB._TM927_PCB04_GPRS_MT6228_S02.092710_670 _V0031.BIN_F0B1FFB5_.rpl
warning: unknown identification#1 structure: TM927_PCB04_GPRS_MT6228_S02.092710_670_V0031.BIN_F 0B1FFB5
error: Unknown firmware, user action required:
1. download latest software from support area and try again !
2. if no still luck follow the next procedure:
- find good working phone with the same firmware:
- make "Read detailed information" operation
- send "system_log_..." file to support: [email protected]
- make "Read full flash" operation
- send flash backup file(s) to support: [email protected]
- include in your e-mail full text from phone back label (phone name etc.)
- be little bit patient and wait update
You can flash phone now but can't finalize it.
In most cases phone can NOT power-on normally.
Do you want to write flash anyway ?
Identification Done
Write ...
write core area 1 of 2...
write core area 2 of 2...
error: code: A500000BF1
error: code: 5A
error: code: A500
error: code:
error: block/offset: 000002D5/002D5000
error: can't write nand core
Write Fail
Finished, time used: 896 sec
Remove/Install battery now !
Old 12-30-2008, 18:24   #7 (permalink)
TUR@N ALAM's Avatar
Member: 705213
Thanks Meter: 2,735
TM927_PCB04_GPRS_MT6228_S02 jast look like a serch
Old 12-31-2008, 08:18   #8 (permalink)
Member: 441483
Thanks Meter: 6
I try to use this file from support but still error......
TM927_PCB04_GPRS_MT6228_S02.092710_670_V0031__64m_ En_Cn.B4M.bin
TM927_PCB04_GPRS_MT6228_S02.092710_670_V0031__128m _En_Cn.B4M.bin
Firstable...the phone restarted....i do wrong procedure...format whole chip....and then the phone dead....
Maybe somebody can give me soulution......
Old 01-02-2009, 10:35   #9 (permalink)
Member: 441483
Thanks Meter: 6
Somebody ....help me please....phone dead now...
Old 01-02-2009, 10:58   #10 (permalink)
Member: 203158
Sonork: 100.1592032
Thanks Meter: 358
well its the Comprehensive way to find the file :
http://forum.gsmhosting.com/vbb/showthread.php?t=499453
if still no luck than u need the Phone same alike ..then read and just do your work ...
Could somebody help me please? Elizabeth92 Samsung Flashers, Software, Firmware. 4 02-12-2008 08:52
can somebody help me please mickb9455 CAR Electronics 0 07-23-2007 18:56
Somebody Help Me PLEASE bobby5 Old Ericsson Phones & Sony Phones 2 07-23-2000 17:34
Somebody Help Me PLEASE bobby5 Motorola Old Legacy (EMMI) 0 07-22-2000 16:44
Page generated in 0.19350 seconds with 10 queries
