07-25-2016, 18:52 | #1 (permalink) |
Freak Poster Join Date: Aug 2009 Location: nobody is perfect and i'm 1
Member: 1105427 Status: Offline Sonork: I don't use sonork Thanks Meter: 57 | TECNO DP7CPRO Hanks after CM2 USER RESET members Kindly check the info below and give me instructions on how to solve my problem , i just used reset userlocks button on CM2 as fone owner has a fogoten password but after fone refuses to on..and hanks on tecno screens and android upgrade reboot and so on....Will be glad if any of u can poin out the exact file by the info shown below to flash the set back to normal... Don't Be supriz cos am like a new baby when its comes to chines tools Operation : Check / Read Info [ v1.51 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 54 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 700100563130303136501E9FADE7A29B Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , 61001 [eMMC] : FLASH_CID : 700100563130303136501E9FADE7A29B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000386000000 [eMMC] : FLASH_UCP : 14432 MiB [eMMC 16 GiB] DEV RID : 0x1C45FED8192E6F57BF87CCD5C3D62D92 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : TECNO ProdName : DP7CPRO ProdModel : TECNO DP7CPRO Device : DP7CPRO AndroidVer: 5.1 MTKxCPU : MT6580 MTKxPRJ : ALPS.L1.MP6.V2_HTT8321.EMMC_P21 Done! Elapsed: 00:00:08 Reconnect Power/Cable! |
07-25-2016, 19:23 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Recover data with forensic tab and then make factory reset. Next time follow instruction in SW. |
11-20-2017, 06:43 | #10 (permalink) |
Junior Member Join Date: Jul 2013 Location: Manila, Philippines
Member: 1987144 Status: Offline Thanks Meter: 4 | i had the same issue with this tablet after clicking Reset UserLocks on UserData / Rorensic i had this unit hang on TECNO boot animation Thanks to JayDi after using FULL FACTORY RESET (ALL) on service tab, my problem solved |
The Following 2 Users Say Thank You to stigmatized For This Useful Post: |
