05-24-2009, 03:55 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: MX-Key and me ...The Best
Member: 617692 Status: Offline Thanks Meter: 306 | Touch Screen Celebration Solved Dear users ...some friends complaining for Touch Screen Celebration that do not work..The Problem is that it shows connection but can not connect to the phone or do not format with "Safe Mode" because of low voltage.... Solution: Open your Infinity Box (not Pinfinder) and remove the diod inside. The work of Diod is to control the battry voltage. It gives low voltage so you can not connect to the phone and progress bar goes to 100% and do not connect with phone. So remove the diod and make a jumper...your problem will be solved 80%. and the 20% ramaining I still not solved..because these chines set have big speakers and lights and need more voltage.. for picture of diod goto the folder :C:\Program Files\InfinityBox\Documentation\PinFinder and open "Infinity-Box_PinFinder.pdf" with adobe reader. Then goto page 21 or search in the pdf document "diod". |
05-24-2009, 04:08 | #2 (permalink) |
Member: 617692 Status: Offline Thanks Meter: 306 | Seconed Problem Solved Seconed Problem Solved: If your touch screen works very well but still not removing the touch screen problem.... and all the procedures finishies with okey... then try the same Mode two or three times for examle if you use Mode-1 and phone connects and finish with oky and problem still not solved then try the same Mode-1 for two or three times. your problem will be solved |
05-24-2009, 06:08 | #3 (permalink) | |
No Life Poster Join Date: Oct 2005 Location: P A K I S T A N Age: 16
Member: 190344 Status: Offline Thanks Meter: 280 | Quote:
br hamis | |
05-24-2009, 20:50 | #6 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
almost all boxes has this diode. please measure voltage beween pin 1 and pin 8 in your box RJ45 connector. what value do you get? | |
05-24-2009, 20:57 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! even modified box can not power On completly some phones. Tip: power on phone with battery, select "silent" mode and continue work. Fast silent mode is activated by pressing and holding "#" key |
Sigmatel touch screen celebrate | alamgarh | Infinity-Box | 7 | 04-20-2010 15:24 |
touch screen celebration | dreams_bd | CPF-BOX Ⅱ | 8 | 04-26-2009 20:36 |
Celebrate Touch Screen & Bad Software | iqbalbangash | SpiderMan | 8 | 04-11-2009 02:19 |
iphone touch screen problem! solved | gopalhot | iPhone 2 / iPhone 3G / iPhone 3GS | 7 | 08-18-2008 16:15 |
iphone touch screen problem! solved | gopalhot | Nokia Hardware & Hardware Repair | 1 | 06-04-2008 12:41 |
