Old 03-23-2009, 08:36   #1 (permalink)
Member: 701779
Sonork: 100.1622334
Thanks Meter: 121
test report for I phone 16Gb failed INFINITY
COM6 selected
module v2.79
Device: Autodetect 6228-6230 NAND
Checking data, wait...
Action: write NAND flash
read mode: 01
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
source data: page only
identification#1 protocol ver: 04
ver. sw 1: APL216_PCB01_GPRS_MT6230_S02.APL216_V1_2_20080918. BIN
ver. sw 2: APL216_V1.2_20080918, 9C534816
ffs offset/size: 02000000/06000000
id-page1 Ok
end mark #2 found
nfi area detection finished: Ok
Boot ...
baud autodetection active
19200 autodetect
Connecting, wait...
Initializing [6230:8A02:8A02]...
CPU: MT6230
high speed boot Off
chip: 0031:0000:0101
status: FF
high speed boot Off
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
version: 3.020C
loader: 3.748.0
NAND id: ECF10095
page size: 800+40
pages/block: 40
bits i/o: 08
address cycles: 04
blocks: 0400
error: unexpected answer:
NOR: 0000:000000000000 [00000000]
NAND: 00EC:00F100000095 [08400000]
NOR chip is not installed
Initialize Done
Set baud ...
slowest
Set baud Done
Identification ...
reading bootloader structure area (00080000 bytes)...
warning: nfi read command is not accepted
error: bootloader structure area read failed, read again...
error: can't read area required for bootloader structure detection: 00000000 instead of 00080000
Identification Done
Write ...
error: write bootloader command is not accepted
error: can't write nand bootloader
Write Fail
Finished, time used: 160 sec
Remove/Install battery now !
Old 03-23-2009, 09:35   #2 (permalink)
Member: 701779
Sonork: 100.1622334
Thanks Meter: 121
another test result..
==== log: [3/23/2009 4:36:50 PM] ====
COM6 [VCP1] selected
module v2.79
read mode: 01
write: Firmware
skip: Customization
skip: Eeprom/ffs
id-page1 Ok
end mark #4 found
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6230
high speed boot On
status: FF
Boot Done
Initialize ...
version: 3.020C
loader: 3.748.0
NAND id: ECF10095
page size: 800+40
pages/block: 40
bits i/o: 08
address cycles: 04
blocks: 0400
ram size: 00800000
Initialize Done
Set baud ...
slowest
Set baud Done
Identification ...
detecting bootloader structure...
warning: probably flash chip completely erased, no bootloader found
nfi area detection finished: failed
detecting bootloader structure by source file...
id-page1 Ok
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is Ok
security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.277ADFDB.[APL216_PCB01_GPRS_MT6230_S02.APL216_V1_2_20080918. BIN_E9B7AC63].rpl
identification#1 detection finished
security area (code #1) calculation...
Identification Done
Write ...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_277ADFDB_APL216_PCB01_GPRS_MT6230_S02.AP L216_V1_2_20080918.BIN_E9B7AC63_20090323-163807.B4X.bin
00006000 bytes sent
write core area 1 of 3...
00417400 bytes sent
write core area 2 of 3...
010BEC00 bytes sent
write core area 3 of 3...
00635400 bytes sent
Write Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_277ADFDB_APL216_PCB01_GPRS_MT6230_S02.AP L216_V1_2_20080918.BIN_E9B7AC63_20090323-172235.B4X.bin
Finished, time used: 2742 sec
WARNING ! Settings will be cleared, user data erased, Imei set to default value !
Make flash backup before this procedure !
Do you want to continue ?
==== log: [3/23/2009 5:23:51 PM] ====
module v2.79
Action: NAND reset
read mode: 01
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6230
high speed boot On
status: FF
Boot Done
Initialize ...
version: 3.020C
loader: 3.748.0
NAND id: ECF10095
page size: 800+40
pages/block: 40
bits i/o: 08
address cycles: 04
blocks: 0400
ram size: 00800000
Initialize Done
Set baud ...
slowest
Set baud Done
Identification ...
id-page1 Ok
security area (code #1) is damaged, recalculation required
Identification Done
Write ...
formatting...
..error: code: 1C00006900
...error: code: 4000006900
.................................................. ...............................error: code: 2200006900
....error: code: 6400006900
..........error: code: A502000000
error: code: 0600000000
Write Fail
Finished, time used: 83 sec
Old 03-23-2009, 10:38   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
1. What is the reason to start new thread each time instead of make an answers in old threads ?
2. You must check your phone hardware or your cable due to now I am sure that software works without problems.
Why so ? Easy answer: I see good test report from other user who has EXACTLY the same phone (just compare firmware version name): http://www.mcrf.ru/forum/showthread.php?t=19807
p.s.
Information for all users: many users make answers to only one question from the questions that was asked by supporter.
It is really terrible situation for supporters (we can not understand reason of this kind of ignorance) so from today we will close any thread if users did not make an answers to all questions that was asked by supporters.
Thank you for your understanding and cooperation !
Old 03-23-2009, 14:14   #4 (permalink)
Member: 701779
Sonork: 100.1622334
Thanks Meter: 121
well i made a mistake in this forum i didnt mean to do that certain thing.. sorry supporter. thanks!
Test report for 5.91 1208 zipzap_kill MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 10-23-2009 07:07
Test Report for new UPDATE 1.06 alfox Cyclonebox 2 08-14-2009 19:14
About I phone 16GB sir infinity... lorenzo roberto Infinity-Box 2 03-20-2009 08:40
Worked and tested pinouts for Chinese phones are here GSMtricks Chinese Cocktail 32 10-22-2008 15:27
Auto PinFinder Adapter for Chinese phones launched by Infinity Box Team InfinityHelp Main Sales Section 0 04-06-2008 11:26
Page generated in 0.20249 seconds with 10 queries
